Fridge Wiring
Results 1 to 11 of 11
Thread: Fridge Wiring
    Feb 2008
    Default Fridge Wiring
    Hi All
    I have a small Snowmaster 220v/12v compressor fridge, the fridge works superb if I connect it directly to the battery but once I plug it in at the rear socket of my Discovery, it does not get enough power. I want to wire the fridge direct to the battery, what size wire do I use and what is the recomended size of the fuse I need.
    Jan 2010
    I used 3mm wire and a 15A inline fuse at the battery...
    Feb 2008
    I have used 2.5 but it seems that it is too thin to carry the amps.
    Bellville
    Thanked: 336
    Gary 6mm or even 8mmm I have used 8mm with success before. BOTH Live AND neutral wires.
    Thanked: 390
    I would go for a 6mm wire running on both + & - with a 20a fuse to take care of protecting the cable. This should take care of the majority of the voltage drop.
    Resit the temptation to use the body as the negative, rather pull in an additional cable
    Henk
    Fitment and trailer service. Agent for Metalian & Tentco
    Follow us on Facebook
    Nov 2008
    Thanked: 11
    Default Best advise
    I have an 80L Snowmaster in my bakkie, and my opinion is to fit a battery manament system. When I go on the long road, and I want to let my contents of my fridge to get cold quickly I set my Snowmaster on FF [ fast freeze ] . When I arrive there I set it to the temperature I want. The battery management system controls your fridge and your bakkie starting power [I do have a duel battery]. I was away from my bakkie for 4 months without staring the bakkie and when I came back my bakkie started without any problem. Difference is deep circle battery with battery manage system. The battery manage system regulates the power between your excess power supply and the staring power of you bakkie. When you set the snow master on FF [fast freeze] while driving along roads it will freeze al the content of your fridge. If your bakkie is standing still the battery manage system will minimise the power from your fridge so you are able to start your bakkie and freeze the content of your fridge again. But the content of your fridge will not go off.
    Toyota Fortuner 4.0L 4X4
    AKA - TUNA
    Agree 100% minimum 6mm positive and negative
    Going bush is going Home
    Mike Lewis
    Pajero NS (Gen 4) 3.8 V6... Dual battery, EFS Suspension, Airbags, Safari snorkel & Front Runner rack with extras
    Feb 2008
    I found a shop that sells car sound stuff and they can supply me with the cable, it is damn expensixe R32 per meter.
    Thanked: 86
    Gary, Go to the East Rand Traders (Fleamarket). There are many audio shops that sell thick cable that is used on car audio systems. I find that the cheapest stall is if you enter on the East Rand Mall gate. The audio shop is basically in front of you. You can pick up a 6 gauge for R10/metre. Regards
    Edwin
    Defender '99 TD5 Pick Up
    Rock sliders, Spare wheel carrier, Roof Rack, Aluminium canopy, Tentco RTT, Tentco Awning, 280Ah Dual batteries, 3 x Sliding Drawers, Water tank, Hot Shower, Kitchen
    Jo'burg
    Car sound shops are expensive
    Try here
    http://mweb.brabys.com/search-InfoKe...SUPPLIERS%20CC
    SWAMBO
    2009 Suzuki Grand Vitara 3.2i V6 Auto
    Me
    2003 Ford Focus 2.0
    Eurard: For T=2; ˝T=1 but, 1/2T=Ľ
    Thanked: 390
    Quote Originally Posted by garywinter View Post
    Sounds like the right stuff
    Henk
  1. National Luna Fridge vs the battery? Fault ID flashing.
    By spylikeme in forum Camping, Fridges, Accessories
    Last Post: 2013/09/17, 07:16 PM
  2. Yskas sny uit. Hoekom?
    By Ripper in forum Camping, Fridges, Accessories
    Last Post: 2011/01/25, 10:05 AM
  3. Solar panel and Fridge
    By Ore in forum Camping, Fridges, Accessories
    Last Post: 2010/10/18, 03:58 PM
  4. ARB fridge - owners feedback
    By Kykdaar in forum Camping, Fridges, Accessories
    Last Post: 2010/06/13, 10:26 AM
  5. 220V Fridge in car question
    By jdjoubert in forum Camping, Fridges, Accessories
    Last Post: 2010/01/13, 11:12 AM
