logo
Go Back   4x4 Community Forum > General Category > Vehicle & Technical Chat > Ford & Mazda
4x4Community
Notices
Ford & Mazda Combined forum for Ford and Mazda
Reply
Thread Tools Display Modes
  #1
Old 27-01-10, 04:41 PM
BushMan BushMan is offline
Member
Default Ranger 2.5 TD turbo
Hi fellow Ranger owners,
I have a 2004 2.5TD DC Ranger, now my question is can you actually tell or feel your Ranger's turbo kicking in, on the Toyota D4D I can definitly feel it but on my truck I can't realy tell if it kicked in or not
  #2
Old 27-01-10, 05:26 PM
Hardebak's Avatar
Hardebak Hardebak is offline
Member
Hi Bushman
My truck is very much the same..can't really feel it..I have also driven the 2.5 D4D and it is quite different...can feel that asthma pump arriving at the party ;P..
Mine sounds pretty cool though!! ;P
__________________
02' Defender 90 TD5
OME suspension
33" Hankook Muds
  #3
Old 28-01-10, 08:02 AM
Hagu13's Avatar
Hagu13 Hagu13 is offline
Member
I've driven a few Rangers and can definitely feel it, although on one Ranger I had (a single cab) it was much less pronounced- perhaps because the vehicle was lighter. Haven't driven a D4D so can't compare.
If you accelerate gently from 1300rpm in 4rd gear or so, you should get a nice surge around 1750. Essentially the motor cannot generate enough torque to pull the skin off a rice pudding at 1300, but is pretty strong at 1750 and very strong at 2000.
Alternatively, if you accelerate hard from steady state 2000rpm, you should get a certain amount of acceleration immediately, then a step increase about a second later courtesy of the turbo.
Also, if you can run it to at least 155km/h on a GPS (could be 170 on a speedo depending on your tyres) then your power output is what you should expect and your turbo is working.
  #4
Old 29-01-10, 12:36 AM
Scrat's Avatar
Scrat Scrat is offline
aka Vrod
Not really...and not sure what the previous comment was as even below boost the diesel has more than enough torque to climb...just depends how fast you wanna get there..when I off-raod I like to go as slow as possible and as fast as I need.
A WELL matched engine turbo gives you an almost seemless power/torque curve unlike the 2.5 Navara,dead then hits like a train to get that peak power.....pointless on the dirt...but anyway...The variable vein turbo does just that, give you that smooth pull...
MOST turbo passanger and bakkie TDI's pull from as low as 1400rpm but usually around 1800rpm..
By the way..if you have the 3.0D4D, that motor pulls ALOT harder than your 2.5
  #5
Old 29-01-10, 01:32 AM
BigBear BigBear is offline
Member
Most Certainly felt the kick from 2000 rpm on ...
Feels a bit slow and laggy up till 2k rpm then it pulls all the way to 3/3500 rpm
Most important on TD is to make use of the boost and slick shifts... to keep it within the boost and torque ...
kW not much use on the TD
1>2 3000 rpm falls back to 2000 rpm ( in boost and torque )
2>3 3000 rpm falls back to 2250 rpm +-
Can't remember all exactly was sold last year
  #6
Old 29-01-10, 01:37 AM
Member
Lightbulb
Also keep in mind that the 2500TD/2.5TD
Is the older gen Diesel Turbo's...
TDi, D4D, TDCi etc... all newer Common Rail / Direct Injection / Variable Vane Turbo Charged Motors
Variable Vane Turbo on D4D, TDCi, TDi causes the Turbo to spool up faster and supplying the boost from +- 1450 - 1750 ( lightly ) more Pronounced Boost from 1800 rpm On
Common Rail on most newer models also contribute and uses very High Injection Pressure rails.
On the Newer Gen. TD's it is preferred to use ULS / 50ppm Clean Diesle
__________________
2005 Ford Ranger SuperCab XLT 4000V6 Manual 5 Speed 4x4
Petri
1997 Ford Explorer XLT 4.0 L SOHC V6 Auto AWD 4x4
Pieter
  #7
Old 29-01-10, 11:54 PM
Danny_Boi's Avatar
Danny_Boi Danny_Boi is offline
Member
Set of nice and easy in 1st, put 2nd and put your foot flat to the floor, it will lag like a biatch, then at about 1800-2000 it will pull like a train, if not then somethings seriously wrong. infact for you to be asking this question, something must defantly be wrong!
__________________
  #8
Old 30-01-10, 12:57 PM
Botswana's Avatar
Botswana Botswana is offline
Member
That nice "kick in the butt" is not simply caused by the turbo coming on song - the biggest contributor is the injector pump restrictor / limiter (older technologies refer to it as an air-fuel ratio control),either mechanical or controlled by the ECM, acknowledging increased boost thereby allowing a fairly drastic increase in the amount of fuel injected.
Depending on design the reasons for the low-RPM restriction could for instance be to lower stress on the internals, or to limit the amount of black smoke from the exhaust.
Some engine designs do not display any perceivable kick but simply a smooth, increasing pull as the revs and load rises, others are relatively dead to a point and then all the action starts. The higher the boost setting, the more marked the "kick" tends to be. Variable-vane technology helps to lessen the kick by allowing better power from lower RPM's throughout a larger range.
It's one of the reasons why I simply LOVE diesels - the knowledge and feeling of POWER without having to wrench the guts out of it....
__________________
2011 VW Amarok BiTdi 4-Motion
2006 Daihatsu Sirion
6 x Water Buffalo's
Honda Lawnmower
  #9
Old 26-06-12, 10:37 PM
BlaaSopiE BlaaSopiE is offline
Member
Default Checks
Good day
There is a small siv you might want to have a look at (it might be clogged). it is on your diesel pump. Ill get the documentation and post it tomorrow. If that doesn't work you might want to refurbish your injectors and calibrate your diesel pump.
__________________
Texas walker RANGER
2.5 TD 4X4 XLT '04
  #10
Old 27-06-12, 07:17 AM
BushFire's Avatar
BushFire BushFire is offline
Commercial Member
Quote:
Originally Posted by BlaaSopiE
Good day
I posted step by step pictures of how to clean out that sieve. Just go do a search. It was a few months ago.
__________________
SHOWHOUSE KITCHENS & DESIGN
"Never compromise on Quality"
Contact: Juan G. Brand 083 677 3912
Email:juan@showhousekitchens.co.za
FaceBook: facebook.com/showhousekitchens
Picture Thread
WE WORK COUNTRYWIDE
  #11
Old 27-06-12, 12:43 PM
jice jice is offline
Member
I can also hear the turbo slightly when i drive with the cab window open at the back
__________________
Jaco
Life's a journey, enjoy the ride.
2004 Ford Ranger 2.5TD D/C 4x4
Mini Metalian - bush home (in progress)
2006 Toyota Corolla 160 GLS
  #12
Old 02-07-12, 04:07 PM
Hilly Hilly is offline
Member
Default Is this mod worth it?
Hi all
as always you get the best advice on
this forum
My question is , is it worth the effort to do free flow exhaust and pump tune up
SAC quoting R2600) or will this be a minimal improvement
SAC quote some impressive figures an xtra 30 KWand pretty good Nm aswell but ihave already done 198 000ks and am just hoping one of the knowledgable guys can give me some advice please
thanks guys
  #13
Old 02-07-12, 04:11 PM
Member
Default sorry!!!
Sorry guys i did not mean to pose this query in yhe middle of some one elses query i just hit the wrong button
my appologies
  #14
Old 20-08-12, 08:24 PM
JacoNeethling's Avatar
JacoNeethling JacoNeethling is offline
Member
Default Ford ranger 2.5 tdi 4x4 2005
Hi everyone, recently bought a 2005 2.5 tdi 4x4 Ford Ranger. Really happy with it except that its a bit slow compared to friends non 4x4 version. (same year and model) Is there a diffrence in performance between the 2 ? I have been told a Sirus intercooler and a exhaust system with the correct downpipe from the turbo will do the job. Apparently 100 nm more, can anybody advise on this ? thanks
  #15
Old 20-08-12, 08:33 PM
DVR DVR is offline
Member
If I have to repeat myself !! it is going to be the 4th longest thread on the forum !! go find my Ford second longest thread and you will get all your answers.
  #16
Old 20-08-12, 08:35 PM
Fanatic's Avatar
Fanatic Fanatic is offline
Member
1. Have you cleaned the secondary diesel filter? If not, do so.
2. Search 'Ford se tweede langste thread'. DVR explains exactly what to do iro performance.
  #17
Old 20-08-12, 08:36 PM
Fanatic's Avatar
Member
Quote:
Jy was vinniger as ek Oom Ek moet jou nog kom sien!
  #18
Old 16-09-12, 03:38 PM
Baboel's Avatar
Baboel Baboel is offline
Member
To Jaco Neetling.
The 4x4 have much more drag on the front sideshafts the are constantly turning compared to he 4x2. This is the reason most 4x2's fuel consumption is less than the 4x4.
__________________
Mazda Drifter 2500TD 4x4 , stock standard.
VHF: Vertex VX2200, 29MHz:GME GX300
Garmin NuLink 2390 , Garmin Quest
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Fitting a turbo on 2005 2.5 Ford penny1000 Ford & Mazda 3 20-10-09 09:04 AM
Ford Ranger 2.5 Supercab vs Ford Ranger Supercab 4.0 Wenwe Ford & Mazda 7 13-04-09 08:40 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Template-Modifications by TMS
