logo
Go Back   4x4 Community Forum > General Category > Camping, Fridges, Accessories
4x4Community
Notices
Camping, Fridges, Accessories All those other small items relating to vehicle accessories, camping.
Reply
Thread Tools Display Modes
  #1
Old 13-06-07, 11:25 AM
Cherokee Cherokee is offline
Member
Default Standard trailer wiring diagram (colour coded)
This diagram is always handy to have around . Laminate it and stick it onto the trailer and glove compartment of your towing vehicle. I Always bridge no 6+7
__________________
Defender Puma 130
Don't follow me, you won't make it!!
  #2
Old 13-06-07, 11:46 AM
BigRed's Avatar
BigRed BigRed is offline
Member
Which diagram? I canna see one
__________________
"A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster "
By Jeremy Clarkson (I think)
  #3
Old 13-06-07, 12:07 PM
Bundu Bundu is offline
Member
also cant see anything (but available on the net at lots a places)
WIRING DIAGRAM TAILGATE ( TRAILER) SABS 1327 - 1981
1.-----LEFT INDICATOR -----YELLOW
2.-----AUXILIARY--------------BLUE
3.-----EARTH--------------------WHITE
4.-----RIGHT INDICATOR-----GREEN
5.-----RIGHT TAIL-LIGHT-------BROWN
6.-----STOP LIGHTS------------RED
7.-----LEFT TAIL-LIGHT---------BLACK
__________________
Hein
Mazda Drifter 2.5TD D/Cab 4x4 "BURAWA"
  #4
Old 13-06-07, 12:09 PM
Member
[quote=Cherokee;95259]This diagram is always handy to have around . Laminate it and stick it onto the trailer and glove compartment of your towing vehicle. I Always bridge no 6+7
__________________
Defender Puma 130
  #5
Old 13-06-07, 12:48 PM
LowRange's Avatar
LowRange LowRange is offline
aka DiscoV8
Cherokee
One very important piece of info missing from your diagram - Are you looking at the plug from the front or the rear? The male or the female?
Talking from experience
Johan
__________________
2004 Pajero DiD GLS with a few mods
2009 Jurgens Xplorer in tow
  #6
Old 13-06-07, 12:58 PM
4ePajero
Guest
Posts: n/a
This is a wiring diagram for a 12n, 7 pin standard trailer socket.
This is the view from the rear as you look at the terminals to wire the plug or socket. In all cases the terminals will be numbered.
  #7
Old 13-06-07, 01:54 PM
LowRange's Avatar
aka DiscoV8
I have seen case where te terminals are not numbered - My current luggage trailer has been "rewired" a number of times by "friends" borrowing it and then returning it modified
No numbers on the terminals.
Johan
__________________
  #8
Old 13-06-07, 07:37 PM
Khosaan's Avatar
Khosaan Khosaan is offline
Member
Quote:
Can we get a Sticky on this one?
__________________
Ettienne Myburgh
Nissan Patrol 4.8GL OME, ARB, Drawers, 2nd Battery
Challenger Off-road trailer with Howlin Moon tent
  #9
Old 14-06-07, 07:53 AM
Member
Muuchh better!!
__________________
Defender Puma 130
  #10
Old 14-06-07, 08:23 AM
Henris's Avatar
Henris Henris is offline
SIR
Here is the diagram that is on the venter website.
http://www.ventertrailers.co.za/prod...d=212&subid=28
__________________
GX LC80 D/C 1HD-FTE(Manual injector pump)
1998 Hilux 4x4. (Long term D4D project)
  #11
Old 14-06-07, 02:36 PM
jbeez's Avatar
jbeez jbeez is offline
Member
I see Pin 2 is for a fog light. Why would no-one evr have bothered to wire a reverse light in?
__________________
Johann Bredell
1996 Pajero 2800 tdi
  #12
Old 15-06-07, 02:21 PM
benhur's Avatar
benhur benhur is offline
Member
Location: Tswane se gat ek bly nog lekker hier in Pretoria!!!
Quote:
Pin 2 is for auxiliary (12V+) supply for stuff that needs 12V in the trailer.
Theoretically you should be able to charge a battery or run a fridge off it in the trailer/caravan, but these pins seldom gets wired or if they are wired the wires are to thin and the voltage drop too much and the current flow too restricted. I wired a 4 mm conductor in my folks' bakkie straight from the battery to supply power to the caravan, via a proper fuse off-course. You can also add a relay to switch it on/off together with the car's ignition.
__________________
4.0 Prado VX and SFA Hilux
  #13
Old 19-07-07, 08:13 PM
Ratsalad's Avatar
Ratsalad Ratsalad is offline
Member
The diagrams are all for the trailers. Does the same colour wires go on the female (car) side of the plug? I need to refit my tow bar and plug for the weekend.
__________________
Chris Bruce
1996 Pajero 3.5 LWB
  #14
Old 19-07-07, 09:07 PM
benhur's Avatar
Member
No the guys use any colour they like when wiring a car. You will have to get a test lamp to figure out what wire goes where.
__________________
  #15
Old 19-07-07, 09:15 PM
Henris's Avatar
SIR
http://www.ventertrailers.co.za/imag...IAGRAM-big.jpg
Here is the diagram
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Reversing with a trailer behind your 4x4? Big Hilux Vehicle & Technical Chat 44 04-02-13 12:51 PM
looking for wiring diagram land cruiser rockridge Toyota 2 27-03-11 07:01 PM
Wrangler 2dr Wiring Diagram for TJ Wranglers. General Patton Jeep 6 29-12-10 02:39 PM
Leo or Conquest s - some advice needed? Wiv Camping, Fridges, Accessories 9 02-09-07 10:49 PM
Trailer plug wiring Hobo Camping, Fridges, Accessories 2 30-03-07 02:15 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Template-Modifications by TMS
