logo
Go Back   SA 4x4 Community Forum - The only forum for the offroad and 4x4 enthusiast > General Category > Vehicle & Technical Chat > Nissan
4x4Community
Notices
Nissan SHIFT_freedom
Reply
Thread Tools Display Modes
  #1
Old 03-12-09, 01:22 PM
HIGHFLYER's Avatar
HIGHFLYER HIGHFLYER is offline
Member
Default Flushing of radiator in sani with the vg 30 engine
Can the fundis out there give me a hand as to what exact steps to take when I flush the radiator please.
I have already aquired the coolant and questions like the following arise:
After flushing do I first add the coolant and if so +- how much
Do I let the engine run when I do this
After filling the radiator with water do I still add water to the plastic bottle etc
Please help and thanx
__________________
" IF THE GIANT BEASTS ARE GONE, MAN WILL SURELY DIE FROM A GREAT LONLINESS OF SPIRIT "
1996 3.0L SANI "EXECUTIVE" S/W
CAMIL SUSPENSION
3O/9.5/15 BF GOODRICH A/T
WILCAT BRANCHES
REAR SUPER LEAF-SPRINGS
PORTABLE NL DUAL-BATTERY POWER PACK
  #2
Old 03-12-09, 02:00 PM
Henris's Avatar
Henris Henris is offline
SIR
You need a mix that will give you a -20degC protection. The stronger you make the mix, the colder temp it can handle, but also the less heat it will transfer.
In Musina I run a 30% coolant mix.
__________________
GX LC80 D/C 1HD-FTE
TDI Golf 4
And some toys.
  #3
Old 03-12-09, 02:07 PM
HIGHFLYER's Avatar
Member
Red face
Dankie Henris
Eintlik moet jy dan weet hoeveel vloeistof jou hele sisteem bevat en dan daarvolgens die persentasie uitwerk. Ek sien die gegewens is in die handboek
Wat van die ander vrae wat ek het seblief
__________________
CAMIL SUSPENSION
WILCAT BRANCHES
  #4
Old 03-12-09, 02:13 PM
4ePajero
Guest
Posts: n/a
Dit "Izzy" so moeilik nie.
Dreineer die stelsel (onthou om die kajuit-verwarmer op "hel" te sit, sodat hy ook dreineer).
Volg die "flush" bottel se aanwysings, indien jy dit gaan gebruik.
So nie vul met water, laat lekker warm word en dreineer weer.
Vul die stelsel met 30-70% verkoel-vloeistof (min is 30%, 50% is die norm).
Kontroleer die vlakke vir die volgende paar dae.
  #5
Old 05-12-09, 12:57 PM
HIGHFLYER's Avatar
Member
[QU
OTE=4ePajero;393207]Dit "Izzy" so moeilik nie.
Kontroleer die vlakke vir die volgende paar dae.[/QUOTE]
As dit vir my net altyd so "easy" was. Baie dankie ek maak dan so
Groetnis
__________________
CAMIL SUSPENSION
WILCAT BRANCHES
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Part catalogs & other useful info charlatan Jeep 38 31-08-10 03:10 PM
Grand Cherokee Error code Nick47 Jeep 4 30-08-10 01:28 PM
Petrol of Diesel johandewaal Toyota 34 14-04-09 01:00 AM
How to service your vehicle yourself. Koebelwagen Vehicle & Technical Chat 17 19-01-09 07:11 PM
Advantage of a Diesel vehicle? Krimpie Mitsubishi 49 27-02-07 09:30 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
ABMM Powered by Syrian Medical Society
Template-Modifications by TMS
