logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Land Rover
4x4Community
Land Rover Go Beyond! The best 4x4xfar!
Reply
Thread Tools Display Modes
  #1
Old 06-01-12, 03:41 PM
GrahameG GrahameG is offline
Member
Default Defender Speedo Unit
Hi All,
The LCD mileage (kilometerage?) display on my 1998 Defender 90 2.8i has been flickering on & off for a while, but has now given up the ghost. Having been told that the cause is likely to be dirty contacts on the LCD screen I took out the speedo, but as far as I can make out it is a sealed unit, so I can't get to the screen without cutting the casing.
Am I missing something?
Not keen to cut without having located a spare speedo in case, & if I have a spare speedo there's not much point in cutting!!
Grahame
__________________
1998 Defender 90 2.8i "Malutka"
2011 Ranger 3.0 Super Cab
  #2
Old 06-01-12, 04:12 PM
albertvl's Avatar
albertvl albertvl is offline
Member
Mine does the same - it is caused by rainy weather. I first thought it was because I drove with the flaps open when it rained, but it now happened when my Landy was parked in the garage (while it rained). The good news is that it fixes itsself after a week or so of dry weather. Maybe wait a little before cutting the thing open.
__________________
Land Rover Defender 90 2.8i
Remember children, you can't spell "slaughter" without "laughter".
  #3
Old 06-01-12, 04:39 PM
Member
Hi Albert,
Thanks for the reply but unfortunately wet weather doesn't seem to be the cause - last sign of life was about 3 or 4 months ago, and there's been no rain down here (Western Cape) for the last month or 2. A good run on rough roads used to get it working, (which seems to gel with the poor/dirty contact theory), but thats no longer working!
grahame
__________________
  #4
Old 07-01-12, 07:09 AM
johnnybritz johnnybritz is offline
Member
mine is also weather related and its frustrating i wonder if maybe i cant fit another defenders speedo.
if somebody has done it please inform us
  #5
Old 07-01-12, 07:59 AM
Lewis Lewis is offline
Member
Try spraying some electrical spray onto the plug at the back of the speedo, if this doesn't work you can strip the speedo to see if the flex cable is still properly attached,
http://www.d-90.com/forum/showthread.php?t=3035
Credit to user Astoltz for previously posting this link.
  #6
Old 07-01-12, 08:45 AM
Member
Lewis,
Thanks for the link - answered my query & a whole lot more.
Seems a bit of an ongoing problem but am going to give it a try
__________________
  #7
Old 07-01-12, 08:53 AM
Member
Pleasure, before you open your speedo, try the electrical spray does wonders, it is fairly dusty at the back on the dials.
  #8
Old 07-01-12, 08:59 AM
albertvl's Avatar
Member
Spraying the back didn't work for me, I'll try opeining the speedo over the weekend
__________________
  #9
Old 07-01-12, 09:02 AM
Member
Hi Albertvl, did you spray the plug and the speedo ?
  #10
Old 07-01-12, 09:15 AM
albertvl's Avatar
Member
I'm not sure. I unplugged the white electrical connector at the back and sprayed it. I can't recall now what else was at the back of the speedo unit.
__________________
  #11
Old 07-01-12, 01:11 PM
lrswb's Avatar
lrswb lrswb is offline
Member
If everything else fails try Combined Electronic Services, 6 Privet Street, Plattekloof 021 930 3549/87. Take the Landy to them and talk to Henry - he fixed mine. He does work for BMW, Mercedes, Audi etc and know what he's doing.
__________________
1952 Land Rover Series I 80" 2-litre ioe tilt (project)
1975 Land Rover Series III 88" 2.25 p soft top (workhorse)
1998 Land Rover Defender 90 2.8i CSW (expedition vehicle)
1977 Land Rover Series III 109" 2.25 p station wagon (sold)
  #12
Old 16-01-12, 01:22 PM
Armandt Booysen Armandt Booysen is offline
Member
Hi, i would just like to know if anyone managed to sort out the speedo problem? I also own a '98 D90 2.8i and my clock was replaced by the previous owner @ 130 000 and it shows only 29 000 on the new one....does anybody know how to get the lcd to reflect the actual mileage?
  #13
Old 16-01-12, 03:50 PM
albertvl's Avatar
Member
Drive 100 000km to fix your problem
I managed to open my speedo quite easily and cleaned the ribbon connector with spiritus. Be careful if you are considering this - the conductive strips on the ribbon dissolve quite easily. I sealed the back of the speedo with a plastic baggie. It helped but is not 100% My next step will be to put a few silica gel packets (the stuff inside pill containers) inside the plastic to keep the air dry
__________________
  #14
Old 16-01-12, 04:10 PM
Member
HAHAHA or i could do that yes.....:-)
Oh good! Thanks, i will keep it in mind and definitely open it up if needed.
  #15
Old 17-01-12, 10:37 AM
Member
Well I eventually got round to spraying the connectors on the back of the speedo - didn't help, so removed & opened speedo.
When I saw the conductive strip I decided not to touch it if at all posible - far too delicate for fingers more used to 15cm & larger spanners!!
Did give it a good spray before closing up, but that didn't help either.
Looks like I'll be paying Combined Electronic Services a visit on the next visit to Cape Town.
__________________
  #16
Old 17-01-12, 08:53 PM
albertvl's Avatar
Member
Opening the speedo is much harder than removing the ribbon, just take a small little flat screwdriver and pop the top of the connector on the pc board open. The ribbon then slides out easily. This is really easy, if you have to use force it means you are doing it wrong.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Defender vs Cruiser 70 vs Wrangler - Who is the top dog! Defenderman Land Rover 83 24-12-12 10:15 AM
Portable Aircon / Air cooler Boeta The 4x4 Pub 20 18-01-10 12:29 PM
Defender td5 fuel sender unit Jon747 Land Rover 1 06-01-10 08:20 PM
Reborn Defender - still rugged, but gone upmarket rssFeedMonster Land Rover 29 23-07-08 09:39 PM
Template-Modifications by TMS
