Stuck - Page 144
Page 144 of 144 FirstFirst ... 44 94 119 134 135 136 137 138 139 140 141 142 143 144
Results 2,861 to 2,864 of 2864
Thread: Stuck
  1. #2861
    swakopmund
    Thanked: 730
    Default Re: Stuck
    Ukranian tourist ..... unsafe towball recovery ? Why do you say so just by looking at a pict ? Or is ALL towball recoveries deemed as unsafe ?
  2. #2862
    Sep 2013
    Thanked: 47
    Default Re: Stuck
    Quote Originally Posted by Bartho View Post
    As a general rule, yes. All towball recoveries should be considered unsafe- and that looks like a kinetic rope too! Dis moeilikheid soek.
  3. The Following 3 Users Say Thank You to Clem For This Useful Post:
  4. #2863
    Worcester
    Thanked: 782
    Default Re: Stuck
    Bartho, I do not profess to know dune recoveries anywhere near as much as you. Yet, I do know enough to know that recovery is going to take more than a pull. That calls for a snatch recovery. And, that being a kinetic rope, spells danger.
    We've had a Disco 1 try a snatch on a SerIII Landy where the tow bar drop plate tore out, and struck the D1 on the top part of the tailgate door. Took out the roof and rear door on the Disco. Both had to be replaced! If that drop plate was 6" lower, we would have had my SIL in hospital... if she was lucky.
    I consider that recovery unsafe.
    André Opperman
    Learn everything you can, anytime you can, from anyone you can - there will always come a time when you will be grateful you did. Sarah Caldwell.
    "Boerbok" - 98 Jeep XJ 4lit auto
    "Gloria" - 04 Ranger D/C 4lit auto
  5. The Following 2 Users Say Thank You to Oppers For This Useful Post:
  6. #2864
    swakopmund
    Thanked: 730
    Default Re: Stuck
    Would agree totally with abovesaid but fortuner could not get traction to even start to really put tension into strap. After this picture they sweated a bit and dug it out properly and a vast walking pace pull recovered it 😊
    By charlatan in forum Jeep
    Last Post: 2017/04/15, 11:31 AM
  2. Clutch pedal Stuck rock solid - Defender tdi
    By frogstar in forum Land Rover
    Last Post: 2013/03/27, 07:28 AM
  3. 1, no 2, no 3 vehicles stuck in Bridgemead
    By Dirk in forum Eastern Cape
    Last Post: 2011/10/03, 10:05 AM
  4. Grand Cherokee Error code
    By Nick47 in forum Jeep
  5. Some last resorts when your vehicle is stuck
    By Big Hilux in forum 4x4 Recovery & Recovery Gear
    Last Post: 2006/12/09, 09:13 PM
