logo
Go Back   SA 4x4 Community Forum - The only forum for the offroad and 4x4 enthusiast > General Category > Vehicle & Technical Chat > Jeep
4x4Community
Notices
Reply
Thread Tools Display Modes
  #1
Old 03-12-09, 03:14 PM
Chris_cross's Avatar
Chris_cross Chris_cross is offline
Member
Default Jeep XJ 2.5td Engine oil drain plug?
Hi this might be a reaally stupid question, but after looking at the manual and doing some google searches i cannot find anu useful info. Im trying to change the engine oil in my XJ but cannot work out which is the drain plug? Theres a square section under the motor (sump?) and has a bolt in the bottom, in the centre (looks like a torx bolt or something)...is this it?
Im scared to remove something i shouldnt...
thanks
  #2
Old 03-12-09, 07:40 PM
Biggles's Avatar
Biggles Biggles is offline
Member
It is an alan key bolt that is it
__________________
2001 Jeep Cherokee Country 2.5Td 3.5 inch Rubicon Express Lift, Airflow snorkle, 31inch Cooper STTs, 29Mhz, Nomad front and rear bumper with rear tire carrier. RTI=764
Platkar: 2002 M Coupe
SWAMBO: Freelander I Td4
Work: Land Cruiser ute
Talk softly, carry a BIG stick
  #3
Old 03-12-09, 08:43 PM
Member
Quote:
i need to get the right size, it seems a standard set doesn't have it.? or its stripped too much, do you think i could just replace this bolt with some other?
  #4
Old 05-12-09, 09:23 AM
Biggles's Avatar
Member
I would get a Jeep part to replace, Should not cost much. Proberbly easier than trying to find a same thread plug with the right shape.
__________________
  #5
Old 05-12-09, 09:27 AM
Biggles's Avatar
Member
Getting out a stripped sump plug will be interesting...
Maybe just remove the whole sump... with a Big drip tray underneath
__________________
  #6
Old 07-12-09, 12:57 PM
Arrie's Avatar
Arrie Arrie is offline
Member
That might be Impereal Alan key so metric might not work the way you think it should. And I agree with Biggles. Get sump plug from Jeep.
This is advice for all Jeep owners. Get yourself a workshop manual for your Model of Jeep. I do all my services on my 4.7 WJ Jeep myself and you wount believe how much money you can save by doing it yourself. The manual will also help find small problems yourself and fix it yourself.
But off coarse if your jeep is still under warinty or motor plan, you will have to take it to the dealers.
One thing that also helps allot, eaven if your service interville is 10 000 km, still do a oil change every 5000 km yourself. It will save you lots of money in the long run.
__________________
I work off shore so I can Play OFF ROAD..lol
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Delo 400 Testimony 4ePikanini General (non vehicle/technical) 4x4 Discussions 99 02-02-10 08:09 PM
An interesting TJ Jeep Article. Big Hilux Jeep 2 19-05-09 10:31 PM
Diff Oil Drain? steamer Isuzu 2 13-05-09 04:19 PM
Good Oil ---- Bad Oil !!!!!!!!! Landy Nut Vehicle & Technical Chat 34 12-02-07 12:34 PM
Jeep CJ 6Cyl EFI Engine for sale JeepCJ5 For Sale, Swop & Give-Away 1 07-02-07 10:37 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
ABMM Powered by Syrian Medical Society
Template-Modifications by TMS
