logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Land Rover
4x4Community
Land Rover Go Beyond! The best 4x4xfar!
Reply
Thread Tools Display Modes
  #1
Old 11-04-13, 03:40 PM
Clyde B's Avatar
Clyde B Clyde B is offline
Member
Default Disco 3 - Fuel Contamination Problems
Hi,
Been having some problems with my TDV6 HSE. When I give full acceleration, the car will go but eventually will stop accelerating. Almost like the accelerator does not function. If I push the car into neutral whil it is going, leave for a few seconds and then back into drive again, the car will continue going, provided I do not accelerate heavily. I can drive the whole day like this but it will only happen when I accelerate heavily. It also seems like it has a jerk or miss at certain revs and also like a "whoo-whoo-whoo" sound that can be heard when accelerating. This seems to be getting louder and I seldom drive the car.
After some testing, I sent it in for a fuel test and the Diesel Analysys Report failed stating that the Water Content Exceeds Specification. The car's fuel is contaminated which upon recollection, can be from a trip to Mozambique late last year when I had to fill up diesel there. I have been using 2SO in the vehicle to help prevent this from happening.
Anyway after some fights with our insurance company who will not pay, I will be fixing myself.
Sent the car in to get the tank flushed and a new fuel filter installed. They have done some tests after completion with the following results;
  • P034100 - Camshaft position sensor A (bank 1) outside specified range
  • P228800 - Rail pressure - pressure too high
  • P193400 - Driving speed signal - signal improbable
  • P120E00 - Unknown fault
They have also mentioned that the test of the injectors are not up to spec and they would need to be replaced - about R35000. The injector correction values for injectors 1-6 respectively are: 1047.52, 926.99, 1160.25, 962.95, 946.51, and 950.50.
After getting advice from some members on the forum, I was told to purchase 3 litres of Liqui Molly Diesel Purge along with 500ml 2SO. Add to the tank when the reserve light comes on and take for a good belt, keeping the revs up at all times. This still did not help.
I do not just want to replace the injectors as this is a very expensive option and would leave as a last resort. I do not notice the car smoking but this is from the drivers seat and I have not driven behind the car. I have also heard that injectors do not just pack up and that they can be cleaned ultrasonically or something like that. Is this the case?
What would you see as the way forward with this?
I am in Pietermaritzburg and would need to take to someone that can fix. Who would you recommend?
Regards,
Clyde.
__________________
Defender 110 Td5
Disco 3 TDV6 HSE
  #2
Old 11-04-13, 03:42 PM
PUW's Avatar
PUW PUW is offline
Member
Also check ECU behind battery for water contamination on the terminals.
  #3
Old 11-04-13, 03:52 PM
faniedup's Avatar
faniedup faniedup is offline
Member
Did you change diesel filter as well?
  #4
Old 11-04-13, 04:01 PM
Clyde B's Avatar
Member
PUW, I will check the ECU.
Faniedup, yes the diesel filter was replaced.
__________________
Defender 110 Td5
Disco 3 TDV6 HSE
  #5
Old 11-04-13, 07:53 PM
hgbosch's Avatar
hgbosch hgbosch is offline
Commercial Member
HI Clyde
take the vehicle to Landyorx in Randburg. Peter can sort it out. If he cannot, then it is time to put a match to it
Just kidding
Landyworx can have the injectors tested and rebuilt, if necessary. Also the electronic side can be sorted out inhouse.
Good luck!
__________________
with kind regards
George Bosch
________________________
2003 RangeRover Vogue 3.0 Td6
2005 LR Disco3 TDV6 S
1998 Disco1 Tdi ES (Sold)
And some more serious stuff
Distributor for:
  #6
Old 12-04-13, 10:25 AM
Clyde B's Avatar
Member
George,
I might just take the plunge and drive the car up to Randburg and leave it with Peter for a couple of days.
Clyde.
__________________
Defender 110 Td5
Disco 3 TDV6 HSE
  #7
Old 12-04-13, 10:32 AM
RobH's Avatar
RobH RobH is offline
Member
My old D3 suffered from water contamination. I had to replace both fuel pumps and all the injectors, cost to the garage was R52k. At the time there was no-one who could rebuild the injectors. Paul at The Centre in Durban sorted it out for me.
PS. How are you going to drive the car to Jhb on bum injectors, surely it will do more long term damage?
  #8
Old 12-04-13, 10:40 AM
Silver Shadow's Avatar
Silver Shadow Silver Shadow is offline
Member
Quote:
One can buy a lot of petrol for that money.
__________________
Discovery 3 V8 SE
Self designed Rock and Tree Sliders.
Next: Project Bashplate
1981 Series 3 S R6 88" Allmost Perfectly Restored
  #9
Old 12-04-13, 10:45 AM
RobH's Avatar
Member
Quote:
Mine wasn't the only vehicle; at the time I did a quick tally and reckoned the garage and his insurers were in for about R750k, and that was only on the vehicles I had heard about.
  #10
Old 12-04-13, 10:48 AM
Member
Thats crazy money.
__________________
Discovery 3 V8 SE
  #11
Old 12-04-13, 02:24 PM
Clyde B's Avatar
Member
RobH,
I am able to drive the car on those injectors as long as I do not increase the revs over a short period of time, like not accelerating drastically. If I steadily accelerate, the car goes okay and should get to Jhb quite fine.
I do not know about the long term damage. There might not be any as the injectors will be re-built anyway.
__________________
Defender 110 Td5
Disco 3 TDV6 HSE
  #12
Old 12-04-13, 03:37 PM
faniedup's Avatar
Member
I would not drive it that far, stuffed injectors ends up with spray patterns that burns holes through pistons at times.
  #13
Old 12-04-13, 06:02 PM
DiscoFrans DiscoFrans is online now
Member
Fanie is reg.Be very careful.....the HP diesels will not tolerate faulty injectorsSerious damage
Frans
__________________
2006 TDV6 SE A/T NL split charge,HcdP DC/DC charger,Big Country RR,FR Bash plate,EGR's Blanked,cat removed,interior LED's,Cooper A/T3(265/65-17)
2013 Bush Lapa Boskriek B142
2008 FL2 TD4 SE A/T
1968 Renault 8 Gordini
109 s3(Sold)
1983 RR Classic(Sold)
1993 RR Classic(Sold)
  #14
Old 13-04-13, 08:13 AM
RobH's Avatar
Member
Let me second what Danie and Frans have said, be very careful driving with stuffed injectors. I drove about 25km to my indie, very slowly and without accelerating like you said, and my vehicle went into limp mode on at least 3 occassions - it does this for a reason, to protect your vehicle from further damage.
Rather give Peter a call and get a verbal quote / assessment, and take it from there.
  #15
Old 15-04-13, 10:34 AM
Clyde B's Avatar
Member
Thanks all, concerns noted. I will give Peter a call and see what he says.
Clyde.
__________________
Defender 110 Td5
Disco 3 TDV6 HSE
  #16
Old 28-05-13, 12:22 PM
Clyde B's Avatar
Member
Guys, just and update.
I have had a chat to Peter on various occasions and I am persuing the repair of my car. Upon his instruction. I have taken her to a local indie in PMB and the following has been done as:
1. Diagnostics done
2. Camshaft sensor replaced
3. CAT removed
4. EGR removed
5. Exhaust pipe replaced as it was damaged
6. Diff oil replaced
The problem is still evident.
Have now started with a diagnosis of 2S0, deisel purge and injector cleaner to try and clean out the injectors. This will be done for the next two tanks to see how the injectors respond at the next diagnostics.
Will keep you posted.
Clyde.
__________________
Defender 110 Td5
Disco 3 TDV6 HSE
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
2 stroke oil in diesel? Bruce_1 Vehicle & Technical Chat - General 225 07-08-13 08:16 PM
WJ 2.7 CRD Maintenance wtrlan Jeep 198 04-05-13 11:08 AM
Musing on modern day vehicle electronics and the duality of man IanG Vehicle & Technical Chat - General 21 13-04-12 03:33 PM
Mixing 2-stroke oil into Diesel hgbosch General (non vehicle/technical) 4x4 Discussions 437 03-01-11 01:11 AM
Defender Fuel Cooler Problems Vaal japie Land Rover 1 15-07-08 12:21 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
Template-Modifications by TMS
