logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Land Rover
4x4Community
Land Rover Go Beyond! The best 4x4xfar!
Reply
Thread Tools Display Modes
  #1
Old 27-09-12, 07:44 AM
Werner90's Avatar
Werner90 Werner90 is offline
Member
Default 300 TDi Defender Viscous vs electric
I have recently broken a blade on my fan, after some inspection I have an idea that my viscous is also stuck fixed..
So before replacing the lot, can I convert the fan to an electric system to save some engine power?
Inputs would be appreciated..
Thank you
__________________
Airlift kit
Long range tank
Barakah roofrack
National luna split charge
ARB Rear Locker
BlackBox engine monitoring system
TerraFirma All Terrains
  #2
Old 27-09-12, 07:47 AM
Crips's Avatar
Crips Crips is offline
Member
I would stick to the viscous, I think it's more reliable out in the bundus but maybe that's just me....
__________________
Chris
"Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure, or nothing" Helen Keller
2005 LandRover Defender 110 D/C TD5
1977 LandRover Series III 109" Project
chairman@4x4actiongroup.co.za
www.4x4actiongroup.co.za
  #3
Old 27-09-12, 08:18 AM
Dawid's Avatar
Dawid Dawid is offline
Member
Unless you go for an expensive BMW electric fan, the viscous will be better. Keep it standard and reliable.
__________________
2004 Defender 110 Td5
ex 2009 Suzuki Jimny
ex 1996 Toyota Hilux 2.8D
ex 2002 Lada Niva
2012 Momsen 29'er (MTB)
  #4
Old 27-09-12, 11:03 AM
terratiger's Avatar
terratiger terratiger is offline
Member
I've only recently come to understand the viscous fan and how it works... ingenious.
The chaps in the UK are all for pulling them out and replacing with electric.... but they won't find themselves in the middle of nowhere.
I'd also stick to the standard viscous. The 300 Tdi is brilliant for the bundus. Don't start introducing stuff that can become a problem in the sticks.
__________________
___________________________
98 Defender 110CSW 300TDI
2010 Freelander 2 TD4 HSE
97 Discovery V8i
You can go fast but....I can go anywhere!
  #5
Old 27-09-12, 11:49 AM
faniedup's Avatar
faniedup faniedup is offline
Member
If a viscous coupling ever starts slipping in the sticks, two large cable-ties around the shaft and blades will introduce enough friction to get blowing again.
  #6
Old 28-09-12, 07:58 PM
biltong's Avatar
biltong biltong is online now
Member
Keep the viscous!
__________________
1999 Discovery 1, 300 TDi - "Tink Tanky"
Those less educated think they know it all. Those more educated, realise how little they know. And of course there are exceptions to both. 50 Shades of grey or something.
  #7
Old 29-09-12, 03:11 PM
johannes14's Avatar
johannes14 johannes14 is offline
Member
Uk does'nt get as hot as Africa A hot day there does not come close to a hot day here
__________________
2004 Defender TD5
1992 Defender 3.5V8
PROJECT OVERHAUL http://4x4community.co.za/forum/show...oject+overhaul
  #8
Old 29-09-12, 03:15 PM
4x4 Bedinges's Avatar
4x4 Bedinges 4x4 Bedinges is online now
Member
UK the highest temp is 20 degrees Celsius plus minus keep the viscus fan.
__________________
Petrus
4x4 AG 0081
Swambo : 4x4 Gogga
2006 Bmw X3 3.0d Awd
Die krag vraat
2012 Ford Ranger T6 2.2 XLS DC 4x4 Die speelding WorsHond
En n 1969 stok ou woonwa wat ek en my vrou self oor gedoen het
My Lorrie se thread : http://www.4x4community.co.za/forum/...d.php?t=227207
As jy n opstical die eerste keer nie maak nie is jou aanloop te kort
ONE LIFE LIVE IT!! OFFROAD STYLE!!!
Alles in die lewe gebeur met n doel
  #9
Old 29-09-12, 04:35 PM
terratiger's Avatar
Member
Quote:
You'll be amazed, having lived there for a few years, it can become uncomfortably hot... But yes it is a rare event, point taken
Sent from my iPad using Tapatalk HD
__________________
97 Discovery V8i
  #10
Old 29-09-12, 05:07 PM
hgbosch's Avatar
hgbosch hgbosch is offline
Commercial Member
Hi guys
a properly working viscous fan will only sap power from the engine, when such is running at to high a coolant temperature. As soon as this has returned to normal levels, it will switch off again. It does this by means of a bi-metal triggered valve, that opens or shuts the flow of the viscous fan's oil and therefore engaging and/or disengaging the clutch.
If you need to remove the fan assembly for work on the engine or for cleaning out the intercooler, then ALWAYS stand the fan assembly up right against a wall or similar. This prevents the oil from leaking out of the VF.
You will know that it operates properly when driving off in the morning. You will hear a howling noise from the fan for about 15-20 seconds which then abates. Only once the engine coolant reaches about 97 Degs will the viscous clutch of the fan kick in again and then the fan will suck air through the radiator until such has cooled down to around 85 Degs. At this stage the VC will disengage again.
__________________
with kind regards
George Bosch
2003 RangeRover Vogue 3.0 Td6
2005 LR Disco3 TDV6 S
1998 Disco1 Tdi ES (Sold)
And some more serious stuff
Distributor for:
  #11
Old 29-09-12, 05:31 PM
Member
To me uncomfortable comes at 50 in the desert
__________________
Petrus
4x4 AG 0081
Swambo : 4x4 Gogga
Die krag vraat
  #12
Old 01-10-12, 06:19 PM
Werner90's Avatar
Member
Thank you hgbosch!
Think my viscous needs replacing a it is not disengaging anymore..
__________________
Airlift kit
Long range tank
Barakah roofrack
ARB Rear Locker
  #13
Old 01-10-12, 08:37 PM
LouisXander LouisXander is offline
Member
There is nothing wrong with an electric fan conversion. As long as it is properly done it has more advantages of which one is more power..Normal fwd cars also drive in 50° heatwaves and still work fine. I'll go electric with a warning light if you really want to be sure. I'm going electric on my auto Can for the extra 7-9 kw on my auto.
__________________
LouisXander
2014 Renault Duster 4WD
98 XR600R just to keep me busy
  #14
Old 02-10-12, 11:03 AM
T le Roux's Avatar
T le Roux T le Roux is offline
Member
Guys where can one buy the "special" tools refered to in the Rave Manual to enable you to change the Viscous Fan unit.
__________________
Theo le Roux
1995 Defender 110 300TDI
2007 Discovery 3 TDV6 SE & TorqTune Remap
2014 Bush-Trotter Warthog
  #15
Old 02-10-12, 11:18 AM
biltong's Avatar
Member
You can buy it at any hardware store and modify it yourself.
__________________
  #16
Old 02-10-12, 09:29 PM
Landyluvver's Avatar
Landyluvver Landyluvver is offline
Member
Quote:
are you referring to a 32 flat spanner?
may need to thin it down a bit to fit in but easy enough with an angle grinder and flapper wheel
__________________
0833006099
  #17
Old 10-10-12, 07:15 PM
Werner90's Avatar
Member
Bought a 32 spanner and it worked 100%, took me 10 mins to remove and 10 to refit, got quoted R1500 for labour so decided to do it myself...
__________________
Airlift kit
Long range tank
Barakah roofrack
ARB Rear Locker
  #18
Old 10-10-12, 09:40 PM
Member
Quote:
was that an "independant" quote?
__________________
0833006099
  #19
Old 10-10-12, 09:42 PM
Werner90's Avatar
Member
Quote:
Maybe
__________________
Airlift kit
Long range tank
Barakah roofrack
ARB Rear Locker
  #20
Old 18-11-12, 11:01 AM
Werner90's Avatar
Member
Replaced the viscous, all good again!
__________________
Airlift kit
Long range tank
Barakah roofrack
ARB Rear Locker
  #21
Old 13-05-14, 08:03 PM
CuZn CuZn is offline
Member
Default vf removal
Hi guys...
Is there any way of testing the viscus while its off?? And how to tell if its working without running the motor to Temp??
  #22
Old 13-05-14, 08:09 PM
Member
Quote:
Originally Posted by CuZn View Post
Hi guys...
no
needs to run to operate
if you understand the mechanism, you will realise it operates with centrifugal force so needs to spin to work
__________________
0833006099
  #23
Old 13-05-14, 10:21 PM
Grim's Avatar
Grim Grim is offline
Member
Always interesting reading discussions about fans.
I changed my D2 v8 to electric fans from a Freelander.
In my opinion electric fans will move more air at slow speeds / low motor rpm than a viscous can.
The thing I don't like about the viscous, is you (ok me) only realise it's not working when the gauge moves, by which time it is usually too late.
As mentioned, one can wire in a LED to show the electric fans are running.
Also, you can change the temperature of the switch for when you want them to come on.
My 2c.
__________________
Disco 2 V8 GS
Kymco Xciting 500
Jazz 1.4
  #24
Old 15-05-14, 12:07 AM
Simmo2000 Simmo2000 is offline
Member
Cool stick with the viscous coupling.
I was contemplating the change to an electric fan as well, and saw a lot of talk about it on various websites, mostly from the UK. Most of the guys on the SA site are against it and they turned me off the idea as well. Driving in the UK where a hot day is 25 C, is one thing. Driving in sand, or up long mountain tracks heavily loaded when its 38 to 42 deg C is another. ( any hotter than that you should be having a beer some where cool so you don't overheat ).
The guys report it's not much quieter , or much better fuel economy.
Landrover has done their homework over many years, my viscous fan does the job without fuss for nearly 20 years, hard to beat that for simplicity & reliability. For me that's what it's all about, I doubt if I would notice any noise reduction on a defender anyhow. Thanks for the contributors for sharing their experience about the electric fans, when my time for replacement comes up I'll just get another viscous coupling
simmo
1995 Tdi wagon
  #25
Old 15-05-14, 12:24 AM
Member
Default test viscous coupling.
The coupling works like fluid clutch that has viscous fluid between the plates, the hotter the coupling gets get the more viscous the fluid becomes , and the more drag , ( or drive).
If you heat up the coupling using a hair dryer or hot air gun you should notice it's lot stiffer. When my car is idling and not hot I can grab the fan and hold it for a while, so its just free wheeling and not using hardly any power. I was never brave enough to try it when the engine is hot though.
I guess it works OK because the engine temperature never goes into the red. though it has gone close once or twice, on a long up hill, or in soft sand on hot summer days, with the AC on, I usually turn the AC off when conditions are that bad, My car has no electric fan in front for the AC, that's a small project to think about.
simmo
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Defender Wheels24 Test JohanJvV Land Rover 1 07-08-15 09:16 PM
defender 300 Tdi Drivebelts Benson Land Rover 29 01-04-11 08:53 AM
Defender Viscous fan vs Electric fan Grond Monster Land Rover 21 03-01-11 05:42 PM
Defender Defender 110 300 tdi overhauled. brandh Land Rover 6 22-12-09 09:07 PM
Electric problem - Defender Tdi OllieNoster Land Rover 10 10-12-08 06:45 AM
Template-Modifications by TMS
