Mike's Homemade Fridge
Results 1 to 20 of 83
    Suffolk, UK
    Default Mike's Homemade Fridge
    If you have to have a fridge in your overlanding vehicle..........which you don't............at least have the fun of making it yourself.
    I started by buying a second hand upright fridge freezer from eBay. It had just been taken out of a narrowboat on one of the Midlands canals, and for less than £50 I had a cracking little Danfoss compressor, plus all the controls etc.
    Then, it really helps if a friend from the squash club is a high-end sheet metal fabricator.
    I had to fit this thing into a very small space in my Hilux, and the space isn't regular....hence the strange looking design with a corner chamfered:
    It was important not to waste any space, so I have made the compressor "box" act as a shelf for my cooking gas bottle, and the two triangular ducts behind (cooling air extract vents) are designed to hold the gas tight in place (there will be a couple of straps). A pair of "over-centre" catches will hold the lid down tight against the seal.
    Here is the inner skin taken out of the outer shell, and showing the 6 metres of 8mm copper cooling pipe tacked to the shell:
    This is a close up of the hinge, showing the detail that enables the fridge to stand hard-up against some storage boxes without fouling the open lid:
    Everything is fabricated from stainless steel, and the white covering with blue stripe is the protective plastic still in place. This is the outer shell:
    and this is the air ducting showing one of the 60mm computer fans in place (there will be two):
    I have had a bit of help from specialists on the forum (thanks guys!!....you know who you are) and have fingers crossed that 50% more condenser than evaporator will do the trick, with forced airflow. I had fun bending this lot, and this is "work in progress". The condenser coil will sit in front of the compressor.
    This is the cover that will shield the compressor and condenser, yet allow airflow:
    The compressor is shown roughly in position, but with stray pipes sticking out all over the place!
    The next stage is to "blackjack" the cooling pipes and the skin of the inner box (to avoid condensation problems in the insulation area. Then, the insulation will be fitted. This will be a mixture of foil faced PIR ("Kingspan" or "Celotex"), with blown in expanding foam to fill the gaps. There is typically 60mm of insulation around the whole thing, but only 40mm on the long faces front and back.
    The fridge has a volume of 33 litres, and is dimensioned to fit 2 milk cartons across the width, which also is the size of my 5 litre "duty" water container. The principle funtion of the fridge is to keep drinks cool, and to preserve some veggies and cheese. Actually, it's principle function is to keep my passengers happy, and me miserable! It won't be a freezer.
    Mike
    "Mike for President" Freeflyd
    Melville
    Patent and export!
    "Man is still the greatest miracle and the greatest problem on this earth"
    Modderfontein, naby Rysmierbult
    Thanked: 118
    Mike, of course you don't really need the fridge !!
    .. impressive job nevertheless
    ... a guaranteed cold one is always nice to have.
    .. enjoy
    Johan Mitchell, Swambo : Marthie.
    My beste kennis is diť oor my eie onkunde
    '96 Colt DC V8 ... Safari Camper ... '88 Fleetline L
    '88 Ballade 150.
    "The rule here is that there is no rule" .. MikeAG
    Oct 2006
    CAPE TOWN, SOUTH AFRICA
    Thanked: 138
    Mike, this has already been copied by the Chinese and will be on the market tomorrow for 50 pounds.
    Seriously a very nice project and hope it serves you well.
    ORA
    Ian
    Thanked: 272
    jy is nogal oraait vir n rou soutie ne! Mens moet jou erens vasmaak en teel met jou, dink net watse slim kinders jy kan he!
    herman@angeloffroad.co.za
    +27824453301
    Gautengeleng
    Thanked: 14
    You are ok for a raw salty hey,We have to tie you somewere and breed with you. Just immagine what clever kids you will have
    Corne
    Suffolk, UK
    Thanks guys! I guess that increases the chance of me supplying you lot with a cold drink when we bump into each other somewhere in the bush.......
    Herman........you do test me, don't you! But I'm getting quite good with this Afrikaans thing..... Is it something like "You're OK for a soutie. We should ? you somewhere and breed ? with you.......Think what smart/ intelligent?? children you would have"?
    If so, you can have one of these...........but I've got a couple of bright kids floating about already, and that's plenty enough!
    Mike
    Suffolk, UK
    Thanks Matoda..........I wasn't far off, then! Herman's English is still 10 times better than my Afrikaans.
    Thanked: 9
    Well done so far Mike, its looking good!
    Nigel
    Thanked: 446
    Mike don't worry about Herman's English. It is just an act. His English is quite up to scratch. A helluva lot better than your Afrikaans.
    That fridge really does look damn good. Even though you don't need it.
    Aug 2010
    Delmas
    Thanked: 8
    Nice job Mike!
    BlinkGat Products
    Manufacturing of Aluminium and
    Stainless Steel custom made Products
    Sarel 082 820 9413
    www.blinkgatproducts.com
    Suffolk, UK
    I know! I met him a couple of years ago in Jozi.......Hy praat lekker Engels.
    Cheers Henri. I only want to make it once, so may as well do it properly. I took dozens of measurements when I was last out with the car, but will still be holding my breath when I first offer it into place. I'll look pretty damn stupid if it doesn't fit!
    Thanks Barto, Sarel.
    Mike
    Thanked: 70
    Hi Mike, looking good - now you'll have to start intensive training to drink cold beers!
    Are you going to thermal compound between the shell and the tube?
    Uys
    Overkill - isn't!
    uys@stofpad4x4.co.za
    www.stofpad4x4.co.za
    Why you need Stofpad4x4 Rock sliders
    Office: 012 654 7723 (sales)
    Gordon's Bay
    Thanked: 2588
    WHO ARE YOU AND WHAT HAVE YOU DONE WITH MIKE AG?
    can't be Mike.. thats a mobile fridge... it must be an imposter... the real Mike does not even have a fridge at home!!!
    "the village scoundrel" - Uys
    Anyone who is capable of getting themselves made President should on no account be allowed to do the job. Douglas Adams
    those who can, do; those who can't, teach George Bernard Shaw
    A business that makes nothing but money is a poor business. Henry Ford
    it is better to be irresponsible and right than to be responsible and wrong Winston Churchill
    Suffolk, UK
    Are you going to thermal compound between the shell and the tube? Uys
    Hi Uys. (isn't that a type of taxi-van, a mutatu?)
    Thermal compound? I've never heard of such a thing..........but it seems like a good idea. What do you have in mind?
    Mike
    Thanked: 70
    Quote Originally Posted by MikeAG View Post
    Mike
    Mike.
    The biggest problem, which you obviously know off- is to get proper thermal conduction between the shell and the tube. This will greatly affect the efficiency. You get a thermal compound that can improve this, but the only I know off is the type used between CPU's and the heat sink. 5ml costed me R80 a while ago.
    Overkill - isn't!
    Thanked: 8
    Very neat job Mike.
    Have you any idea what the actual cost of this project is, including time, yours and your very clever metal sheet bender.
    Just trying to rationalize whether it is really worth making something like this or whether it is just easier and more cost effective to buy one. New or second hand.
    I am aware that your unit is very specific to available space in your vehicle and that and off the shelf version may not suit your requirements.
    Rob Stock
    SS Agencies
    website: www.ssagencies.co.za
    Tel: (041) 379 2495
    Fax: 086 529 3495
    Cell: 082 905 4738
    Suffolk, UK
    Rob,
    Off the shelf wouldn't have fitted...........and I just hate buying things I can make. The compressor cost around £50 with transport, and the sheet metal work will cost around £100 to £120...then there is a bit of plumbing and gassing to do. £200 the lot, maybe? I never cost my time on stuff I do for myself. It's my hobby, my pleasure.
    My mate the sheet metal worker does an absolutely brilliant job.......and he can get me a TIG welder for £300!!! It's handy to know people!
    Uys......do you have a brand name I could look up?
    Mike
    Thanked: 435
    That looks like an impressive piece of engineering Mike....good on you
    Neil
    2001 Jeep Cherokee XJ 4.0L - 2015 Renault Duster 4WD
    Gordon's Bay
    Thanked: 2588
    thermal compounds are usually heat transmitting greases... useful for PC boards and so on, and bloody expensive....
    http://en.wikipedia.org/wiki/Thermal_grease
    the trick is to increase the contact face between the pipe and the shell. packing polystyrene between the shells would be a good start - the cavity will be cooler, less heat transmission from the outer layer and so on...
    soldering it to the case would be a huge advantage contact area wise but it will not stick to the stainless of course...
    my engel has the element in the box... that works well, as its cooling the box not the cavity and relying on heat transmission to the walls and then the cavity, but obviously not as neat and tidy as you have it....
    don't know what to suggest other than packing the cavity with polystyrene to improve things... taping over it all with aluminium tape might help a lot - have you tested it?
    looks great by the way!!!
  1. National Luna Fridge vs the battery? Fault ID flashing.
    By spylikeme in forum Camping, Fridges, Accessories
    Last Post: 2013/09/17, 07:16 PM
  2. Yskas sny uit. Hoekom?
    By Ripper in forum Camping, Fridges, Accessories
    Last Post: 2011/01/25, 10:05 AM
  3. Solar panel and Fridge
    By Ore in forum Camping, Fridges, Accessories
    Last Post: 2010/10/18, 03:58 PM
  4. ARB fridge - owners feedback
    By Kykdaar in forum Camping, Fridges, Accessories
    Last Post: 2010/06/13, 10:26 AM
  5. 220V Fridge in car question
    By jdjoubert in forum Camping, Fridges, Accessories
    Last Post: 2010/01/13, 11:12 AM
