logo
Go Back   4x4 Community Forum > General Category > Vehicle & Technical Chat > Volkswagen
4x4Community
Notices
Reply
Thread Tools Display Modes
  #1
Old 08-02-09, 10:34 AM
jbq jbq is offline
Member
Question VW Touareg -
Good day to all ,
new to 4x4 and need your considered opinions.
Would like to buy a Touareg 3.0TDI - found 2.Both, same price, same year with foll differences:
option 1- air suspension ,no tow bar , nav system
option 2- standard suspension,tow bar
Am concerned about air suspension when maintenance plan runs out. Also already have a Garmin hence nav system not really an extra for me.
which do you think is the better option knowing that do not intended to do heavy travelling (i.e. in to deep Africa) thinking on Namibia,Botswana,Zim(when they right themselves),Mocambique,Lesotho.
Thank you
José
  #2
Old 08-02-09, 10:53 AM
Dirk's Avatar
Dirk Dirk is offline
Administrator
Do a search for Touareg on the forum, there's been some issues recently with water and air intakes, and repair bills of R400k+.
__________________
2008 Toyota Fortuner, 3.0 D4D....for now
  #3
Old 08-02-09, 10:55 AM
Henris's Avatar
Henris Henris is offline
SIR
Maybe you should reconsider. The Toureg's wading depth is a bit low. Lots of electronics that can give you a headache, should it get wet. Nobody, north of the Limpopo that can help you should you need help. Personally I am a LC fan. Can get a nice LC for the same money.
__________________
GX LC80 D/C 1HD-FTE(Manual injector pump)
1998 Hilux 4x4. (Long term D4D project)
  #4
Old 08-02-09, 11:10 AM
4ePajero
Guest
Posts: n/a
Angry
Please keep this on-topic.
  • He did NOT ask for opinions on his choice of vehicle (a Touareg)
  • He did ask on opinions on the choice between two examples
  • He did NOT ask for suggestions about alternative vehicles (why is that always a LC? )
  #5
Old 08-02-09, 12:15 PM
Vossie's Avatar
Vossie Vossie is offline
Member
Default VW Touareg
Hi Josè,
Your decision should rather be based on your personal requirements, more than anything else. If you are going to tow something on you trips, you obviously need a tow bar. An aftermarket fitment is on the expensive side but it is recommended that you have it done by a VW dealer as the electric wiring has to be integrated into the ESP system. The air suspension has some great advantages, not only off-road but on the road as well. The 300mm ground clearance of the air suspension allows you to go where others need to think twice. On the standard suspension the wading depth is 500mm and 580mm with air suspension. If you stay within these limits, you have nothing to fear. It is always a risk to take a technologically advanced vehicle like this into Africa, but by taking the right precautions in advance, you can make sure it does not turn into a nightmare if you break down. Anyway, all cars can break down. I traveled across Africa (from PTA to Beira to Swakopmund and back) in a R5 with ease and a lot more comfort that the other seven vehicles in the convoy with no serious technical hitches.
Best of luck with your choice!
  #6
Old 08-02-09, 06:08 PM
ADUP's Avatar
ADUP ADUP is offline
Member
Quote:
In other words only overlanding..........there is i.m.h.o. enough groundclearance with the standard suspension and if the Tiguan can do Sani an Mabalingwe, then the Touareg is more than capable with standard suspension to do overlanding. If your family requires more packing space then the towbar will come in handy. Whatever the vehicle, know it's capabilities and restrictions as facts and stay within the limits.
Enjoy.....
__________________
Andre ZR6AGA
2009 VW Tiguan 1.4 TSI Field & Track
  #7
Old 08-02-09, 08:26 PM
jbq jbq is offline
Member
Wish to thank everyone for their input.
  #8
Old 09-02-09, 08:50 AM
Quattro Quattro is offline
Member
Go for the air suspension version to give you the extra height/clearance when needed. Aftermarket towbars are available locally at sensible prices and can be fitted by places like LA Sport and 4x4 Megaworld who will sort out the potential wiring problems. As far as iIknow the air suspension is not generally a problem animal. Mine is ok after 57000km.
__________________
Quattro
2005 Touareg V10
2006 BMW M5
1996 Disco 1, 4.6l, R. Rover transfer case,ARB lockers front and rear, etc etc
2005 Oryx
2007 Noble Ferrari P4 replica
2013 High Spec TRD Toyota 86
  #9
Old 10-02-09, 09:37 PM
Hennie Jackson's Avatar
Hennie Jackson Hennie Jackson is offline
Member
If looking at Bots. you can't go wrong with air suspension. My 2.5Tdi has 190k km on and it (air susp.) is still fine
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
I bought myself a Touareg TDI R5 Romzotwa Volkswagen 12 12-10-11 09:13 PM
Buying a VW Touareg Need Advice Please MKnuvo Volkswagen 35 06-03-11 10:59 AM
Touareg popularity? scandalon Volkswagen 6 29-11-09 08:23 PM
Drowned Touareg search WEBlife Volkswagen 125 07-02-09 06:34 PM
VW Touareg 4ePajero Volkswagen 3 01-05-08 12:18 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Template-Modifications by TMS
