logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Mitsubishi
4x4Community
Mitsubishi Spirited cars for spirited people!
Reply
Thread Tools Display Modes
  #1
Old 18-03-09, 10:45 AM
Jcw Jcw is offline
Member
Default Smoking Pajero
What is normal smoking for a diesel? I Can see at night when a car drives behind me that under acceleration there some smoke coming out. During the day I cant see that much smoke. ON idle there is almost no sign of smoking just a light "stream" of smoke at the exhuast. Its a grey/white smoke. The car doesnt use oil or water. Oil level is a bit above Full. Air filter replaced on monday. Injector tips were replaced last year Sept.
  #2
Old 18-03-09, 11:30 AM
Navigator's Avatar
Navigator Navigator is offline
Commercial Member
Sounds normal for a oil burner.
__________________
SUSPENSION FOR THE FUTURE
www.amadaxtreme.co.za
Diamond Park nr2, 86 Jakaranda Str, Hennopspark, Centurion
S2551'50.2 E2809'58.2
Cobus Bohmer - 071 641 7947
cobus@amadaxtreme.co.za
Rudi Grobbelaar - 061 609 7312
rudi@amadaxtreme.co.za
  #3
Old 18-03-09, 12:06 PM
Jcw Jcw is offline
Member
Is there someone in PTA east with a 2.8 PAjero that I can check if the smoke is the same?
  #4
Old 18-03-09, 12:18 PM
Botswana's Avatar
Botswana Botswana is offline
Member
This is quite a debatable subject and is open to many different different interpretations.
There are noticable differences between direct and indirect injection diesel engines with the direct injection engines normally being the cleaner burning of the two genres.
During normal combustion diesel engines form soot and carbon particles which gets exhausted from the exhaust during normal operation.
Smoking becomes more visible at night purely due to the amount and spectrum of visible light available (vehicle headlights, street lights etc). Some haze is perfectly normal and does not neccesseraly indicate a problem.
A well tuned diesel engine in good condition will show limited amounts of smoking during normal operation, throughout the rev range when not under load (such as when being revved up in neutral). Once "on boost" when placed under some form of load the smoking should be minimal, preferably not noticeable at all. When placed under high torque demands some grey smoke may become visible.
White smoke can indicate unburnt fuel and / or combusted oil. Some smoking (white or grey) is acceptable during start-up and some period thereafter until the engine's combustion chambers have heated up sufficiently.
Grey smoke is normally an indication of incomplete combustion and some measure thereof is totally acceptable during hard acceleration.
Black smoke is a sign of overfuelling and is undesireable.
White / grey smoke during acceleration after a period of decelleration can indicate, as with a petrol engine, worn valve stem seals. White / grey smoke during hard acceleration can indicate worn rings.
Excessive smoking can be caused by dirty air cleaners (grey to black), worn injectors (white, grey or black), low boost (black), poor engine condition (white, grey or black) or incorrect engine timing.
Rule of thumb - None, or at the most, a very light amount of sooting on the rear of the vehicle after a long trip or some hard driving is acceptable. Heavier deposits may serve as indication of one of the elements mentioned above being out of kilter and might need some attention.
  #5
Old 18-03-09, 01:15 PM
Jcw Jcw is offline
Member
Thanks Botswana. Dont think I have a issue then. Will take it to girlfriends dad over the weekend just to make sure
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Smoking Pajero Daneel Mitsubishi 3 10-09-10 01:56 PM
Smoking Pajero Daneel Mitsubishi 11 24-01-10 12:57 PM
Jerking and smoking Pajero Jcw Mitsubishi 5 15-09-08 10:33 AM
Smoking Pajero JMoulder Mitsubishi 22 05-07-07 09:47 AM
New Pajero Gerrit Loubser Mitsubishi 28 04-11-06 03:40 PM
Template-Modifications by TMS
