logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Land Rover
4x4Community
Notices
Land Rover Go Beyond! The best 4x4xfar!
Reply
Thread Tools Display Modes
  #1
Old 13-05-13, 07:41 PM
TRG's Avatar
TRG TRG is offline
Member
Default Key access Discovery 2 td5 2004
Help I can't get into my car. The remote isn't unlocking the doors and the key doesn't seem to work either?
__________________
Pay it forward.
2004 Discovery 2 TD5 GS
  #2
Old 13-05-13, 07:55 PM
PieterV's Avatar
PieterV PieterV is offline
Member
Did the key work before?
__________________
ORRA Z150
Discovery 2 V8 XS
Range Rover 5.0 V8 S/C
  #3
Old 13-05-13, 07:56 PM
Baben's Avatar
Baben Baben is offline
Member
Are you sure its your car?
Go check the numberplate
Sent from my iPhone using Forum Runner
__________________
Mail me if you need me Anthony at TorqTune dot co dot ZA
  #4
Old 13-05-13, 07:57 PM
TRG's Avatar
TRG TRG is offline
Member
Quote:
Ja I used it yesterday everything was fine! I never had to open the door with just the key before though so not sure why it just turns...no resistance to the key hence not opening.
__________________
Pay it forward.
  #5
Old 13-05-13, 07:58 PM
TRG's Avatar
TRG TRG is offline
Member
Fortunately it's parked at home so unless I managed to steal someone else's I'm sure I've got the right car.
__________________
Pay it forward.
  #6
Old 13-05-13, 08:04 PM
PieterV's Avatar
Member
Quote:
I think it turns without resistance because it is "superlocked". So how to get it out of superlock without a working remote? Don't you have a spare remote?
Superlocking
Provided all the doors are fully closed, the
Superlocking feature is activated automatically
whenever the vehicle is locked using the remote
handset. Superlocking immobilises the interior
door handles, thereby preventing an intruder
from gaining entry by smashing a window and
reaching inside the vehicle to operate the door
handles.
Note that locking with the key will not activate
superlocking.
__________________
ORRA Z150
Discovery 2 V8 XS
  #7
Old 13-05-13, 08:14 PM
TRG's Avatar
TRG TRG is offline
Member
Spare remote doesn't work either. If the battery is dead and I have a knackered lock that doesn't open with a key how can you pop the bonnet o check the battery from the outside?
__________________
Pay it forward.
  #8
Old 13-05-13, 09:11 PM
AlvinA AlvinA is offline
Member
Do the indicator lights flash when you lock/unlock with remote?
__________________
Alvin
2000 Land Rover Discovery 2 V8 ES Auto - Me
2010 Hyundai i20 1.6 - SWAMBO
1996 Toyota Tazz 1.3 - "Pool" car
  #9
Old 13-05-13, 09:17 PM
Baben's Avatar
Member
Just joking
This is a big problem. Sounds likely that the battery is dead then.
Is there any way you can get a charge onto the battery?
Can you open any of the other doors?
Otherwise you might be able to open the bonnet somehow by accessing the release cable ?
__________________
  #10
Old 13-05-13, 09:21 PM
TRG's Avatar
TRG TRG is offline
Member
Quote:
Ja when it worked its completely dead now! I think it must be the battery.
__________________
Pay it forward.
  #11
Old 13-05-13, 09:22 PM
Member
Where abouts are you in JHB?
__________________
Alvin
  #12
Old 13-05-13, 09:23 PM
TRG's Avatar
TRG TRG is offline
Member
Just joking
I'm gonna have to see how to get under the hood, almost certain it has to be the battery.
__________________
Pay it forward.
  #13
Old 13-05-13, 09:25 PM
TRG's Avatar
TRG TRG is offline
Member
In Fourways. Fortunately this isn't my only vehicle so it'll have to wait until the weekend when I have daylight to work with.
__________________
Pay it forward.
  #14
Old 13-05-13, 09:28 PM
PieterV's Avatar
Member
From Australian LRO:
"Grab another battery & jumper leads.
Crawl underneath and attach jumper lead to starter motor main power.
Attach negative to body. Then attach leads to the battery.
Now try and open doors and take it from there."
http://www.aulro.com/afvb/discovery-...nlock-car.html
__________________
ORRA Z150
Discovery 2 V8 XS
  #15
Old 13-05-13, 09:30 PM
TRG's Avatar
TRG TRG is offline
Member
That's awesome thanks I'll give it a try this weekend or if I manage to sneak out of the office at a decent time this week.
__________________
Pay it forward.
  #16
Old 13-05-13, 09:33 PM
Member
Sent you a PM
__________________
Alvin
  #17
Old 13-05-13, 10:04 PM
Suid-Wes Suid-Wes is offline
Member
Just be very carefull that you do not touch the small bolt on the startermotor aswell. It will jump forward when in gear. Connect to the donor vehicle last, just to be safe and out of harms way. If it is an automatic, then you will be fine. Good luck!
  #18
Old 14-05-13, 06:21 AM
mariusrautenbach's Avatar
mariusrautenbach mariusrautenbach is offline
Member
100% seker dit is battery wat begin poef maak.....
So twee weke terug selfde storie gehad, nou is daai probleem 'n spook?
__________________
1999 Discovery II 4.0L V8 auto;
50MM suspension lift; Extended diff breathers; Hankook Dynapro AT's; Snorkel; Front bumper cut done; Self made drawer system; Self made roofrack; 50L water tank.
Patiently waiting for a donor 4.6 V8!!
2012 Ford Figo TDCI; Straight pipe; Bi Xenon HID retrofit https://www.hidplanet.com/forums/for...ofit-pic-heavy
  #19
Old 14-05-13, 07:41 AM
TRG's Avatar
TRG TRG is offline
Member
Quote:
Good tip I always park in gear!
__________________
Pay it forward.
  #20
Old 14-05-13, 07:48 AM
ProtZkroG ProtZkroG is offline
Member
Are you sure the remote batteries are 100%?
__________________
2001 Land Rover Defender TD5 110
  #21
Old 14-05-13, 07:54 AM
TRG's Avatar
TRG TRG is offline
Member
Very unlikely both sets are dead I've used them days apart from each other when I couldn't find my usual set. I'm almost certain it's the main battery.
__________________
Pay it forward.
  #22
Old 16-05-13, 03:58 PM
Tsotsi's Avatar
Tsotsi Tsotsi is offline
Member
Alternate option....
__________________
Gary W
BMW 1200 GS Best 2x1xfar
  #23
Old 16-05-13, 05:05 PM
Ystervark's Avatar
Ystervark Ystervark is offline
Member
Exactly this happened to my with my dad's Disco2.
The jumpers on the starter thing could work.
What i did was:
The cable that pulls the the bonnet open from inside the cabin runs down the passenger side fender and then behind the grill to the bonnet catch.
I got hold of the cable and pulled it all the way out through the grill so that i can get to it with a girder, i then grinded a section of casing just so that i can get to the actual cable inside with a long-nose and pulled the bonnet open. (afterword i just pushed the cable back bahing the grill and it worked like normal)
After removing and reconnecting the positive on the battery everything came to life.
__________________
Werner Smit
2001 Defender 130 td5
1999 Discovery 1 with lots of mods
19 something Forward Control 2B
  #24
Old 18-05-13, 01:25 PM
TRG's Avatar
TRG TRG is offline
Member
I'm in thanks to all for the advice main battery was the culprit.
__________________
Pay it forward.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
TD5 Discovery Tranfercase in TD5 Defender Leond Land Rover 7 19-01-13 07:00 AM
EMS 1 installation on Discovery 2 Td5 Auto (facelift version) Mr Bounce Land Rover 1 12-12-12 07:46 PM
Discovery II Td5 Craigb Land Rover 28 07-10-08 10:16 PM
