logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Toyota
4x4Community
Toyota Lead the way!
Reply
Thread Tools Display Modes
  #1
Old 02-05-12, 12:58 PM
Toyota_King Toyota_King is offline
Member
Default 2011 Hilux / Fortuner reverse Camera DIY
Added some end product pictures;
I’m documenting the wiring diagram to install aftermarket reverse cam on new (2011) Hilux and Fortuner. (Could not get this info anywhere, so I paid to get it done…R3500 L)
The facelift Hilux and Fortuner ships with a 2 din colour display radio, the Heritage models comes with a fitted camera and the non-Heritage models not.
The non-Heritage model radios are reverse camera ready but you need the wiring diagram for these vehicles as the radios does not come with a fitted RCA or any indication as to connect your own camera.
Go buy your own reverse camera, there are a few options and you should find 1 to fit your needs. Note some cameras display as Black&White, something to do with the PAL / NTSC requirements. Mine is colour, it is the Kenwood CMOS 200.
Step1.
Remove the left kick plate on the passenger side and look for a white wiring plug with red, black, grey and white wires only.
Take the reverse camera, cut and strip camera video wire with RCA attached.
Wiring values;
· Bridge Red and Black (Seems awkward, but this is correct J)
· White is camera signal wire (Normally yellow on camera wire)
· Grey is camera screen / ground wire (Screen mesh cable on camera wires)
Step2.
Remove plastic cover under steering colom. (There are a few fuses visible when you remove the cover)
On the far right plug there is a cable with black/red colours connect this to the reverse signal wire of the camera.
Supply the camera with Car Acc power + and –
Test before closing all panels.
The end product;
For less reading use this;
  #2
Old 11-05-12, 10:23 PM
devon's Avatar
devon devon is offline
Member
Thanks very interesting,
Will look to fit to SWAMBO,S 2012 hilux, will really help as she sturggles with the reversing. (and will make hitching the caravan a breeze)
regards Devon
  #3
Old 12-05-12, 11:01 AM
aviator609 aviator609 is offline
Member
Nice mod! We have reverse camera on the FJ Cruisers, but the picture is in the mirror, so it is a bit small and hitching is still a little difficult. I like the big size of the radio's screen.
Well done and enjoy!
  #4
Old 08-09-12, 11:10 AM
nice2have nice2have is offline
Member
Default reverse camera
Hi
i have connected the camera, but if the vehicle is not in reverse when starting the car, it does not recognize the camera. Once started like that you can go in and out of reverse no issue. The camera i use only have the psos and neg power as well as the video plus and negative. I see you talking about a camera signal, this is what i am missing, any ideas?
regard
  #5
Old 10-09-12, 01:23 PM
Adam Schäfer's Avatar
Adam Schäfer Adam Schäfer is offline
Member
My Mrs loves it so much she actually volunteers to reverse onto the caravan hitch!
__________________
To argue with a person that has renounced the use of reason is like administering medicine to the dead. ~ Thomas Paine
  #6
Old 10-09-12, 10:14 PM
sashton's Avatar
sashton sashton is offline
Member
Default Speaker wires
Maybe the wrong thread but Toyotaa-King seems to know alot about the head unit wiring. I want to connect an amplifier and sub to the existing sound system. What would be the easiest way to tap into the speaker wires without having to remove the door pads to check the wire colours and polarity?
__________________
2011 Toyota Fortuner 3.0 D4D 4x4 Auto (Facelift)
Previous: 2009 Toyota Fortuner 3.0 D4D 4x2 Auto (Facelift)
  #7
Old 12-09-12, 12:58 PM
Member
Default toyota wires
hi
i have found a lot of info on this website with wiring diagrams, maybe will help
http://www.modifiedlife.com/car-stereo-wiring-diagrams-and-car-radio-wiring-diagrams/
  #8
Old 12-09-12, 04:06 PM
sashton's Avatar
Member
Thanks a mil. After alot of research I have also managed to get all the info on the head unit in the Fortuner. I have now successfully, added a line-out converter, amplifier and sub woofer to the existing system. What an amazing difference in the sound. If anyone needs more detailed info on the installation, feel free to let me know...
__________________
  #9
Old 06-09-13, 11:52 PM
paler paler is offline
Member
Default Awesome Information
Toyota King,
Thank you for this information. I tried it today and worked as described. I just did a test before drilling the camera on to the tailgate to make sure it worked and it did.
I had looked all over the web for this. The local shops said it was not possible.
Best,
Tito
  #10
Old 11-09-13, 12:52 AM
Member
***UPDATE***
My camera has 4 wires only: 12VDC+, 12VDC-, video signal, video ground.
I powered my camera from a circuit that has 12VDC+ only when reverse is engaged.
Camera only works if I open the ignition switch with the vehicle in reverse. Apparently the HU detects if it gets a video signal on start up. If it does not, it will inhibit switching to monitor input when reverse is engaged.
I am concerned about having the camera powered on all the time if I wire it to acc + ...
  #11
Old 11-09-13, 05:12 AM
marnix's Avatar
marnix marnix is offline
Member
I have just ordered a 2nd hand Fortuner (June 2013 with 2,000km ) D4D 4x2 Auto with the reverse camera factory fitted. The camera comes on automatically when engaging reverse but does anyone know if there is a way to engage it manually while driving to keep an eye on a trailer while towing? An installer at Toyota Randburg said the after market ones count do it but wasn't sure if the factory ones could.
Another question I have is the radio comes standard with Bluetooth - can this Bluetooth stream audio from an iPhone or is this just for making calls? The Parrot 9100 in my existing Fortuner can stream audio via Bluetooth but I'm keen to move it to my wife's car if I don't need it in the new Fortuner.
Lastly whats the deal with the Satnav? Toyota are quoting R10k for the maps Would anyone in their right mind pay R10k for this when you can get a brand new Garmin with traffic updates for 1/3 of that.
  #12
Old 11-09-13, 07:52 AM
sashton's Avatar
Member
To the best of my knowledge, the camera can not be turned on manually. Bluetooth streaming works perfectly for my Ipad and Galaxy S4 so I don't see a problem with your iPhone. Unlike other bluetooth streaming head units that just allow a simple playback function, this HU also allows you to view playlists etc via bluetooth streaming.
Yes, the SATNAV story is a joke, I'm happy to stick with my Garmin for now.
Lastly... ENJOY!
__________________
  #13
Old 11-09-13, 04:26 PM
marnix's Avatar
Member
Thanks sashton. Just to confirm, "Bluetooth streaming works perfectly for my IPad and Galaxy S4" you happily stream music etc from your iPad vis Bluetooth to the Fortuners audio system?
  #14
Old 11-09-13, 04:46 PM
sashton's Avatar
Member
Yes perfectly, Including sound from music, games, movies etc.
__________________
  #15
Old 16-09-13, 07:33 AM
marnix's Avatar
Member
I can report that the info from sashton was 100% correct and audio streams beautifully (actually works better than my Parrot 9100 from my previous Fortuner). There doesn't seem to be any sort of mute button tho? Currently i am just turning the radio off which is not really a big deal.
Still want to see if there is a way to activate the rear camera while driving to keep an eye on the trailer tho. Any suggestions?
  #16
Old 16-09-13, 11:36 AM
sashton's Avatar
Member
There is a pause button on the bottom of the touch screen if my memory serves me correct. This could pass as a mute
Regarding the reverse cam. Fitting a switch to view your camera shouldn't be difficult. I had an after market head unit in my previous Tuna and fitted the camera and a switch to view the camera even when reverse was not engaged. Have not fitted the switch on my current Fortuner but I assume the following will have to be done.
1, Basically the camera input is triggered by power to one of the wires behind your head unit. Use a tester and check which wire gets power when reverse is engaged.
2. What you will want to do now is T off this wire and feed power to it via the switch you want to acitivate to view the camera.
3. Importantly, in order to prevent your reverse lights from coming on when you turn your camera switch on, you would need to fit a Diode on the camera trigger wire as shown in the diagram.
****** I am assuming that the power to activate the camera input is +12V. Please verify this with a tester before proceeding******
Let me know.
File Type: pdf Manual Activation of reverse Camera.pdf (31.0 KB, 516 views)
__________________
  #17
Old 16-09-13, 12:38 PM
marnix's Avatar
Member
Thanks for the comprehensive reply. Any ideas of someone who could do this around JHB North (I'm not much of an electrical guy )?
  #18
Old 16-09-13, 01:43 PM
sashton's Avatar
Member
Not from GP but I'm sure any sound installer should know what to do...
__________________
  #19
Old 16-09-13, 02:23 PM
riyadh's Avatar
riyadh riyadh is offline
Member
Is the current models camera 6v or 12v?, because I was told it is a 6v camera
  #20
Old 16-09-13, 02:52 PM
riyadh's Avatar
Member
How would I test it? to see what voltage it is using?
  #21
Old 16-09-13, 04:13 PM
sashton's Avatar
Member
Quote:
The camera may be 6V as it is probably powered by the Head Unit. The trigger wire however may be 12V as the unit is most likely receiving the trigger voltage from the reverse lights.
I can't say for sure until I find time to "dig" .
__________________
  #22
Old 16-09-13, 09:02 PM
riyadh's Avatar
Member
Thumbs up
thanks sashton, if you do find out anything please let me know
  #23
Old 19-09-13, 01:05 PM
GameFarmer GameFarmer is offline
Member
@ Toyota_King
I've got a slightly different model unit in my Cruiser (please see pic below), and have been searching all over to find a solution for a reverse camera. Without getting too exited in anticipation, do you perhaps know if this might work for me? I cannot determine from the manual (or non-existing google info - the Japs don't like sharing) if my unit is camera ready..
__________________
Unless it shoots straight, it is like Zohkos. Pretty perhaps, but not of much use.
  #24
Old 19-09-13, 01:23 PM
marnix's Avatar
Member
Randburg Toyota have said i need to leave my Fortuner with them for a day to the technician can have a look at fitting a switch.
Not sure i want someone fiddling around but without knowing anyone who has done this in JHB not sure what other options I have.
Any suggestions?
  #25
Old 10-10-13, 12:51 PM
Schumi's Avatar
Schumi Schumi is offline
Member
Default Camera
Hi All
I would like to know if anybody can assist, i have read thru all the comments and the installation steps provided by Toyota King, will it be possible for me to connect 2 cameras to my 2012 Lux, rear camera to work as intended but the front 1 to activate via a switch for traversing for instance a log crossing.
Any info will be appreciated.
Thanx Guys
  #26
Old 10-10-13, 07:52 PM
echochaser's Avatar
echochaser echochaser is offline
Member
Quote:
Originally Posted by Schumi View Post
Hi All
Thanx Guys
Hi schumi
It is possible.
My manager did it for his landy, with a normal swich and a relay.
I will see if i can get some more info on it for you.
Sent from my iPhone using Tapatalk - now Free
  #27
Old 10-10-13, 09:40 PM
riyadh's Avatar
Member
in the new murano's u can switch the cameras on and off
  #28
Old 10-10-13, 10:34 PM
echochaser's Avatar
Member
Hi All
Thanx Guys
Im going to do exactly the same. One camera on bull bar, one for reverse with a relay and switch to choose which is operational.
  #29
Old 11-10-13, 10:00 AM
Schumi's Avatar
Member
Thanx a mil ecochaser, any info will help if you need backup cameras look at www.stopshop.co.za they stock a wide range and the pricing is extremely good i will comment on the quality when i receive and install the cameras.
__________________
Live to Explore !!!
  #30
Old 17-10-13, 12:11 PM
Schumi's Avatar
Member
Quality of the cameras looks good will do the install this weekend and let you guys know about the image quality as well as aome pics
Live to Explore!
__________________
Live to Explore !!!
  #31
Old 20-10-13, 10:05 AM
marnix's Avatar
Member
Does anyone know if it is possible to load the Trackef4Africa onto the Fortuner nav system?
  #32
Old 20-10-13, 07:12 PM
echochaser's Avatar
Member
Is the fortuner nav system tunning windows ce?
  #33
Old 20-10-13, 07:16 PM
echochaser's Avatar
Member
Live to Explore!
Hi schumi
Did you have a chance to install?
What leondb did was a relay setup as i intend to doe but he controlled the feed to the radio from the cameras instead of having both permanently fixed to the radio and only switching power to each. His system is tried and tested, mine is still only an idea.
I have received my camera and the radio is installed, though i cannot install the camera until the back door is correctly fixed. As i sent it back to the panelbeater and its still not right!
  #34
Old 20-10-13, 07:52 PM
Schumi's Avatar
Member
Rear camera is in and working beautifully. Picking up the switch for the dash from toyota tomorow to finish the front camera install.
No need to cut any wires all the connections is under the passenger seat (video and trigger wires) rear camera power was taken from the towbar reverse pin and front is going to run via the switch on the dash. Will post all relevant photos as soon as the front camera is in and working
Live to Explore!
__________________
Live to Explore !!!
  #35
Old 20-10-13, 10:27 PM
echochaser's Avatar
Member
Great stuff!
Cant wait to see!
  #36
Old 21-10-13, 05:15 AM
marnix's Avatar
Member
Hi echochaser - thought there may have been something ported across...
  #37
Old 21-10-13, 01:10 PM
Schumi's Avatar
Member
Hi all
My cameras is in and working beautifully. Install was easy the steps as follows
1. locate the wiring plug under the front passenger seat
2. Install and pull wires thru chassis and thru the grommet also under the seat
3. Connect the wires as per photo (this took time to locate which wire goes where)
4. Install a relay to swith between front and rear while in reverse
5. Install a diode on the radio feed to prevent power back flow to the relay and install the switch for the front camera
6. Test before closing
Live to Explore!
__________________
Live to Explore !!!
  #38
Old 28-10-13, 08:28 AM
Beebob Beebob is offline
Member
I would like to fit a reverse cam to my 2012 hilux 3.0D4D But I have heard the Heritage model has a different radio in for the reverse cam, And that the non heritage model's radio will not have the video feed option. can someone please clear this up for me.
  #39
Old 29-10-13, 12:19 PM
Member
Picture of the head unit fitted to your Fortuner?
  #40
Old 12-11-13, 05:18 PM
Member
Quote:
Originally Posted by paler View Post
***UPDATE***
Figured it out, apparently the head unit checks for a camera signal upon startup. If the signal is not there it will not switch the screen when reverse is engaged.
To solve this I powered my camera via an ACC 12 V + instead of a lead that was hot on reverse only. My generic camera only had 4 wires: 12 vdc+, 12 v - ground, video +, video -.
Hope this helps!
My rig is a 2012 D4D 1KD, Americas version, LHD ... and I love it!
  #41
Old 14-11-13, 11:03 AM
Wanderlust_SA's Avatar
Wanderlust_SA Wanderlust_SA is offline
Member
I believe the OEM radio for Hilux/Fortuner with cam capability is very expensive.
Has anyone fitted a 3rd party radio and did a DIY on the reverse camera?
I'm looking to do it on my 2008 Hilux.
  #42
Old 03-01-14, 10:13 PM
yster130 yster130 is offline
Member
Thumbs up
Try keeping the mode button in for second,workon mine
  #43
Old 07-01-14, 04:52 AM
marnix's Avatar
Member
No mode button on my radio (I have the same as the one pictured above) :-(
  #44
Old 07-01-14, 04:53 AM
marnix's Avatar
Member
I have also been told by Toyota that my 2013 Fortuner no longer supports auto-lock on the doors above 25kmph. I find this unbelievable in a country like SA - does anyone know why this is the case?
  #45
Old 07-01-14, 09:25 AM
riyadh's Avatar
Member
Yes, I find this ridiculous. I have my very first Toyota and it is a Love Hate relationship. I love the way the car drives, and even more in the effortless way it behaves offroad. I hate the funky electronics, that for me seem it was just put in to keep up with competitors. I like the electric seat, but there is no memory function. The interior is plastic, much like the chinese and korean conterparts etc. I have to admit, I prefere the build qaulity of european cars. However I am still loving and hating my fortuner. LOL
  #46
Old 13-03-14, 02:59 AM
trini hilux trini hilux is offline
Member
I have a 2013 hilux and trying to connect a reverse camera. the wires are just like the pictures from Toyota King post, but when I connect the black and red wires the speakers are humming and its not going to video mode. Can any one help me?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Super rugby log ? duncang The 4x4 Pub 11 17-02-11 09:22 AM
Fortuner trip computer in Hilux martins Toyota 0 03-09-08 03:58 PM
Template-Modifications by TMS
