logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Toyota
4x4Community
Toyota Lead the way!
Reply
Thread Tools Display Modes
  #1
Old 24-02-09, 10:14 AM
Remo's Avatar
Remo Remo is offline
Member
Default Long range tank for '08 Hilux D4dD?
Hi Guys
I'm looking at having a long range tank installed on my Hilux. The one I was looking at is the Frontrunner 70L tank. Apparently the filler cap gets connected to the LR tank and then the LR tank gets connected to the main tank. Is there anything to look out for in terms of installation method, fuel guage issues etc. How does the EXCEL tank compare. Or is it much of a muchness? There was a thread the other day where someone mentioned that it took them about 30min to fill the tank(s) due to the pipe being too small or something like that. I would like to avoid any complications in this regard, so any comments from those who have done this will be much appreciated.
Remo
__________________
'08 Toyota Hilux 2.5 D4D SRX D/C
African Outback Canopy
Long range tank
NL Battery Pack
  #2
Old 24-02-09, 10:28 AM
Kesheshe's Avatar
Kesheshe Kesheshe is offline
Member
i can only provide information related to frontrunner which i had fitted to hilux 5 years ago. i have 145l extra tank and touch wood i have not had one day of trouble with this brand. Regarding the time to refuel i have had situations where loading both tanks takes a while but in my experience it is all about getting the right setting on the petrol pump and not getting the attendant to have it on manual. When set correctly it takes about 10-15 mins to fill both tanks from empty in the region of 240l.
I do however believe that if i was to fit this again i may consider having the filling points seperate.
__________________
If you haven't fixed it with duct tape you haven't used enough!
Vehicle details: OME suspension kit 400kg, long rank tank 150lt, 70lt water tank, drawer system, duel battery, snorkel, roof top tent, roof rack, fitting air compressor, double spare wheel carrier, sand tracks, NL 70lt
  #3
Old 24-02-09, 03:49 PM
Dif's Avatar
Dif Dif is offline
Commercial Member: Solareff
Frontrunner 65l on 1998 D/C Hilux SFA - Filling time 30 minutes
Exel 42l on Fortuner - Fills with less airlock than before fitment of tank!
As previously said, I know Northern Offroad (manufacturers of Exel) well. They kitted all my equipment on my Fortuner and I'm still smiling.
__________________
Solareff - Solar PV Specialists
www.solareff.co.za
info@solareff.co.za
011 675 1114
  #4
Old 24-02-09, 04:35 PM
Veldrot Veldrot is offline
Member
Hi
I fitted the frontrunner tank to my 06 hilux 4.0 petrol and have no hassles at all. It fills from the one filler only (my old 89 hilux had two filler caps) and must say I prefer the one filler as it is easier with less hassles. Filling time is normal with no airlocks or anything experienced. Had it filled to the brim on a few occasions now during extended trips through Moz and Bots. Must say it feels good to travel around 500km's before your fuel needle starts to move downwards!
  #5
Old 25-02-09, 10:19 PM
Remo's Avatar
Member
Hi Veldrot
I guess your setup would be the same as what I am looking at getting and if you don't have any problems with it, that's just the answer I was looking for. Yours is also a gravity feed system, I assume. I think the air lock situation probably occurs more when you have the two tanks seperate and linked by means of a fuel pump rather than with a gravity feed system where you have the two tanks linked by tubing. Anyway, thanks for all your replies sofar.
Remo
__________________
Long range tank
NL Battery Pack
  #6
Old 26-02-09, 06:50 AM
Pype's Avatar
Pype Pype is offline
Member
Remo I also had a look at the Frontrunner and EXCEL tanks not sure what they price now but was around 4k fitted when I wanted to fit one. I eventually had one custom made 160 liters so I can carry 200 liters of diesel now. The cost was 2k fitted (Keep in mind I do not carry my spar wheel under my bakkie anymore it is on the back bumper) the tank is made out of stainlisteel an so far no hassles filling up is a breeze no problem
__________________
To see what a Hilux can do click link below
https://www.youtube.com/watch?v=0m_cUKPjRAU
  #7
Old 28-02-09, 08:47 AM
Mr Difflock's Avatar
Mr Difflock Mr Difflock is offline
Member
You can have a 140 Liter replacement fuel tank from Long Ranger Australia
http://thelongranger.com.au/hiluxlongrangefueltank.html
I have the 72L fuel tank fitted on my Fortuner from 4x4 Megaworld. It works through gravity feed and has only one filler. Filling the OE tank starts after the aux tank is filled, and I have to slow down the pump significantly to avoid air lock. The tank is starting to build up some corrosion on the outside, unfortunately, although it is supposed to be stainless steel. After having experienced the gravity feed tank, I would recommend tanks with pumps, for two reasons:
1. Fitting a pump-based tank is much easier and simpler, no need to modify the main tank
2. With gravity-fed tanks, when you're parked at an upwards angle and the car tanks are half-full, the fuel from the main tank pours back into the aux tank and the guage will indicate an empty tank.
__________________
Toyota Fortuner 4x4 4L V6 A/T LHD
Mods: Front airlocker, ARB Bullbar, OME suspension, auxiliary battery, 72L auxiliary fuel tank, Safari Snorkel
  #8
Old 09-03-09, 06:44 PM
Dunesand Dunesand is offline
Member
Default Gerbers
Any experience with the units made by Gerbers, apparently a 85l with little spare wheel drop.
Looking forward to any advise/opinion.
  #9
Old 10-03-09, 10:02 PM
Remo's Avatar
Member
Hi
Finally decided to go for the 70L Frontrunner tank. Had it installed last week and I'm pretty happy so far. It fills up without any air lock in no time and there is minimal spare wheel drop. One just needs to get used to the extra weight of a full tank at the rear of the vehicle, it becomes a bit bouncy. But after 300 km's or so, when the weight is reduced, its ok. I guess a suspension mod is next on the list
Remo
__________________
Long range tank
NL Battery Pack
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Where to fix leak on long range tank? chicken noodle General (non vehicle/technical) 4x4 Discussions 4 10-03-11 04:30 PM
Long range tank for Sani Safaridude Nissan 4 09-02-11 09:56 PM
Ford Ranger 3.0XLT Supercab Long Range Fuel Tank Cruiserboy22 Ford & Mazda 0 03-02-11 05:16 AM
Long Range Fuel Tank Colt 2,8 4WD Jayefe Mitsubishi 2 03-05-09 05:56 PM
Long Range Tanks for Hilux freeflyd Toyota 0 02-10-07 03:57 PM
Template-Modifications by TMS
