logo
Go Back   4x4 Community Forum > General Category > 4x4 Recovery & Recovery Gear
4x4Community
Reply
Thread Tools Display Modes
  #1
Old 13-09-06, 11:28 AM
4x4 4x4 is offline
Member
Default Snatch strap vs Snatch rope
What's the difference between the two?
The strap needs 5 to 10 hours recovery time. The rope doesnít.
The strap can be used 10-12 times while the rope can be used 50 times.
Is this true?
Anyone know?
__________________
Deon Kotzee
Heidelberg
1999 Colt Rodeo 3.0 4x4 (Blue)
  #2
Old 13-09-06, 01:11 PM
Musashi's Avatar
Musashi Musashi is offline
Member
Default Re: Snatch strap vs Snatch rope
As far as I know yes, but I may be wrong. That is the reason the rope is more expensive.
__________________
Niel
2012 BMW F800GS
  #3
Old 13-09-06, 01:20 PM
Ralph_Clark's Avatar
Ralph_Clark Ralph_Clark is offline
Commercial Member: Adventure 4x4 Academy
Hi Guys
The fibre used in both is the same and comes from France so I don't think the recovery time would be that different. The key difference lies in the ropes ability to release trapped dirt while the strap often gets grains of sand or mud trapped between its fibres. The rope should last longer.
I would not be so specific on the number of pulls either because there are many forces of varying degree during each and every recovery. The simple rule of thumb is let the rope or strap settle for 24 hours and then measure it. If the rope hasn't returned to it specified length e.g 9 meters, it is damaged and should be used as pull strap and not for kinetic recoveries.
Ralph
__________________
Partner Adventure 4X4 Academy
http://www.4x4training.co.za
  #4
Old 13-09-06, 02:09 PM
Barto's Avatar
Barto Barto is offline
Moderator (aka Zantus)
Here are some previous comments regarding this subject by Micheal Green, of Securetech/Spanset, who's also a member of this forum.
There is some more and I'll post it when I find it
Quote:
good morning
no two recoveries are the same
each recovery is dependant on the following factors which will shorten or lengthen the kinetic recovery strap or ropes life span
(1)mass of the stuck vehicle
(2)mass of the tug vehicle
(3)speed of the tug vehicle
(4)how badly is the vehicle stuck
(5)stuck in mud is not the same as been stuck in sand
(6)how the kess / kerr is stored after recovery
(7)how many times in a 24 hour period the kess/kerr is used
(maintenance program
(9)distance travelled
a rope and strap is made out of the same material and therfore have the same or similar properties
(1)they will or must eventually wear out
(2)both require a recovery time period
how a kerr / kess works
(1)a kinetic recovery works because of the conversion of potential energy into kinetic energy
(2)imediate recovery ( the part that does the work)
(3)latent recovery ( the part that requires 12 to 24 hours to recover)
(4)these rules apply to both types of equipment
it can therefore be concluded that in principle there is no real difference between a strap and a rope and the rules for the strap applies to the rope and visa versa
difference between a kess and kerr
(1)kess is cheaper (kerr is about 2 or 3 times more expensive)
(2)kess has slightly less elongation 20% - 30% (kerr is about 30% - 40 %)
(3)kess packs into about 1/4 of the size of a kerr
in europe more ropes are used (as they have not had webbing available) while in australasia more kess are used (this is trend we follow here is south africa)
there is different elongation between a wet and dry strap/rope, there is also a different break strength between a wet and dry strap/rope
kess = kinetic energy snatch recovery strap
kerr = kinetic energy recovery rope
SECURETECH / SPANSET products available from Makro stores
hope this helps
M K G
Quote:
Good morning
Makro sell a 16 ton 10m Spanset / Secure-tech kinetic snatch strap and rope. No other independant dealer except Safari Centre in Cape Town believes that there is demand / requirement for such an article. If you have no success in locating one please reply and we will assist further in trying to locate one or deliver one to you.
As far as using two snatch straps in parallel we would NOT recommend such for the following reasons:
1- They would have to be the exact same length
2- As these items are made made/woven no two batches are exactly the same ellongation
A snatch strap/rope is worn out by the following:
1- Used more than once in 24 hours
2- Incorrect storage
3- Overloading
4- Incorrect material finishing
and many more
Quote:
#1~ Spanset/Secure-Tech have launched a NEW snatch rope with a minimum break strength of 8000kg and 16000kg / 9m and 10m supplied in a heavy duty Cordura type storage bag
#2~ Snatch strap/rope must be manufactured from high tenacity high elongation polyamide yarn. One cannot tell the difference between a snatch rope/strap and tow/pull rope/strap by feel or appearance. If the strap/rope is not labelled for application then treat it as a pull/tow rope/strap, because one will do major vehicle damage if you use a pull tow as a kinetic snatch recovery as polyester elongates by only 5-8 % at break.
#3~ A snatch rope/strap needs to be no shorter than 9m metres because one needs to be able to obtain a speed of between 15 - 30 km/h to energise the strap/rope.Snatch straps/ropes are available in any length up to 100m. With a 6m strap/rope you will not be able to create enough energy for the strap/rope to work effectively. Remember a snatch strap/rope works for one reason only - the towing vehicles kinetic energy is converted into potential energy of the stretched rope/strap. The energy is transfered by the rope to the bogged vehicle.
#4~ The individual who secures his strap/rope temporarilly or permently around his/her bull is looking for short to long term trouble. As straps/ropes are manufactured from textile they degrade over time with continuos exposure to weather and UV. Kinetic ropes/straps are especially susceptible to rotting as they absorb moisture and will rot if kept wet. Store in a cool dry place out of direct sunlight.
  #5
Old 13-09-06, 02:34 PM
Barto's Avatar
Some more:
Quote:
Good afternoon
Special Industrial Supplies (Pty)Ltd is a Randburg based company manufacturing, importing and distributing the following products :
-lifting equipment
textile flat webbing slings
textile endless roundslings
chain slings
steel wire rope slings
shackles, chain blocks, crane scales etc etc
-lashing equipment
ratchet tie downs
cam buckle tie downs
chain load binders
textile rope
-automotive seatbelts
3 point inertia seat belts
3 point static belts
2 point lap belts
4 point harnesses
3 point harnesses
-webbing
13mm to 300mm
200kg to 65000kg
polyester
polyamide
polypropylene
-4x4/outdoor products
snatch straps
snatch ropes
pull straps
tree trunk protectors
snatch blocks
vehicle winches
tow straps
cargo nets (webbing and rope)
super syphon
reflective safety tape
karabine hooks
quick links
shock/stretch/bungee cord
plastic buckles (side release, three bar slides etc etc)
leather gloves
duct tape
- height safety
full body harnesses
fall arrest systems
temporary horizontal safety lines
- kit/storage bags
medical bags
recovery kit strorage bags
cutlery organisers
tool organisers
roof rack strorage bags
hi lift jack covers
The above is an overview and many more items products are available
The above products are supplied under the following brand names:
-SecureLoad
-SecureTex
-SecureTech
-Spanset
-McKinnon Chain
-RidgeGear
-Secutex
-JDT
-Warn
-RUD
-VIP
These products are produced and packed in our Randburg plant for distribution in South Africa and to 28 countries around the world. In South Africa we distribute via 185 dealers and through 105 international outlets. If possible we could consolidate shipments on a cost plus 15% or 20% basis (this is to cover export packaging, collecting, delivering and all export documents) and forward either ex works, FOB or CIF.
If you would like to like to discuss this further please advise your contact details and we would be only to happy to prepare an offer according to your requirements.
Many thanx in advance
Michael Green
T+27)0861040506
F+27)0861040507
M+27)0832514312
E: michael@liftlash.co.za
I thought I'd add this as well if anyone wants to question Micheal's knowledge:
Quote:
24 years production experience and 15 years offroading...........
.........the manufacturers of the relative equipment who like myself would give information free of charge
  #6
Old 13-09-06, 02:41 PM
Muddy Muddy is offline
Member
So what would the suggestions be for a place like Mudslingers, where we can recover anything from 1 to 20 vehicles in a day. Some of them requires 2 or 3 pulls, per mudhole, and there's 3 mudholes. 20*1*3 = 60 ropes/straps
Would we therefore need between 20 and 60 snatchropes/straps
__________________
Clive Kelfkens
Heidelberg Gauteng
2006 Jetta V
2009 Citi Sport
  #7
Old 13-09-06, 03:14 PM
Bob's Avatar
Bob Bob is offline
Member
nu uh, you use only a few repeatedly... making sure you did your stretches beforehand in case that snatch breaks or a recovery point is ripped off (
It is mud after all... taai soos boomgom) and comes flying your way.
Maybe practise your Matrix type moves at home beforehand.
Normally on a trail we are between 5 and 8 vehicles with about 5 kinetic straps between us, never broken one... have broken recovery points before though.
I don't know if your average 4x4 guy can afford to buy a new snatch that often, stuffs expensive
__________________
08' Diablo Black Kawasaki Versys
98' 3.0L V6 Colt Rodeo D/C (Engine rebuilt, Body lift, Monroe Shocks, 32" Wrangler MTR's, GME GX300)
Work hard, play harder. --Bob
  #8
Old 13-09-06, 03:58 PM
4x4 4x4 is offline
Member
They should use their own straps/ropes
__________________
Deon Kotzee
Heidelberg
  #9
Old 13-09-06, 05:49 PM
trekker's Avatar
trekker trekker is offline
Member
It is only good manners to have your own recovery gear if and when somebody need to recover you. It is like BOB says. The stuff is expensive. The other day I was asked to try and recover a LC with my winch. The winch cable broke and was replaced by Thys the owner of the LC within two days. I am more than willing to help a man like that each and every time.
__________________
Willem
http://www.4x4community.co.za/forum/image.php?type=sigpic&userid=334&dateline=1216741173Echo 3 Trailer with all the goodies.
FJ Cruiser (Stompie)
  #10
Old 13-09-06, 11:50 PM
PieterIsuzu4x4 PieterIsuzu4x4 is offline
Member
Willem,
Jy het 'n Duke op jou bakkie? Wat was die lengte & diameter van die kabel op die winch wat gesnap het. Wat se grote winch het jy?
  #11
Old 14-09-06, 04:36 AM
trekker's Avatar
Member
Pieter,
Duke 9500 met 35 m x 9.5 mm kabel. ( By Dune Off Road gekoop )
Die rede hoekom die kabel gebreek het. Ek het al 10 moeilike recoveries gedoen en die kabel het 'n paar platgedrukte plekke gehd.
Nog 'n rede is dat ek nie naby genoeg aan die LC kon kom om die kabel deur die katrol te sit nie. Die LC was amper uit toe die kabel breek. Ek weet tenminste dat my winch is sterk genoeg.
[img width=640 height=480]http://img172.imageshack.us/img172/7716/bullyp3.jpg[/img]
Myne aan die linker kant. Een van die moeilike recoveries.
__________________
Willem
  #12
Old 14-09-06, 07:40 AM
Member
Ja Willem, ek weet nie van jou nie maar ek haat eintlik die staal kabels. Moeilik om mee te werk, man moet altyd handskoene dra sodat die ding jou nie sny of steek nie, as die ding breek....kan potensieel groot skade en pyn aanrig....
Plasma tou is die "way to go". Sterker, ligter, dryf op water, kan gewoonlik meer tou op jou drom kry, maklik om mee te werk en as die seun breek...boef...val net grond toe.
Die foto van jou steek lyk dit vir my 'n lekker storie weg...moes julle gelyktydig winch?
  #13
Old 14-09-06, 08:20 AM
trekker's Avatar
Member
Ek wens ek het nou oor die R2000.00 gehad vir 'n 30 m plasma tou. Dis net uit die 10 recoveries wat ek gedoen het was net een op my eie voertuig. As daai tou iets oorkom terwyl ek iemand anders help kan ek mos nie van hom verwag om die ding te vervang nie. So ek bly maar eers by staal.
Ja ons moes altwee gelyktydig trek. Johan en ek teen Eugene se Trooper
[img width=640 height=480]http://img182.imageshack.us/img182/1939/troopergb0.jpg[/img]
__________________
Willem
  #14
Old 25-09-14, 10:50 AM
EVH's Avatar
EVH EVH is offline
Member
Hi there guys - I am reviving this old thread as I am in the market for a snatch strap / rope and looked at them at Safari Centre yesterday. What they told me was that the rope can definitely be used for multiple consecutive pulls and the strap not - needs to rest 24 hours. According to the salesman, the further advantage of the rope is that lasts a lot longer than the strap. And the rope is a couple of R100's cheaper than the strap. Only disadvantage is the size when packed - it is quite bulky. Do I understand the thread correctly to conclude that the salesman was talking *&#^? Or is there some merit in what he was saying?
__________________
2013 Land Rover Defender 110
2010 Toyota Land Cruiser Prado 4.0 TX
09 Xplorer Anniversary Ed No.144
  #15
Old 25-09-14, 10:56 AM
Engel's Avatar
Engel Engel is offline
Commercial Member
(STOCK STANDARD)
Rope cheaper than a strap? something is wrong. Strap R400 and rope R1400.
__________________
Worldwide Driver and Transport solutions.
*Defensive driving in Africa
*High speed vehicle control on gravel roads
*4x4, Recovery, Deep Sand
*Accident avoidance and prevention
Premier private and corporate Training-mail me!
herman@angeloffroad.co.za
Manufacturer of Pofadder (c) kinetic recovery rope kits Importers & Distributers of 4x4 products.
Custom 4x4 installations and manufacturing
+27824453301 always on.
  #16
Old 25-09-14, 10:59 AM
EVH's Avatar
EVH EVH is offline
Member
9m rope 12000lbs is R1000; 9m strap 12000lbs is R1200
Is rope a better option?
__________________
  #17
Old 25-09-14, 12:39 PM
camelman's Avatar
camelman camelman is offline
Member
Like Engel said, something is wrong. Strap should be much cheaper than rope. And the 1 snatch in 24 hrs is also BS. The strap just loses its elasticity and if you recover more than once in succession it will become jerky.
__________________
camelman
"Houses are the coffins of the living" - Touareg saying
  #18
Old 25-09-14, 02:05 PM
Biggles's Avatar
Biggles Biggles is offline
Member
Something definitely wrong... safari centre should in no way be cheaper than anywhere else.
__________________
2002 Nissan Patrol 4.2Td. Body lift, 5cm OME lift 33inch Cooper SST, Burnco bumpers.
Platkar:2002 BMW M5, 2002 M Coupe and 1985 635csi
SWAMBO: BMW X5 3.0D
Talk softly, carry a BIG stick
Ex: Jeep Cherokee XJ 2.5Td
  #19
Old 25-09-14, 02:23 PM
XJ Junkie's Avatar
XJ Junkie XJ Junkie is offline
Member
The recovery time needed on either is dependent on the severity of each use. Ropes do recover quicker though but that doesn't mean to say that a strap can't be used repeatedly on the same day. If your at the point where each recovery ends up being a hardcore one, then you bought the wrong 4x4 in the first place :-).
For frequent use I reckon straps are better because they are cheaper, easier to get out & pack away again & are less cumbersome.
Ropes are more expensive but the kinetic action tends to be better.
  #20
Old 25-09-14, 02:41 PM
Die Skim's Avatar
Die Skim Die Skim is offline
Member
Oky as niemand dit dan gaan sÍ nie sal ek maar.
Bestel vir jou 'n Pofadder snatch rope by Engel. Dit neem dalk 'n bietjie meer plek op en is 'n duur belegging, maar jy sal nie spyt wees nie.
__________________
Pat
Prado 3.4 V6, OME + Spacer lift, Cooper STT, Safari Snorkel, VHF.....
Buell Xb12Ss
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Kinetic snatch strap or kinetic rope DUMPIE Regional chat 6 14-03-11 01:05 PM
Help with choosing snatch rope or snatch strap jaco_n 4x4 Recovery & Recovery Gear 8 26-01-10 12:52 PM
Recovery Rope/Belt Ebot 4x4 Recovery & Recovery Gear 22 29-06-09 08:35 AM
Snatch Strap Mechanics 4ePajero 4x4 Recovery & Recovery Gear 39 08-09-08 07:11 PM
Tow rope & Snatch strap combination HannesvZ 4x4 Recovery & Recovery Gear 6 10-08-07 11:50 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
