logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Ford & Mazda
4x4Community
Ford & Mazda Combined forum for Ford and Mazda
Reply
Thread Tools Display Modes
  #1
Old 21-10-09, 10:54 AM
Wimpy Hightop Wimpy Hightop is offline
Member
Default What's the best oil for my engine?
My old Series II Landy has a Ford Cortina V6 3L petrol engine, which runs beautifully.
I've been mostly using "Super" that you get from most petrol garages (I think this is a 20W50 grade), but I'm not sure if this is correct for my vehicle.
I have noticed that when the car is still cold the oil pressure is often pretty high - but I think this is cus of the high viscosity of the cold oil
Should I rather be using "multigrade" or a less viscous oil (I think this is maybe a 10w40... I don't a hell of alot to be honest).
Thanks!
__________________
2008 Defender Puma 2.4
1963 Series IIA
  #2
Old 21-10-09, 11:11 AM
Mister4 Mister4 is offline
Member
Thanks!
The Ford Essex V6 is an old generation engine therefor it should not be run with oil lower than 20W50 viscosity which is a multigrade.
10w40 and 15w40 is for new generation multivalve engines with have tighter/smaller clearances. Do not use it in the V6.
  #3
Old 21-10-09, 11:17 AM
Damdan's Avatar
Damdan Damdan is offline
Member
And if I may add, DONT buy the cheapest no-name brands.
Buy the best oil your budget allows and change every 10000km because sludge is a killer.
Nothing wrong with Castrol GTX in the V6.
  #4
Old 21-10-09, 11:19 AM
Member
Thanks for the advice!
Does it matter whether I use "super" or "multigrade" from the garage? and I guess you shouldn't mix them, so if I need to switch will I need try drain the oil first?
__________________
1963 Series IIA
  #5
Old 21-10-09, 11:22 AM
4ePikanini
Guest
Posts: n/a
your engine should have a high pressure bypass so don't worry about the pressure.
I have found Caltex Delo 400 to be a fantastic oil in both my petrol engines ( Mitsu V6 3.0 & VW 1.8 )
Both my engines don't use any oil or make any lifter noise from the hydraulic lifters/VLA's
If you search around you will find very heated debates about the quality of Caltex delo 400. The general consensus is that it is a very good oil in both petrol and diesel cars.
  #6
Old 21-10-09, 11:23 AM
Damdan's Avatar
Member
Stick to multigrade = 20w50.
Dont mix brands.
Change oil filter with every oil change.
Dont take shortcuts with an old engine.
If you cant afford Delo 400 there is always Delo Gold.
On a tight budget I would stick to GTX in the V6.
Nothing less.
  #7
Old 21-10-09, 11:25 AM
Member
If you mean by Super that it is a 30 or 40 mono grade then yes to both your questions
Reply
Tags
ford , land rover , multigrade , oil , oil pressure
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Part catalogs & other useful info charlatan Jeep 88 02-12-15 12:11 PM
How to service your vehicle yourself. Koebelwagen Vehicle & Technical Chat - General 20 26-03-15 11:43 AM
Advantage of a Diesel vehicle? Krimpie Mitsubishi 54 26-12-14 12:05 PM
Grand Cherokee Error code Nick47 Jeep 4 30-08-10 01:28 PM
Prolong henlo Jeep 15 06-06-07 11:59 AM
Template-Modifications by TMS
