logo
Go Back   4x4 Community Forum > General & Misc > The 4x4 Pub
4x4Community
The 4x4 Pub Off topic chat area, from the latest to IT questions may be posted here. Please keep it clean and family orientated, or your post WILL be deleted.
Joke and funny picture threads are not welcomed, and will be removed without notice.
Reply
Thread Tools Display Modes
  #1
Old 11-11-12, 06:36 PM
Starfire69 Starfire69 is offline
Member
Location: San Sebastian Peninsula, Vilanculos Mozambique
Default Removal of Diesel Particulate Filter
OK, so here are my thoughts.
A large number of vehicles in SA use the same engines as they do in Europe where they are fitted with DPF's. When they are being sent to SA, they are assembled without the DPF to be compatible with our lower quality fuels.
So these engines are able to run on our diesel in SA, theoretically.
Here is my problem: I want to buy a Subaru again, but I want the diesel Forester.
Let's forget about the warranty implications completely.
If the DPF was removed, and the vehicle run on 50ppm as much as possible, it should not be a problem?
The reason I am thinking of this is because I live in Mozambique, and travel outside of SA a lot. Most of these out of SA places do not have 50ppm. I usually travel much more kilometers than the standard tank and jerry cans will take me.
Would it be possible?
  #2
Old 11-11-12, 07:14 PM
Speedo's Avatar
Speedo Speedo is offline
Member
Remember that its just not the PDF that is influenced by the diesel quality, yes they do block easier when using dirty or poor quality diesel.
But the main concern is the high pressure fuel pump and injector lubrication, that is where the main wear occur when using lower quality diesel.
Modern engines are running much higher fuel pressure as a few years ago, thus require better lubrication.
  #3
Old 11-11-12, 07:25 PM
Pajeromania's Avatar
Pajeromania Pajeromania is offline
Member
You will not encounter any problems. The DPF & Catalisator is a filter which clean the exhaust gas before blowing it out into nature. Running the vehicle with 500ppm for long durations may only cause more soot, but usually the system cleans itself when driving constantly on the open road. Filling the tank with 50ppm every now and then will help to clean the filter.
Running the vehicle without the the DPF will only have an effect on nature.
__________________
Pajero Did lwb
Jeep Gladiator J2000
Kenwood TK-7100 VHF
AG-0241
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Advantages of 50ppm diesel Sanman Vehicle & Technical Chat - General 30 16-04-15 05:11 PM
2 stroke oil in diesel? Bruce_1 Vehicle & Technical Chat - General 225 07-08-13 08:16 PM
UDF diesel filter testing Uys Vehicle & Technical Chat - General 213 19-06-12 03:47 PM
diesel fuel Landyluvver Land Rover 270 04-03-12 07:05 PM
Petrol or Diesel Varkienel Toyota 18 15-03-11 02:59 PM
Template-Modifications by TMS
