logo
Go Back   4x4 Community Forum > General & Misc > General (non vehicle/technical) 4x4 Discussions
4x4Community
Notices
General (non vehicle/technical) 4x4 Discussions Any 4x4 related topic, for which there is no other specific Section.
Reply
Thread Tools Display Modes
  #1
Old 19-07-12, 09:30 AM
Schuits's Avatar
Schuits Schuits is offline
Member
Default Centurion D5 gate motor problems
Hey guys,
I'm hoping someone can help.
We have a Centurion D5 gate, which stopped working properly.
I replaced the battery and it worked for about 2 weeks, then stopped working again.
I've checked the battery and charger and they are 100%.
Pressing the test button results in a relay click and 5 led flashes.
I connected the motor directly to the battery and it runs fine, voltage doesn't drop more than expected.
I took the circuit board into a specialist who ran a bench test and confirms the PCB is fine.
I did a factory reset, with no luck. I tried setting the gate limits with the automatic programming mode, but again the relay clicks and the LED flashes 5 times. He now wants me to bring in the complete unit, which is a schlep.
Theres a thing called a DOS connected to the PCB which keeps track of the gate position or something. Could this be defective and causing the problem?
- mod please move to the PUB section, I posted in the wrong section -
__________________
Robert
"...just a bottemless pit of useless facts"
http://discoii.wordpress.com/
  #2
Old 20-07-12, 09:06 AM
SpiderGear SpiderGear is offline
Member
Which model is it? The EVO with the LCD screen?
  #3
Old 20-07-12, 10:44 AM
Schuits's Avatar
Member
Quote:
Nope definitely no LCD. So it must be an older one.
__________________
Robert
  #4
Old 20-07-12, 03:38 PM
Bob Lemon's Avatar
Bob Lemon Bob Lemon is offline
Member
It has a dos decoder, very seldom goes wrongwho has a manual handy? mine is still packed and I probably won't need it where I am nowI won't toss it though
__________________
'79 Range Rover classic.
Now sadly sold.
88" series 3"Littlemule"my first diesel.No more Landys, all sold
  #5
Old 20-07-12, 03:49 PM
CoenraadB's Avatar
CoenraadB CoenraadB is offline
Member
Hier is die Manuals.
Hoop dit kan jou help
of anders https://dl.dropbox.com/u/80636533/Ga...ll%20guide.pdf
https://dl.dropbox.com/u/80636533/Ga...er%20guide.pdf
__________________
Coenraad Basson
Hilux D/C 3.0 D4D
Prado 4.0 V6 Auto VX
  #6
Old 20-07-12, 04:15 PM
Flagster's Avatar
Flagster Flagster is offline
Member
Phone Centurion directly
0116992400. Te help line is open till 7pm I think, else give me a call and I'll try to help you over he phone. Just one concern, 5 flashes does not Make sence.
Franz
082 threefourthree 4949
__________________
Franz
ISUZU 300TDi Lx D/C 4x4 (AKA SMYlie) with a few extras
Venter Bush Baby with a few extras
  #7
Old 20-07-12, 04:23 PM
0-100km/h in 2 days's Avatar
0-100km/h in 2 days 0-100km/h in 2 days is offline
Member
Sounds like a loose connection. Check your terminals on the battery, check where the battery and motor wires goes onto the PC board that it's tight check the 16 A fuse next to the relay's with a multimeter and also remove the fuse while testing and before replacing the fuse bend the fuse holder close so that the fuse makes good contact.
Hope this helps
__________________
Stephan
Landy Defender 110 3.5 V8
  #8
Old 20-07-12, 04:30 PM
Mr.G's Avatar
Mr.G Mr.G is offline
Member
Mine did exactly the same.I replaced the small black box with the "tube" that slots in on the side of the motor wher the gate is..Think it is the dos sensor.Was R300 all and all.Fixed.
__________________
2007 gen 4 pajero 3.2
Wilderness 310 trailer
Nissan np200 8v
  #9
Old 20-07-12, 05:33 PM
Flagster's Avatar
Member
The 5 flashes = Micro processor reset.
Call Centurion on 011 699-2400. Never had that problem before.
__________________
Franz
  #10
Old 23-07-12, 10:20 AM
Schuits's Avatar
Member
Quote:
Hope this helps
10 points for being correct!!
I HAD checked voltages, fuses and everything the local centurion dude recommended. BUT I had assumed good voltage means a good connection.
The local dude took one look at a corroded battery lead and said...theres the problem. After replacing it it worked!
I felt a bit stoopid Lesson learnt, corroded connections are bad. And voltage alone is not a good test. Amperage cannot effectively pass through a bad connection.
__________________
Robert
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Moremi and Chobe trip report, July 2010 lvarro Botswana 11 19-07-11 02:38 PM
Anybody in the gate automation industry (Centurion D5 EVO) ?? SinWolf The 4x4 Pub 14 29-05-11 04:13 PM
Botswana Trip report: Chobe, The Delat and Nxai Pans Dec 08 brennain Botswana 9 16-02-11 11:30 AM
Centurion D5 electric gate issues offroadrover The 4x4 Pub 27 09-02-11 06:29 AM
Centurion D3 sliding gate operator dvdm The 4x4 Pub 3 05-02-10 11:58 AM
Template-Modifications by TMS
