logo
Go Back   SA 4x4 Community Forum - The only forum for the offroad and 4x4 enthusiast > General Category > The 4x4 Pub
4x4Community
Notices
The 4x4 Pub Off topic chat area, from the latest to IT questions may be posted here. Please keep it clean and family orientated, or your post WILL be deleted.
Reply
Thread Tools Display Modes
  #1
Old 03-12-09, 07:05 PM
KobusDJ's Avatar
KobusDJ KobusDJ is online now
Member
Default Clear Ice
To make clear ice (those nice looking see through cubes) you need to do the following:
Use clean/pure water (distilled)
Boil it to get rid of the dissolved air
Freeze in layers
Question: Does it mean that the more "milky" your cubes are, the more impure/polluted/contaminated water you have.
__________________
Kobus
'96 Nissan Hardbody DC V6
  #2
Old 03-12-09, 07:46 PM
Soutter's Avatar
Soutter Soutter is offline
Member
Quote:
Not necessarily ... also has to do with the way it was frozen, if it has melted and refrozen etc.
freezing water slowly will result in clearer ice than water frozen quickly.
also, the older type of ice makers (the ones that spray a steady stream of water into an inverted "cup") make clearer ice than the ones which immerse a cold rod into water.
__________________
2008 Jimny (ex SJ)
...Extended diff & tcase breathers, dual battery, towbar
2008 Terios Offroad
...nudgebar, spots, runners, dvd
  #3
Old 03-12-09, 07:52 PM
MikeAG's Avatar
MikeAG MikeAG is online now
Member
No, it means there is more oxygen dissolved into the water. Your process is simply about removing bubbles of gas. Compressed snow, squished such that there is no place left for the bubbles of air, is clear when it freezes into ice.
Mike
__________________
"Mike for President". Freeflyd & Kalamazoo
  #4
Old 03-12-09, 08:08 PM
KobusDJ's Avatar
Member
So it is more the trapped oxygen than the impurities.
Those people doing the ice sculptures always amaze me with their "clear" ice.
__________________
Kobus
  #5
Old 03-12-09, 08:44 PM
TiaanS's Avatar
TiaanS TiaanS is online now
Member
I know that for the construction of the ICE hotel in Kiruna they only use crystal clear ice from the Torne River. The river’s ice got some unique properties in the way that it freezes up as well as the water quality.
__________________
Live life on the edge... you get a better view !
Disco 3 Video
http://www.youtube.com/watch?v=STt7DmJeeVc
  #6
Old 04-12-09, 08:50 AM
Randy's Avatar
Randy Randy is offline
Member
Is the "whiteness" not caused by suspended solids in the water?
Mike - you in the UK will not have this YOURS will have only oxygen.
Maybe OT, but most water filters / purifiers (even some that cost R5 - 7k) are ONLY for aesthetic purposes. Removes smell, taste and looks clean.
Dis some research for a guy at Pecanwood a few years ago, he ended up installing a R300k 3x4m room full of purification plant to get rid of all the nasties (microsistoxins etc.) in the "borehole" water. If people REALLY knew what was in that dams water they would not go near it never mind in IT!!!!
No i did not make a fortune, i was only paid for my advise, plant came from USA. They make systems that can remove the 2700 most common chemicals etc from water.
There is a SCARY subject for YOU.
__________________
I hate being so intolerant, and I wouldn't be if people didn't deserve it.
  #7
Old 04-12-09, 08:57 AM
4ePikanini
Guest
Posts: n/a
I believe that those impurities ( the natural ones other than the obvious harmful viruses ) contains some nutrients and it keeps your immune system exercised.
I have been drinking from the tap for 25 years and I can't really remember the last time I was horribly sick.
On the subject of clear ice - It is the oxygen that escapes and gets trapped when the water freezes and creates pressure. If you want clear ice try this : boil water and pour it in the ice tray. Try to be gentle when pouring to keep it from dissolving extra air again. Put it directly into a very cold freezer.
  #8
Old 04-12-09, 09:04 AM
Frans Reichert's Avatar
Frans Reichert Frans Reichert is online now
Member (aka Julius)
Perhaps I can help.
For background, we manufactor Ice, about 12 ton of it each day, and then we distribute them in Kimberley and serounds. So believe me when I say: I am cool!!
Doesn't matter how clear your ice is, after a time it wil go white, but if jou dip it in water for a moment it wil become clear again.
The icemachines work on a principle that the water keep on moving and freeze on the evaporator. If the water doesn't move you get ice with more cracks and bubbles in.
__________________
No one ever ruined their eyesight by looking at the BRIGHT side!!
  #9
Old 04-12-09, 09:08 AM
ArrieMeyer ArrieMeyer is offline
Member
The whiteness is caused by dissolved elements in the water, so using distilled water with the air boiled out will definitely result in clearer ice cubes. Remember: even clean water has some dissolved elements such as oxygen, nitrogen, chlorine, magnesium etc.
It works like this: the higher the temperature of the water, the more dissolved ions can be present in the water. When we make ice cubes, the water cools and solidifies from the outside. The colder water cannot hold as much frozen ions, and therefore the dissolved elements are continiously rejected from the solidification front into the unfrozen water. As the solidification front moves towards the centre, the unfrozen water therefore becomes more and more enriched in dissolved matter, i.e. the concentration of dissolved ions becomes larger and larger. In the end, there is no unfrozen water left, and the dissolved ions simply freeze in. The "white" center is therefore a supersaturated solution of various elements in water, and the clear part is relatively low in dissolved matter, except for the very little that can be in solution at such low temperatures.
Depending on the amount of dissolve matter that we start with, the "white" part may be smaller or larger, sometomes even resulting in a totally "white" ice cube. These sometimes result in Coke (or any other gas cold drink) "boiling" vigorously when the ice is added, as some of the dissolved ions replace the CO2 dissolved in the Coke, whereuopon the CO2 leaves the Coke and make bubbles.
  #10
RedLineR RedLineR is offline
Member
Don't worry about milky ice. It's just air.
Water is kinda weird that way, but this is what happens.
As water is cooled, it shrinks. this means that it's density increases.
Right down to around 4°C.
When water continues cooling to below 4°C it starts expanding again. In other words it's density decreases. It still weighs the same, but the volume is occupies becomes larger. You see this in your ice trays in that they look fuller than they did when you filled them with water.
Then as the water solidifies (freezes), it continues to change density. That's when the air in the water can now longer be suspended in the water. so it separates out of the water, but is trapped in the cube.
Nothing to worry about.
Air and moisture works much the same way. As air cools it cannot keep the water vapour in suspension anymore, and the water drops from suspension. We see it as water forming on a cold glass. The glass cools a thin layer of air around the glass to such an extent that the water vapour drops out of suspension and forms droplets on the glass.
Same with rain, which is why we don't often get rain when it's lekka hot. There are ofcourse times that a cold air stream at high altitude meets a nice big cloud and cools it, causing the water vapour to be dropped from suspension. But we mostly get rain in the afternoon when the temps are going down. Water vapour has built up nicely to max capacity at that temperature, and as soon as the temp drops, the water drops out of suspension because the air cannot sustain the amount of water vapour at the decreased temp.
I'm over-simplifying a bit so we don't have to go down to atomic and sub-atomic level, but you get the idea
__________________
SWAMBO
Me
2003 Ford Focus 2.0
  #11
Old 04-12-09, 09:09 AM
DavidW's Avatar
DavidW DavidW is offline
Member
Very interesting Frans, one learns new things every day!
__________________
David Wolmarans
Ford Ranger 2.5 4 x 4 DC turbo diesel, bog standard (Have now fitted a Burnco front bumper, looking for a snorkel)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Tropica ice boxes. Ian Upfold Trailers, Radios, Fridges, Camping etc 2 29-12-09 11:02 PM
12v Ice machines snomaster Engel Commercial Member Adverts 4 28-10-09 02:41 PM
Dry Ice hakkie Trailers, Radios, Fridges, Camping etc 21 24-05-09 11:18 PM
Making Ice - the ultimate answer babba Trailers, Radios, Fridges, Camping etc 31 22-12-08 11:03 PM
ICE in case of emergency Engel General (non vehicle/technical) 4x4 Discussions 7 06-04-08 07:59 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
ABMM Powered by Syrian Medical Society
Template-Modifications by TMS
