logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Mitsubishi
4x4Community
Mitsubishi Spirited cars for spirited people!
Reply
Thread Tools Display Modes
  #1
Old 11-09-13, 12:32 PM
Dirtrider24's Avatar
Dirtrider24 Dirtrider24 is offline
Member
Default Pajero 4x4 lights/gearbox advice
Hi guys! I'm always just checking the site for advice and info but today I'm gonna ask some advice.
I know this topic has been chatted about many times but I'd like to know what you guys who has been through this problem think. I'm interested in buying a 2000 Pajero 3.5 auto LWB Gen 3 with 195 000km with full service history and its in great shape. The only thing is the 4x4 selection lights and difflock light that sometimes keep flashing when engaging 4x4 and sometimes don't(works fine) - I'm sure you know what I'm talking about, seems to be a common problem. From what I've read is that it is usually the switches, actuator, vacuum pipes or a combination. I phoned Mitsubishi and they confirmed that 9/10 times its the problem. Considering I can get the Pajero for only R60 000, I'm willing to pay a few thousand to replace the switches and clean the pipes and grease the actuator, but its gonna be a gamble as to what exactly is faulty. I don't want to recon or replace the gearbox or transfer case.
From your experience, is it worth taking a gamble and going through the mission and costs to fix the "smallish" problem to get the car in perfect condition or should I stay away?
  #2
Old 11-09-13, 12:40 PM
KurtG's Avatar
KurtG KurtG is offline
Member
Is there any way you can have the car assessed before you purchase so that you know what the real issue is?
__________________
2014 Pajero 3.2DiD SWB - COLLECTING SOON
2008 Pajero Gen4 3.2DiD LWB - SOLD
2016 Nissan Qashqai 1.2T Acenta
Metalian Maxi
4x4AG 0110
  #3
Old 11-09-13, 01:03 PM
Member
Quote:
Unfortunately not. Its from a wholesaler that supplies dealerships. You see it, you like it, you buy it. Thats why the price is not to bad.
  #4
Old 11-09-13, 05:35 PM
Haydn Haydn is offline
Member
Replace the two switches on the back of the gearbox and the one on the front diff. All in all it will cost you about R1200.
Then replace the two front vacuum switches, under the bonnet, below the air filter. They about R700. Then nothing will go wrong or let you down in that department.
__________________
2002 Colt, 2.8 tdi Rodeo, 4x4, ARB Bull Bar, Excalliber Running Boards, Monroe Gas Magnum Shocks, Cooper AT3's, Excel 53l long range tank, National Luna Dual Battery System, Campmaster 80l Fridge/Freezer Combo, FrontRunner Fridge slide and Bin Slide, Alpha Gte Canopy with FrontRunner Roof Rack and Homemade Awning...[SIGPIC] Pulling a Caravan sometimes
  #5
Old 12-09-13, 08:41 AM
Member
Does anyone know of a good Mitsubishi mechanic in Pretoria? I'd like to speak to someone that has knowledge of this repair because the dealers say I have to change all 6 switches on the transfer case because you dont know which one is faulty and to drop the case and to replace only two and to find out afterwards it wasn't those two and to do the whole job again to replace the others is gonna be costly.
Anyone know a Mitsubishi mechanic in PTA?
  #6
Old 12-09-13, 08:46 AM
pblaauw's Avatar
pblaauw pblaauw is offline
Member
You have a PM
__________________
  #7
Old 12-09-13, 09:50 AM
Member
1. You do not need to drop the transfer case.
2. Its the two switches on the very back at the top of the transfer box, they are difficult to get to, but I have done it plenty of times.
Transfer Switch 4x4 Part number MB811554
Switch Transfer Hi/Low Detection. MB 886426
These switches will tell the ECU if you in 4x4 or not.
And this switch on the front diff.
Front Diff Engage Switch Part number MB176697, this will cause the front two lights to flash continously, even when out of 4x4.
If the lights still flash after changing these switches, then the two vacuum switches under the air filter. Change this one as a last resort, as it is the most expensive.
I do have knowledge of these vehicles as I change these switches all the time...
__________________
  #8
Old 12-09-13, 11:20 AM
Member
Thanx for the info guys! I've spoken to Henk that works on Pajeros and he confirmed that it will most probably be the switches. I've decided to take a change and take the Pajero for R60k and spend a few thousand to replace the switches and service the whole 4x4 selection system so I dont have problems in the future. Picking it up tomorrow - very excited! Just hold thumbs that its the only problem! Will keep you guys posted.
  #9
Old 13-09-13, 06:55 AM
brennain's Avatar
brennain brennain is offline
Member
Quote:
Originally Posted by Haydn View Post
1.
Yes he has he did it on my colt and he's about to do it again on my new Pajero! (at least I hope that's all the problem is!)
Sent from my GT-I9500 using Tapatalk 4
__________________
So much to see, so little time...
2000 Gen2.5 V6 Pajero
  #10
Old 13-09-13, 07:10 AM
sakush's Avatar
sakush sakush is offline
Member
also had a problem with mine, center diff light on after 25km,
then eventually nothing seem to be working, as soon as I went from 2wd to 4wd the lights started flashing.
changed the vacuum solonoid switch in engine bay. All sorted now, luckily did not have to do switches on gearbox itself
__________________
Steve
4x4 Action Group 002
Disco 4 SDV6SE
Metalian Maxi
  #11
Old 16-09-13, 02:24 PM
Mort Mort is offline
Member
Quote:
So what's the verdict? Have you got the vehicle? Sorted out the problem?
Also, you wouldnt happen to have any contact info for that supplier would you?
Reply
Tags
4x4 lights , pajero
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Brakkeduine 4x4 Trail near PE. Big Hilux Eastern Cape 12 29-12-14 10:34 PM
Advice needed: Possibly buying Hilux 4.0 4x4 AT Quantum Theory Toyota 20 11-04-12 10:13 AM
advice needed: which 4x4 to buy Praveshs General (non vehicle/technical) 4x4 Discussions 20 22-12-10 09:56 AM
Pajero & 4x4 newbie. Advice? Dalet Mitsubishi 11 29-07-08 04:05 PM
New Pajero Gerrit Loubser Mitsubishi 28 04-11-06 03:40 PM
Template-Modifications by TMS
