Hallo all
On my way home tonight the 'Water in diesel filter' warning light start to blink.
Now a couple of observations:
- The filter was replaced approx 4000 km ago, together with injectors;
- The Sasol garage was tested by Sasol, and given a clean bill of health;
- I filled up at the same garage since then as it was tested clean;
Up to now I have never had to drain the water (85K km), why now suddenly in the span ~4000 km done since fitting a new filter? (Maybe the light only started to work when they replaced the filter
Is it sufficient to drain and check the light, or do I need to replace the filter again to be sure? (Just YESTERDAY I took the vehicle back to diagnose the injectors again, just as a precautionary measure. Values were something like 0.7, all 4 perfect)
Thank you
