logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Land Rover
4x4Community
Land Rover Go Beyond! The best 4x4xfar!
Reply
Thread Tools Display Modes
  #1
Old 13-08-09, 12:14 PM
Landyman's Avatar
Landyman Landyman is offline
Member
Default V8 electric fan mod
Can anybody please give me some advice on how to go about replacing the original fan with an electric unit. is it worth it, ito increase in power and what does it cost?
Nico
__________________
Nico
LR Defender Puma '09 (ninety)
Mitsubishi Pajero Sport '09
  #2
Old 13-08-09, 01:22 PM
Riceburner's Avatar
Riceburner Riceburner is offline
RIP: 20Sep1969-08Dec2011
Yu should have 2 electric fans on the outside as factory fitment. Mine has.
__________________
D2 V8. Pro Comp MX6 Shocks with Mikem Custom Progressive Coils. Wildcat Headers. 265/75/16 Hankook RT03's. FLI Audio. Kaiser Locker.
  #3
Old 13-08-09, 02:33 PM
Beans
Guest
Posts: n/a
The ones on the outside is for the air con. Yes you can fit two electric fans. Measure the radiator and fit the biggest fans you can get hold of. You need to fit a fan switch in the radiator on radiator hose. I used a combi 2.1 fan switch. If you search the forum it has been discussed before
  #4
Old 14-08-09, 06:05 AM
Riceburner's Avatar
How do you get the electric fans to work on a switch besides only for the aircon?
__________________
  #5
Old 14-08-09, 07:33 AM
Swanny's Avatar
Swanny Swanny is offline
Member
My 2 electric fans come on to when the transmission oil gets to hot or when the motor is running hot even when the aircon is not on. There is a switch on the thermostat housing for water temp and there is a switch on the transmission line near the bottom of the radiator on the passenger side of the vehicle.
__________________
Eric
2012 Range Rover Evoque
2009 Defender SVX 60th Limited
1997 Discovery V8 ES (Sold)
2009 Freelander 2 TD4 (Sold)
2012 Spite Tourer SP
2010 Jugens XT140 (Sold)
2008 Jugens Xplorer (Sold)
  #6
Old 14-08-09, 11:34 AM
Christob Christob is offline
Member
Go onto the nissan forum and check out Pierre aka freakazoid's mod to a Nissan Patrol. Works well and some good ideas in there.
__________________
Ford Ranger
Double cab
2.2
Stock standard (for now)
  #7
Old 16-08-09, 09:39 AM
jelo jelo is offline
Member
The general process is quite simple: you need a thermo switch, a nut that matches the switch, a short length of steel tube with the same outside diameter as the inside diameter of the water hose, a fan or 2, some hi-amperage automotive wire, some fuses and fuse holders.
You get the nut welded to an appropriate position on the steel tube. You'll need to make sure there is a large enough hole on/in the tube behind the nut so that coolant reaches the thermo switch (had mine welded and hole cut at a exhaust firm where I got the S/S pipe section: cost R50 for labour). Cut the water hose (I prefer the hose that is bringing coolant from the engine, some say use the return hose), and install the steel tube with good quality clamps (I use irrigation clamps, those jubilee clamps don't work for me).
You then either wire the fans up to an "accessory" power supply, or if you're lazy, straight off the battery: positive --> fuse --> switch terminal A --> switch terminal B --> fan --> earth. Be careful putting this straight onto the harness, as current draw could be high depending on the fan rating.
Easy to disconnect for river crossings: just pull the fuse.
So as soon as the thermo switch closes, there is power to the fans. Yes, this way the fan will run after the ignition is off, but having run this system on a Nissan Sani V6 for almost a year, I never saw the fan run for more than 1 minute after the engine was switched off (even after a 160 kph run from Rustenburg to Pta on the new N4).
Biggest challenges:
- fan/s and their sizes
- fan cowling/s
I ran a large diameter single fan. Some guys run dual small diam fans. The large diam fan has one advantage: standard fan cowling can be used with mods. Dual fans require some fabrication of cowlings to make sure that there is proper airflow. In my case, I used HD zipties to connect the fan to the stock cowling.
Benefits: 5-10kW power saving, 10% fuel saving, less noise when active than a visco, cheaper to replace, easier to deactivate for water crossing.
Negatives: some say electrical fan/s don't flow enough air at speed or under heavy load (deep sand, heavy towing).
But I know racing vehicles that don't even run fans for hi speed driving, relying on standard air flow over the radiator core. If your engine overheats at speed, it's probably running lean or you have some other problem like ignition advance timing.
The other issues are possible: that's why I must say that I never tested my system under heavy 4x4 conditions.
  #8
Old 05-09-09, 03:04 PM
Landyluvver's Avatar
Landyluvver Landyluvver is offline
Member
the most successful fan conversion is the 2 speed fan unit from a BMW 735 or 740 or 535. you could also fit a Kenlowe fan unit designed for the landrover. these may have to be imported from the UK but I'm sure there are some local guys that have stock
the BMW fans are extremely powerful and the 2 speed thermoswitch kicks in at 2 different temp settings. speaking under correction but the first around 88 and the next at around 93. this means that normally with town driving, the 1st speed only will run while when pushing the engine eg offroad driving, the second speed will kick in.
__________________
0833006099
  #9
Old 06-09-09, 07:04 PM
Beans
Guest
Posts: n/a
You can also use a 2.1 kombi fan which is also 2 speed
I used the normal midas fan on my disco 1 3.9 i used two fans and never had any problems in the sand dunes or mountain passes or even towing. I ran mine without a cowling.
  #10
Old 29-10-09, 01:36 PM
Hennie's Avatar
Hennie Hennie is offline
Member
Will this be the same for a disco 2 v8?
__________________
[/SIGPIC]Disco 3 TDV6 HSE
Bmw GS 1200
Vito 115
Rotary's
  #11
Old 29-10-09, 02:21 PM
Bostokkelos's Avatar
Bostokkelos Bostokkelos is offline
Member
Ek het op die ford n Alfa switch gebruik, hy skop in op so 65 gradeC
__________________
Supporter of Anti Rhino Poaching
4x4AG: 013
Week: Volvo S60 T6 AWD 3.0L 6 Cyl Twin Turbo soon to be Polestar.
Weekend: Pajero Sport 3.2 DiD GLS Auto
Bash plate,G Box Plate,Roof Rack,LR Tank,Snorkel,50 mm lift,Rock sliders,Dual Battery and three child seats...
  #12
Old 07-11-09, 08:05 PM
lunnmj lunnmj is offline
Member
Question
Did you guys really notice any improvement in power and fuel consumption with removing the original fan ?
  #13
Old 07-11-09, 09:17 PM
Henris's Avatar
Henris Henris is offline
Commercial Member
Did this mod on my LC. 2 x RunX fans and it works a treat. Fitted the thermal switch into a piece of s/steel tubing as well. The only thing I did different is that I fitted a 2 way switch into my line, so now I have a 3 way selection.
1. Auto - The thermal switch controls the fans on at 85degC and off at 80degC
2. Off - I did this so that when I go through water, the fans are off.
3. On - This is to force them on. Use this with the aircon.
PS. Make sure that you build a proper cowling. This is VERY VERY important.
__________________
Let me be your link to anything property related. Buying, selling renting or letting.
I would love to make sure you are taken care of, the way you are supposed to be cared for.
Anywhere in the country.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Part catalogs & other useful info charlatan Jeep 88 02-12-15 12:11 PM
Cherokee Testing the electric fan Country Jeeper Jeep 4 02-05-09 12:24 PM
Electric fan on Disco II V8 philippus Land Rover 6 17-01-09 07:37 PM
converting to electric fan Roan Ford & Mazda 4 11-03-08 05:40 PM
8" Electric Radiator Fan benhur Vehicle & Technical Chat - General 13 18-12-06 12:37 PM
Template-Modifications by TMS
