Vehicle & Technical Chat Only on topic posts allowed, all off topic posts will be removed. Off topic posts to be restricted to General Chat. |
03-12-09, 03:14 PM
Member
Extra electric fans
This has been a hot topic recently and decided today that I need some extra cooling. The XJTd has a viscous fan (recently replaced) aswell as an electric fan. They both just don't cut it especially in the dunes. After hitting a slope and getting bogged and maybe abit of grinding with the aircon on she will suddenly overheat.
Even without the aircon on it will run hot. So decided I need to nip it in the butt and install extra cooling fans. Not much room for any other improvement, pretty tight in there.
Infront of the radiator there is a space 5 cm deep x 80cm long x 25cm high. I am thinking of getting 3 20cm fans and hooking them up to the auxillary fan circut, so they come on with the main electric fan.
Where can I source these fans? Any recomendations? And will I get slimline fans that will fit in the 5cm deep gap?
__________________
2001 Jeep Cherokee Country 2.5Td  3.5 inch Rubicon Express Lift, Airflow snorkle, 31inch Cooper STTs, 29Mhz, Nomad front and rear bumper with rear tire carrier. RTI=764
Platkar: 2002 M Coupe
SWAMBO: Freelander I Td4
Work: Land Cruiser ute
Talk softly, carry a BIG stick
Reason: Duh, 5cm not 5mm
03-12-09, 03:20 PM
Member
Not sure of the dimensions, but Autozone has quite a range available.
03-12-09, 03:21 PM
SIR
I put 2 x Toyota RunX fans in my LC and they keep a 4,2TD motor cool. Barely run.
Only problem is that they are about 30mm thick.
PS. Don't use the Autozone ones. They die quickly and they are not as effective.
Put 4 of them on the KZ Prado and they didn't do the job. But then nothing helps for the bloody KZ.
__________________
GX LC80 D/C 1HD-FTE
TDI Golf 4
And some toys.
03-12-09, 03:22 PM
Miserable Soutie
Midas in Montague Gardens has a range of different sizes
__________________
zu1spk X13
"Amateurs talk tactics, professionals talk logistics."
03-12-09, 03:25 PM
Member
If you wanna get extra fans, get the good stuff.
http://www.ebmpapst.co.za/
__________________
SWAMBO
Me
2003 Ford Focus 2.0
03-12-09, 03:29 PM
Member
Sorry guys, 5cm not 5mm deep.
__________________
03-12-09, 03:32 PM
SIR
Quote:
The RunX fans cost me R250 each.
PS. I also fitted a thermostat and a 3 way switch.
1. Fan is auto. Comes on at 85degC and off at 80degC
2. Off. Water crossings and the likes.
3. On. Permanent on. Specifically for when the aircon is on.
__________________
GX LC80 D/C 1HD-FTE
TDI Golf 4
And some toys.
03-12-09, 03:32 PM
Member
Biggles, I found when offroading the auxilliary fan was coming on the whole time and in very hot seriously heavy going it just didn't ever switch off. Had the radiators flushed first and that made a huge improvement, but alas not a total cure. Still found the heat gauge hovering in an unhappy zone at times.
I then fitted two 10" fans that I got from our local Autozone (realise I stay in the countryside and used what was available). I chose not to have it come on with the auxilliary electric fan, but rather fitted them with a manual switch through a relay.
Works wonderful for serious heavy offroad work in our very hot climate.
However, Iwouldn't totally replace the fan with an electric unit.
__________________
“Let us in life rather regret the things we didn't do than the things we did....!!!"
André
'98 Jeep Cherokee 4lit Auto - (playing and daily drive) "Boerbok"!
'04 Ford Ranger D/C 4lit Auto - (camping & touring) "Gloria" (the Hippo in 'Madagascar')
03-12-09, 04:00 PM
Member
I have been using the midas autozone fans for 4 years no problems
look at this place hot4cold
http://www.hot4cold.co.za
__________________
Keep the rubber side down
03-12-09, 07:39 PM
Member
Midas smallest is 25cm and more than 5cm deep
The search continues...
__________________
03-12-09, 08:04 PM
Member
Biggles, 25cm is 10" - and I'm sure those are the ones I fitted to my XJ a few years ago. They can fit. I'll see if I can take some photo's over the weekend and post it. Unfortunately I didn't take pics when it was dismantled, aned my spotlight wires now go through the grill.
__________________
André
03-12-09, 08:07 PM
Member
Biggels.
The smallest you can go is a 8" fan(20cm).
Look in the "Speed & Sound" mag.
There are places that adverise 8" fans.
Also have a loo at places that sells VW Beetle spares.
They ussually sell fans for the oil coolers that are about 8" diameter.
__________________
For Adam.
Rest in Peace kid.
To Motorists: Save a Cyclist, stay out of the Yellow Lane
03-12-09, 09:12 PM
Member
Look at installing an oil cooler as a lot of heat dissipation is through the oil
__________________
 Learn from other people's mistakes, life's too short to make them all yourself.
95 3l lwb Pajero, OME, roof rack, spots, Hi lift points
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
