logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Toyota
4x4Community
Toyota Lead the way!
Reply
Thread Tools Display Modes
  #1
Old 16-08-07, 04:46 PM
Tracer
Guest
Posts: n/a
Smile Hilux 2.8 Diesel double cab
Hi Guys
I am new to this so I would like some advise on the 2.8 diesel (no turbo) double cab Hilux raider please. Is there something specific to lookout for on those vehicles. I haven't seen this one yet so if anyone can tell me if this is still the 'old box shape' or if it's the shape just before the very latest model, if you know what i mean? Also what consumtion can one expect from normal city traffic and open road? It will mainly be used for daily to and from work and then once in a while to tow a trailer or maybe a caravan. Your help would be appricaited!
  #2
Old 16-08-07, 05:09 PM
francoiskriel francoiskriel is offline
Member
Default Def Box shape
Quote:
Originally Posted by Tracer View Post
Hi Guys
or as the guys on the forum call it, a SFA hilux for Solid Front Axle. On the consumption etc, someone who knows more than me will be around shortly to answer all your questions....you can count on that
__________________
He who has the most toys wins.......
  #3
Old 16-08-07, 05:47 PM
Berty's Avatar
Berty Berty is offline
Member
Ja its the old box shape. mine gives about 9km/l average, but depending on where and when and how you drive that can fluctuate up to 9.8 or down to 7.5. Not hugely powerful but very reliable. Some guys will tell you the heads are unreliable, cant say i agree. Its real toyota reliability. It might be a bit underpowered if you towing a big caravan up ###### hills. Althogh my old man used mine to tow a 19ft yacht from CT to durban so it can do it, just not very fast. The only thing i would look for is regular oil changes/service, ie every 5000km, and big mileage, as in 250 000km+. And rust around the windscreen and on the seams at the back of the cab.
__________________
1994 160i Conquest RS
1998 2.8D SFA Raider D/C
2003 2.5 V6 Alfa Romeo 156
2006 3.2 V6 Alfa Romeo GT
  #4
Old 16-08-07, 08:40 PM
Ouarzazate Ouarzazate is offline
Member
Having done many km's in 2.8D's, I can state:
Plus points:
1) Excellent general off-roader - I like the low-rev grunt and engine braking
2) Light on juice (average 9.5 km/l)
3) Normally stone-cold reliable, but there are the odd cases of head/head gasket failure. In my own case, we found the block was also warped, so, many $$$'s later, it's now hopefully back in the reliability stakes
4) Simple engine to work on, robust drive-train
5) Can be easily modified into an off-roader of awesome capabilities
Drawbacks:
1) It's slow, and especially when loaded on long trips, it can be a pain in the backside to pass slow-moving traffic
2) Standard suspension is unforgiving on rutted dirt road bends and harsh in general - this can be fixed by fitting OME suspension
3) Its not built for dune driving
4) Be prepared to change your driving style completely if you fit larger tyres - it runs best on 245's.
5) Spares may become a problem in the not too distant future?
__________________
1998 2.8D DC Hilux, OME, F & R lockers, 31" Hankook Dynapro's with 4.875 ratios
2011 Pajero 3.8 GLS LWB, dead standard
  #5
Old 17-08-07, 11:29 AM
Tracer
Guest
Posts: n/a
Talking
Thank you guys for all your replies - I will have a look this afternoon & keep your info in mind!
  #6
Old 17-08-07, 06:04 PM
iHilux's Avatar
iHilux iHilux is offline
Member
My babe is for sale if you are in the market.
Have a look here:
http://www.4x4community.co.za/forum/...ght=Hilux+sale
__________________
Wade Bowman
'07 Land Cruiser 76 SW
'08 Discovery 3 V6TD HSE
'11 Conqueror Companion
  #7
Old 20-08-07, 09:27 AM
Sawdust's Avatar
Sawdust Sawdust is offline
Member
Mine just packed up but I'm not negative about it. The motor was worked on before. I always had the suspicion that the head might have a slight leak due to slight positive pressure when the engine has cooled down. The broken piston did crack the head but the head was also cracked in a different place. This makes me think that it might have been cracked before I got it. I've being driving it for 2 years. Even the Silverton radiator test did not show any defects.
Performance is not great. Cruising at 110km/h mostly. Overtaking sometimes dangerous. Offroad it's fine. Consumption not as good as I thought it would be. Not 100% sure but mine is in the region of about 8-8.5km/L depending on driving style.
__________________
2004 Defender 110 Td5
  #8
Old 20-08-07, 07:47 PM
Member
Default Jammer om te hoor
Hallo Dawid
Sorry to hear about the engine trouble. Mine has just been repaired. Both block and head skimmed, pistons cut to allow for change in protrusion above block. Thickest gasket fitted. Because the excess combustion pressure punished the radiator beyond repair, I had to replace it AGAIN (R4500).
If I have any more sh1t with this engine, I will replace with a factory sub-assembly (R34,000), or maybe a R15,000 worth of 5L (3 litre imported motor). But so far, things are looking good.
Interestingly, I had a water T gauge installed and it reads a constant 90 degrees.
BTW, I am starting to think that the 3L might not like the installation of an aircon radiator in front of the radiator. This is the only difference between my Raider and the plain 2.8D's at work (without aircon), which are constantly hammered by different drivers, and none of which have suffered from overheating?
__________________
  #9
Old 21-08-07, 09:54 AM
Sawdust's Avatar
Member
Dankie vir die simpatie. Ek het my aircon radiator (condensor) 'n tyd gelede al afgehaal aangesien my compressor inelkgeval moeg was. My temperatuur was baie konstant tussen 85 -90grade. Ek het 'n additionele guage. Die motor het net eweskielik begin raserig raak en 50km later was hy kapoet. Geen waarskuwing nie en die temp was nog normaal. Die workshop staan gereed om te begin met die recon, maar ek kan nie besluit wat ek wil doen nie. Vir dieselfde prys kan ek 'n grey import kry. Probleem is dat niemand in PE voorraad het nie. Eers oor 10 dae. Ek sal liewer wag en dan besluit. Sover is daar meer positiewe feedback as negatief oor die grey imports.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Leisure Wheels’ Chinese double cab shoot-out – we need your help! Dirk The 4x4 Pub 23 25-07-11 03:17 PM
Defender Td5 - 2SO question...sorry! Trevor_Mathews Land Rover 49 03-04-11 09:25 PM
NEw Isuzu beats new Yota offroad. Bryan Webber Isuzu 29 20-12-06 09:31 PM
Template-Modifications by TMS
