logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Land Rover
4x4Community
Land Rover Go Beyond! The best 4x4xfar!
Reply
Thread Tools Display Modes
  #1
Old 20-01-12, 10:40 AM
WynandV's Avatar
WynandV WynandV is offline
Member
Default Defender ECU Problems - Mysterious circumstances
About two weeks ago I took my Defender 90 TD5 to a reputable (apparently) independent workshop in the north of Pretoria for a major service. Yesterday morning when I got into the car to drive to work I noticed that the glow plug lights didn’t come on when I turned the key, the engine turned but there was no ignition. I didn’t find it strange at the time because it happens from time to time due to oil in the wiring loom. Normally I would jump out, open the ECU compartment, remove the red plug, clean out the excess oil with a tissue and spray a little electro clean that I carry around in the car with me, plug it in and off I go.
This time when I opened the ECU compartment I was horrified at what I saw…………… When I removed the red plug I immediately noticed that it looked different than when I last saw it, the white cover covering the holes was gone exposing the brass connections, I also noticed the orange plug seal lying on the bottom of the compartment. What also alarmed me is the fact that one of the four bolts anchoring the ECU to the body was missing. After cleaning out the plug and spraying a little electro clean I plugged it in and turned the ignition, but alas, no action!!!
I was really shocked at what I saw, because I know for a fact that this was not how everything was when I left my vehicle there for the service. The ECU was properly fastened to the body with four bolts and the red plug had a plate covering the brass connections, the same as the black plug. I was there this morning to confront them with this but obviously they denied everything and I have no proof that they tampered with the ECU. Maybe I was naďve in thinking that they would’ve confessed and at least tried to see if they can help me……………… Without wanting to throw anymore mud I left realising that I’m not going to win any battles there and I have to resolve this on my own. Obviously I cannot blame the fact that my vehicle is not running at the moment entirely on them because the thing ran properly for two weeks since my service, but in the same breath there is physical proof that there was tampering and what is to say the fact that my vehicle is standing is not as a result of that?
The bottom line to me is this: There is oil in the harness, I know that, it might be the cause of the oil, it might not. What is absolutely certain, without any doubt, is that there was definitely tempered with my ECU. When I last cleaned the ECU plug was at the beginning of January and everything was in order and intact. Now all of a sudden for some unexplained reason there are two parts missing, a bolt and a plug cover plate……………………
The reason for my post is not only to rant out my frustration but also to ask advice. What can I do to get my vehicle running again? How would I find out if it is the ECU causing the trouble or the plug or the wiring? If the ECU is fine, do I have to replace the plug? Do I have to replace the whole wiring loom? I would greatly appreciate it if anybody can assist.
ID:	128532   Click image for larger version
ID:	128533   Click image for larger version
ID:	128534   Click image for larger version
ID:	128535   Click image for larger version
ID:	128536   Click image for larger version
__________________
2012 Defender 110 Puma 2.2
Ex: 2004 Defender 90 TD5
  #2
Old 20-01-12, 10:54 AM
ProtZkroG ProtZkroG is offline
Member
So jy kan tans glad nie die kar start nie?
As jy kan - neem hom dalk British toe laat hulle kyk?
__________________
2001 Land Rover Defender TD5 110
  #3
Old 20-01-12, 11:01 AM
TwinDisco's Avatar
TwinDisco TwinDisco is offline
Member
My suspicion is that they swopped your ECU with a suspect one from another client, and they charged the other client for that... now they wait to make money out of you sitting with a suspect ECU
__________________
1999 Disco 2 ES 4.6 V8 Auto SWAMBO
2000 Disco 2 GS 4.6 V8 Auto
2013 Wildebeest Kalfie Boswa
ORRA Z07
  #4
TwinDisco's Avatar
Member
Waar in Pta is jy WhyNot?
__________________
ORRA Z07
  #5
Old 20-01-12, 11:03 AM
josephpo josephpo is offline
Member
reputable you say?
maybe also check your fuses and glow plug relay
__________________
Defender 110 Puma
BMW 320i
Yamaha XT660z
Gautrain
  #6
Old 20-01-12, 11:04 AM
TwinDisco's Avatar
Member
What is the ECU number/code? The earlier ECU's were not programmable, and the later ones were programmable. More demand for the later programmablle ones.
__________________
ORRA Z07
  #7
Old 20-01-12, 11:06 AM
bvandyk's Avatar
bvandyk bvandyk is offline
Member
Quote:
It's a 2004 model TD5 so most probably one of the later ECU's
__________________
Land Rover Defender 100 PU V8
TDV6
  #8
Old 20-01-12, 11:09 AM
Fluffy's Avatar
Fluffy Fluffy is offline
Member
I don't know about the Defender, but even my 2000 RROver has the VIN number encoded in the ECU.
Maybe somebody with a diagnostic can have a look for you.
__________________
ZS5KAD Yeasu Ft-897D
NB - I don't do PV Solar Systems - YET!
The nice thing about FRIDAYS, its only two more days until MONDAY.
People that know me know that I skrik vir niks, except high Voltages, High Currents and High Prices.
  #9
Old 20-01-12, 11:13 AM
TwinDisco's Avatar
Member
Apparantly from 2003 the TD5 was fitted with the programmable ECU, NNN 120 for manual, and NNN 130 for auto.
I donk know if Land Rover has a record of the ECU serial number that was factory fitted to your Landy..
__________________
ORRA Z07
  #10
Old 20-01-12, 11:14 AM
FCSteenkamp's Avatar
FCSteenkamp FCSteenkamp is offline
Member
+ 1......I know "WhyNot" personally and he is quite particular when it comes to his D90 aka banana-van . He knows about every
scratch, stain, oil-leak, bump and all other issues of by hart and all have their story. He knows what is going on under that drivers seat and in what state he left it.....I can personally vouch for that!!!
Die goed maak my net moerig..
__________________
2012 Land Rover Defender 110 2.2 Puma
2004 Land Rover Defender 90 td5 (SOLD IT)
  #11
Old 20-01-12, 12:16 PM
Crips's Avatar
Crips Crips is offline
Member
I would like to know to which indy you took your defender too, even if you just pm me?
They will not ever see my defender...
__________________
Chris
"Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure, or nothing" Helen Keller
2005 LandRover Defender 110 D/C TD5
1977 LandRover Series III 109" Project
chairman@4x4actiongroup.co.za
www.4x4actiongroup.co.za
  #12
Old 20-01-12, 12:39 PM
Spectator's Avatar
Spectator Spectator is offline
Member
If it's the case, this is the second story I have heard of in the last few months of independant LR workshops doing part swopping...
__________________
Car - Defender 110 V8
Appliance - Prado 4.0 VX
"Do not try to win over the idiots - you are not the Jerk Whisperer.."
  #13
Old 20-01-12, 12:46 PM
Hagu13's Avatar
Hagu13 Hagu13 is offline
Member
I've been having similar issues lately with my Disco TD5- it intermittently won't start.
First time- no glowplug light, engine cranked but no fire, problem went away on its own after 30 seconds.
Second time- no glowplug light, no cranking. It's not my starter as I sorted that out 6 months ago. problem persisted until I took key out, locked car and unlocked again using remote on key, then it was fine.
First issue was a month ago, second one last week. Too early to diagnose plus I've just been too busy to scratch around, but maybe bad alarm/immob unit??
My ECU plugs are clean.
__________________
Rob
V8 Defender 90 pickup. Lexus, Spitronics, 33" KL71, beadlocks, +2" Terrafirma, ATB's, 3.75 CW&P, 1.21 TC.
Series IIA 88" pickup
V8 Shamrock Cobra 350
MG TF160 VVC ZandF remapped
MG TF135
BMW 330d remapped. Blandmobile econobox
Buell XB12R
  #14
Old 20-01-12, 12:49 PM
Sawdust's Avatar
Sawdust Sawdust is offline
Member
The ignition relay, yellow relay sometimes makes poor contact. It is the 2nd one from the back. Remove it and swop it with the 3rd one from the back which is the AC relay. I did that in December after having a similar problem. It still runs fine.
A new relay from Ford will cost R75.
The orange seal sometimes pops out when the plug is cleaned and there is still some solvent in the plug. The white contact "separater" should still be there. Maybe they cleaned the plug and the ECU during the service and did not replace it all properly.
OK I see your relays are not all yellow. They are all the same in any event. Just swop the 2nd and 3rd one to check anyway.
__________________
2004 Defender 110 Td5
  #15
Old 20-01-12, 12:57 PM
bvandyk's Avatar
Member
Whats the chances of the screw being missing since you've had the landy?
And only seeing it now.
As said above, maybe they cleaned the plug as part of the service.
Phone them and pretend to be a new client and ask them if cleaning this plug is part of the service.
__________________
TDV6
  #16
Old 20-01-12, 04:32 PM
WynandV's Avatar
Member
Hi Ben,
I know that bolt was there because I've seen it many times before. When I was there this morning they clearly said that they never touched my ECU, he would only touch my ECU if there was an instruction on the job card and there was not.
__________________
  #17
Old 20-01-12, 04:36 PM
WynandV's Avatar
Member
Hi D,
Ja die kar staan by die huis en kan glad nie start nie.
__________________
  #18
Old 20-01-12, 08:06 PM
Hello2Africa's Avatar
Hello2Africa Hello2Africa is offline
Member
Hi Whynot,
Bel my in die oggend , wil net n paar goed by jou uitvind, kan jou dalk in die regte rigting stuur.
Groete
Pierre
0-8-3-6-3-7-9-8-3-3-
__________________
Live today as if it’s your last day to make a change in this world. Cause tomorrow is promised to no one.
Driving the BEST 4x4's
  #19
Old 21-01-12, 02:54 PM
WynandV's Avatar
Member
I've fiddled with the relays today and it seems as if it has done the trick........ My landy is running again, yeah!!!!!!!
I still don't know what the cause of the problem is, I'm just glad that the ecu is still working. I've made an appointment with a Land Rover mechanic that I got in touch with through a work colleage. He said he will be able to sort me out, so hopefully after that I will know what EXACTLY causes this fault.
Sent from my BlackBerry 9900 using Tapatalk
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Advice on TDI defender heating problems ngweshla Land Rover 21 04-11-09 02:34 PM
Defender 90 Tdi 300 - Deep Water Wading Problems Defenderman Land Rover 3 18-08-09 05:51 PM
Transfercase and propshaft td5 defender problems Senna Land Rover 6 27-05-09 09:36 AM
Defender Fuel Cooler Problems Vaal japie Land Rover 1 15-07-08 12:21 PM
95 Defender CS tdi - Problems? rattle&hum Land Rover 7 16-02-08 07:36 PM
