logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Hyundai
4x4Community
Reply
Thread Tools Display Modes
  #1
Old 14-12-08, 11:50 PM
Barto's Avatar
Barto Barto is offline
Moderator (aka Zantus)
Default Hyundai Problems!
This thread serves at a database of all problems experienced by Hyundai owners. This will give potential buyers or owners of this specific make a database they can go through to see what problems their vehicle could possibly develop.
To ensure this thread contains only information related to vehicle problems and to keep it easy to read and understand, there are a few very specific rules:
-Copy the list below in bold into your thread and only provide the information asked for, no more, no less.
-One list per problem. More than one problem can be posted in the same post, but use seperate lists.
-No discussions will be allowed in this thread. If you want to discuss a specific problem, contact the poster directly or start a new thread in the relevant section. Copy the post across to the new thread if need be.
-ANY comments, or posts not conforming to the list below, will be deleted.
-Only post problems you personally experienced, please no friends' stories or hearsay's.
Please help to keep this neat and factual.
Thanks!
Model:
Year:
Mileage:
Problem:
Cause of problem(if known):
Specifics of repair work carried out:
Cost of repair:
Who did the repair:
Vehicle under warranty, Y/N:
Was damage covered by warranty:
  #2
Old 20-01-09, 03:11 PM
Biggles246
Guest
Posts: n/a
Model: Terrecan 3.5 V6
Year:2004
Mileage:75000
Problem:4x4 not engaging
Cause of problem(if known):Vacuum pipes/"sirclip" on 4x4 selector underneath the vehicle
Specifics of repair work carried out:replaced vacuum pipes/fitted bolt to selector/drained and replaced AT and Diff oil. Only use specific limited slip diff oil. Others damage the diff.
Cost of repair: +-R500
Who did the repair:Hyundai Bryanston
Was damage covered by warranty: N/A
  #3
Old 26-01-09, 06:17 PM
Ingwelala's Avatar
Ingwelala Ingwelala is offline
Member
Model: CRDi Auto
Year: 2006
Mileage: 50000
Problem: Diff whine
Cause of problem(if known): Apparently was common in a certain batch.
Specifics of repair work carried out: Diff replaced (eventually)
Cost of repair: Nil
Who did the repair: Hyundai Cresta
Vehicle under warranty, Y/N: Y
Was damage covered by warranty: Y
__________________
Kevin Smith:
Hyundai Terracan 2.9CRDi, TJM Lift Kit, Big Country bash plates, drawer system and load platform. ZS6KVN
  #4
Old 05-03-09, 03:21 PM
regmark's Avatar
regmark regmark is offline
Member
Model: Sante fe - crdi 2.2 auto 4x4
Year: 2008
Mileage: 9000
Problem: when accelerating hard it goes through the gears but sometimes when changing from 4 to 5 automatically - there is a shudder at the wheels, then a puff of white smoke and then no acceleration from the pedal as if the engine has cut out and after about 10 seconds all comes back and away you go.
Also: the 4x4 light does it work off the switch per say of does the dash light only come on when the clutch is engaged.
Also: If a cam belt breaks, can the pistons clap and bend valves
Also: Any way of raising the suspension by +/- 20 MM to around 220mm.
markides.rs@ufetcollege.co.za
Cost of repair:
Who did the repair:
Vehicle under warranty, Y/N: Yes
  #5
Old 06-03-09, 07:40 AM
Oupoot's Avatar
Oupoot Oupoot is offline
Member
Model: Terracan 2.9 CRDi
Year: 2004
Mileage: 133000
Problem: Just dies, eventually found no diesel flows theough to the commonrail.
Cause of problem(if known): Diesel pump seized - suction valve to be specific.
Specifics of repair work carried out: Valve replaced, pump refurbished
Cost of repair: R11000
Who did the repair: Stripping: Motoworx Randburg, Refurbishing: M&G Advanced Fuel Injection
Was damage covered by warranty: n/a
__________________
Werk nog om te oorleef maar leef om te kamp ...
'15(16) Ford Ranger 2.2 XL Plus (extras to follow)
'12 Summit Everest
'10 Fortuner 3.0 D4D 4x4 (gone )
'09 Terracan 3.5 V6 - liftkit (gone too)
'98 Xplorer ( gone too)
'04 Terracan 2.9 CRDi (gone!)
  #6
Old 27-04-09, 04:10 PM
Skilpad Skilpad is offline
Member
Default Replace Flywheel and clutch
Model: 2.9 CRDi
Year: 2004
Mileage: 110 000
Problem: Replacement of Flywheel
Cause of problem(if known): Previous owner towed a large heave caravan at high speeds.
Specifics of repair work carried out: Replace clutch and flywheel
Cost of repair: R 11 000. Could not find the parts in Gauteng. Was sourced in Durban after three days.
Who did the repair: BJ Auto Clinic in Benoni
Was damage covered by warranty: Only partually.
  #7
Old 02-10-09, 12:24 PM
D-tomcat
Guest
Posts: n/a
Model: Tucson CRDI
Year: 2005
Mileage: 80000
Problem: defekt diesel-injectors
Specifics of repair work carried out: replace injectors
Cost of repair: each time between R2.5 - 5000
Who did the repair: GC Diesel Port Elizabeth
Vehicle under warranty, Y/N: 1st yes, 2 others no
Was damage covered by warranty: 1st, 2nd no, 3rd within guarantee but not accepted because it "could" be bad fuel
  #8
Old 06-10-09, 08:48 PM
Bialetti's Avatar
Bialetti Bialetti is offline
Member
Model: 2.9 CRDi
Year: 2004
Mileage: 150 000
Problem: Sheared Steering Pivot arm (pittman arm support)
Cause of problem(if known): Corrugated roads
Specifics of repair work carried out: Replaced unit
Cost of repair: R1500 plus R3300 flat bed recovery
Who did the repair: Hyundai Uppington
Was damage covered by warranty: no
__________________
Greg Hudson
2009 Prado 4.0 Petrol
2013 Bush Lapa Boskriek B133
  #9
Old 25-04-10, 08:20 PM
offroad junky's Avatar
offroad junky offroad junky is offline
Member
Model: 3.5 V6 Auto Terracan
Year: 2004
Mileage: 130 400km
Problem: EXCESIVE fuel consumption
Cause of problem(if known): Extra fueling values in ECU and loose fuel tank gauge cap.
Specifics of repair work carried out: Chipped and deleted a lot of the extra fuelling values and fitted S/S freeflow exhuast and I took the fuel tank gauge of and refitted everything properly.
Cost of repair: R5400 for chip & exhaust and nil for fuel tank.
Who did the repair: Steve's Auto Clinic PE
__________________
Offroad junky
'14 Citroen DS4 2.0 HDI platkar
'12 Disco 4 SDV6 SE - Beauty
'06 Disco 3 TDV6 S (De-cat, EGR blanked, remap, Johnson rods suspension rods, 285/65-R17 Kuhmo KL61) - Beast
Previously;
'04 Terracan 3.5 V6
'96 Ssang Yong Musso 602 (non turbo manual)
'04 Ford Ranger 2.5 TDI D/C 4x4 with Solid front axle and 33" Maxxis
  #10
Old 18-05-10, 12:32 PM
adolfschoe
Guest
Posts: n/a
Year: 2006
Mileage: 105700km
Problem: Engine failure at 64000km, 1st starter motor at about 80000km, 2nd starter motor at about 105000km
Cause of problem(if known): Engine: Cylinder no 2 totally destroyed due to manifold butterfly braking from axle and fell into cylinder.
Starter motor : Hyundai still trying to figure out why starter motors gave problems. It basically broke from it's brackets destroying bendix and ring gear.
Specifics of repair work carried out: Engine : Hyundai replaced engine under warrantee.
Starter motors :First starter was replaced under warrantee, 2nd one claimed from mechanical insurance which included a new ring gear as well.
Cost of repair: My portion for repairs was nothing for engine and first starter, R4500 for 2nd starter and ring gear.
Who did the repair: Hyundai, Somerset West - must state, their service and backup is out of this world, fantastic !!
Vehicle under warranty, Y/N: Y with engine and first starter problems, N with 2nd starter
Was damage covered by warranty: Y and N
  #11
Old 19-05-10, 07:50 PM
Morton Berg's Avatar
Morton Berg Morton Berg is offline
Member
Model: 3.5V6 Auto Terracan
Year: 2004
Mileage: to date 75000
Problem: Car just died on 4x4 trip
Cause of problem(if known): Mass airflow intake sensor
Specifics of repair work carried out: Simple replacement of unit
Cost of repair: Covered by Hyundai 2x had to fly in from Korea. Flatbed cost R500
Who did the repair: Hyundai Paarden Eiland
__________________
Morton the " BEAST " Berg
3 Skid plates;75mm lift;275/70/16 Maxxis MT's;Merrit 16”rims;Maxe spots+ night breakers on all lights; Solace protection;TJM snorkel;TJM XGS shocks;TJM coils+Bellows; Maniac front & rear steel bumpers;Spare wheel and 3x Jerry can carriers;Rock sliders;Side awning;Front Runner roof rack; Dual batt system;Procool fridge/freezer;2xGarmin;clinometer;Twin free flow exhaust,Fini comp; ARB independent Airlockers F&B; Winch; Drawer Sys;50Lt Water tank;VHF&29Mhz(2)radios; 8x ss Fish road holders; Safety whip&flag.Future mods,Viper V10or Lex V8 Lumina 6lt
  #12
Old 12-06-10, 10:37 PM
atlantic atlantic is offline
Member
Model:2.9 CDRi
Year: 2007
Mileage:61000
Problem: tie rod on right front wheel detatched
Cause of problem(if known):They think the alignment center did not tighten nut
Specifics of repair work carried out: thread stripped and waiting for part to arrive.
Cost of repair: not sure
Who did the repair: Hyundai Tokei
Was damage covered by warranty: not sure
__________________
ATLANTIC
GRAND CHEROKEE 3L V6 DIESEL OVERLANDER
CONQUEROR COMMANDER
  #13
Old 30-07-10, 08:23 PM
witklipbank's Avatar
witklipbank witklipbank is offline
Commercial Member
MODEL:3.5V6
YEAR:2005
Mileage:203000
PROBLEM:Butterfly came loose and fell into cylinder
Cause of problem:Bolts on butterfly came loose.
Specifics on repair work:Remove parts from piston and repair cylinder heads
Cost of repair:R2000
Who did the repair:Myself .
VEHICLE UNDER WARRANTY:NO
__________________
Elize
en ry saam met SarelF in
VW AMAROK MET BLINKGATCAMPER:
My Platkar:- Peugeot 208
Kyk gerus by www.blinkgatproducts.com
Vir enige aluminium produkte,canopy's, campers kontak gerus
Sarel 0828209413
  #14
Old 23-08-10, 09:22 AM
macmac macmac is offline
Member
Model : 2.9 CRDI
Year : 2004
Mileage : 161500
Problem : Brake Master cyclinder replaced
Cause : new pads not fitted correctly by workshop
Specifics : Changed all discs , then seals , and eventually new master cylinder
Cost of repair : R 9800
Who did repair : Pit Auto Meadowdale
Vehicle Under Warranty : No
  #15
Old 15-12-10, 06:28 AM
Festi1 Festi1 is offline
Member
MODEL:3.5V6
YEAR:2005
Mileage:104000
PROBLEM:Screw on Butterfly came loose and fell into cylinder
Cause of problem:Screw on butterfly came loose.
Specifics on repair work:Remove head, replace 2 valves. Luckily no damage to cylinder or heads.
Cost of repair:R5000
Who did the repair:BJ Auto Clinic, Boksburg
  #16
Old 19-12-10, 07:08 PM
Karoolam's Avatar
Karoolam Karoolam is offline
Member
MODEL:2.9CRDi
YEAR:2005
Mileage:128000
PROBLEM: Engine Check Light came on, Vehicle goes "sluk-sluk" as if the diesel filter/system blocks up.
Cause of problem:The watertrap sensor plug underneath the diesel filter let some air into the fuel system.
Specifics on repair work:The rubber seal of the plug was perrished and the thread of the plug was damagded. Some mechanics told me it was faulty injectors, as in SPLAT's case. Until I found the problem myself and replaced it with secondhand part form Hyundai George.
Cost of repair:R 0
Who did the repair: Myself and I
  #17
Old 12-01-11, 12:03 PM
Member
MODEL:3.5 V6 Auto
YEAR:2004
Mileage:154000
PROBLEM: Loss of power on uphill. Excellerator flat on the floor boards and car loosing speed from 120km/h down to 60km/h. Pull over and turn ignition off and back on and problem sorted.
Cause of problem:Stealers' diagnostics copmuter says its the throttle position sensor
Specifics on repair work:Ordered replacement sensor and Hyundia to install and reset.
Cost of repair:R1800-00 for sensor and R232-00 for installation and resetting on CPU.
VEHICLE UNDER WARRANTY; No
__________________
Offroad junky
Previously;
'04 Terracan 3.5 V6
  #18
Old 12-01-11, 12:08 PM
Member
MODEL:3.5 V6 Auto
YEAR:2004
Mileage:154000
PROBLEM: Shudder/vibration coming from the suspension between 80km/h and 120km/h under excelleration or going uphill.
Cause of problem:Unknown. Still trying to determine the source. Had the propshafts checked....they OK. Checked the gearbox mounting....OK. Checked the shocks and had the tyres re-balanced and rotated and problem persists.
Specifics on repair work:Eventually went and bought new spark plugs and replaced. All plugs removed were 12mm TO LONG and 3 plugs were totally destroyed/burned away. Shudder/vibration problem solved. Not even Hyundai could figeur this one out...!
Cost of repair:R185 for 6 plugs.
Who did the repair: Self
__________________
Offroad junky
Previously;
'04 Terracan 3.5 V6
  #19
Old 28-03-11, 08:51 AM
petri.labuschagne's Avatar
petri.labuschagne petri.labuschagne is offline
Member
Model: Terrecan 3.5 V6 Year:2008 Mileage:72000 Problem:4x4 low range not disengaging Cause of problem(if known): Drove through deep water. Low range selector had water ingress and malfunctioned. Specifics of repair work carried out: Replaced selector module as well as diff oils and auto box oil. Cost of repair: +-R12000 Who did the repair:Hyundai Zambezi Vehicle under warranty, Y/N: Y Was damage covered by warranty: N
  #20
Old 13-07-11, 10:58 PM
Dr.Phill Dr.Phill is offline
Member
Model: Terracan 3.5 V6
Year: 2004
Mileage: 120,000
Problem: 4x4 not engaging (front diff)
Cause of problem(if known): Actuator Assembly Pump "faulty"
Cost of repair: R1200 plus labour
Who did the repair: Hycape Hyundai Somerset West
Was damage covered by warranty: I wish
  #21
Old 20-09-11, 10:24 PM
kellyman's Avatar
kellyman kellyman is offline
Member
Model: Santa FE
Year: 2008
Mileage: 105,000
Problem: Loss of power due to rpm dropping below 500rpms.
Cause: Dirty EGR valve
Cost: R1,100 incl labour
Who did the repair: Bosch Strydom park, Randburg
  #22
Old 11-11-11, 12:32 PM
laubscmj laubscmj is offline
Member
Year: 2005
Mileage: 128,600 km
Problem: Reduce speed or loose power and then pick up speed by itself. Used to happen like once a month, then once a week and then many time per day
Cause of problem(if known): Brake switch (confirmed by Hi Scan Pro at Hyundai)
Specifics of repair work carried out: Replaced brake switch
Cost of repair: R145
  #23
Old 03-12-12, 06:32 PM
gotdatshirt gotdatshirt is offline
Member
Model: Hyundai Terracan 2.9 CRDI
Year: 2004
Mileage: 115000
Problem: Engine oil in water and radiator detected
Cause of problem(if known): O Rings on oil cooler defective
Specifics of repair work carried out: Oil cooler removed and o rings replaced
Cost of repair: R1908-00
Who did the repair: BJ Auto Clinic Boksburg
  #24
Old 09-10-13, 05:53 AM
DJ Payne DJ Payne is offline
Member
Year: 2004
Mileage: 235 000km
Problem: Cutting out and loss of power while driving.
Cause of problem(if known): Unconfirmed but was either worn out injectors or fuel lines sucking in air or both.
Specifics of repair work carried out: Replacement of injectors, fuel lines and a few other bits and bobs
Cost of repair: Cost to me, nothing. But total bill came to +/- R36 000.00
Who did the repair: Dealer I bought the vehicle from organised
Vehicle under warranty, Y/N: Aftermarket warranty
Was damage covered by warranty: Partially balance covered by dealer.
__________________
Devin
2009 Volvo XC60 D5 Auto
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Isuzu Problems! Barto Isuzu 36 19-04-16 09:19 AM
Kia Problems! Barto Kia 8 21-03-14 10:18 AM
Conqueror Companion: Dream becomes nightmare Alta Camping, Fridges, Accessories 117 21-10-12 09:54 PM
Discovery 3 CD and Cruise Control problems (incl. bad experience with dealer) ReadySteadyGo Land Rover 8 09-11-11 07:40 AM
Hyundai worst 4X4 service? splat Hyundai 70 01-12-10 06:55 PM
