Fixing my old/new Pajero - pic intensive
Page 1 of 10 1 2 3 4 5 6 7 8 9 10 LastLast
Results 1 to 20 of 194
    4ePikanini Guest
    Default Fixing my old/new Pajero - pic intensive
    This index only works if your threads per page is set to 20.
    INDEX
    Threads elsewhere
    Page1
    Strip down
    4x4 dash lights
    Labour Quotes
    Starter clean
    Page2
    Starter service
    Parts inventory for cooling, pulleys, crank bolt, thermostat, thrust bearing etc
    Crank bolt discussion
    Rear bumper rebuild
    Spotlight wiring discussion
    reverse light switch on the gearbox
    Page3
    workshop pictures of rebuilt engine
    first start priming discussion
    big hole lifter
    prelim price breakdown
    Page4
    Workshop pictures of finished engine
    Re-assembly and engine drop into pajero
    Page5
    Final assembly
    Cost breakdown
    Page6
    Running video with sound
    Idle hunting discussion
    Page7
    Pulley squeel
    Trademark stamp
    Left inner CV boot
    Page8
    Left inner CV boot DIY how to.
    Radiator pulled for spout re-alignment
    Radiator drop-in after spout re-alignment - time lapse video
    Old parts pictures
    Collage picture
    Pitman arm replacement picture
    New tyres
    Page9
    pitman arm replacement steps
    My first trail
    A/C fan
    MAF sensor failing and replacement from overseas
    Page10
    Anti-Roll bar bushes
    4ePikanini Guest
    I bought a pajero for cheap
    My New Pajero
    Then figured its got a rod knock. More than likely a gudgeon pin
    Rod knock causes
    So the tear down has begun
    Will strip down till just the block and heads are left and then take it out and send it in for a possible bigger bore, head skim and new pistons, bearings and head refresh.
    PICS
    Belts hoses fan and radiator. Radiator got a 3 row recore. Thanks dad
    Cam belt looks pretty good surprisingly
    NOTE TO SELF : Replace ALL water hoses - Only at dealers - Got a quote of R1100 for ALL of them - I think it's 8 hoses
    Got to know where the belts go. haha
    TIMING MARKS
    This image has been resized. Click this bar to view the full image. The original image is sized 772x579.
    And out she comes
    Wonder how long ago the oil was changed and what brand was used?
    Water passages doesn't look too bad but It did run for a while without antifreeze and badly overheated at some stage as well. The top housing of the radiator was bulging from the pressure
    This image has been resized. Click this bar to view the full image. The original image is sized 942x569.
    Got the fuel rail and intake plenum cleaned up
    This image has been resized. Click this bar to view the full image. The original image is sized 800x600.
    While the engine has been sitting at the rebuilders I tackled the 4x4 dash lights
    I made a DIY about it HERE
    The engine will be started on tomorrow at the workshop so progress should be updated frequently from this time onwards.
    stripped
    It is not as bad I initially feared but it is clear that the previous owner did no maintenance for over 50k.
    The bores are slightly scored but if you look carefully you can still see the original honing marks after 250k :kewl:
    The crank is slightly scored - due to lack of decent oil and VERY old oil - the workshop reckons it is 60k overdue for a change :8
    Good news is that a bore ( with new pistons ) won't be necessary - just a good re-hone
    I'll let the pictures speak further
    4ePajero Guest
    Seriously neglected engine!
    Got very hot at some stage.
    Should be good as new after the re-build.
    Apr 2008
    Marius
    Hats off to you for tackling this project. You are also lucky to have your dad looking over your shoulder. Don't let him interfere TOO much.
    Enjoy and keep us updated.
    Jacques Greyling
    All that is necessary for evil to triumph is for good men to do nothing
    1999 Prado 3.4 V6
    Jul 2008
    Constantia Kloof
    Thanked: 289
    Marius,
    Take a look at the sleeve on which the thrust bearing slides. It may be worn and would be an easy fix at this stage whilst the engine is out of the vehicle.
    Brandt
    2015 Mahindra Bolero SC 2.5 NEF TCI 4x4 (Ratchet & Clank)
    2007 Mercedes Benz ML500 5.5
    1968 VW Beetle 2276
    4ePajero Guest
    Quote Originally Posted by hoenner View Post
    No chance of that!
    I only give advice when asked!
    4ePikanini Guest
    Marius
    He is directly and indirectly 100% responsible for the knowledge that now allows me to tackle unknown territory as he laid good foundations.
    Off the forum we discuss the build in detail passing thoughts to and fro. We agree on most points but when we differ his ideas are better 99% of the time.
    ( After all I can vouch for him swapping his pajero engine 3 times )
    - 2500 diesel mitsu to 4.3 chev V6 (V6 was a wreck that he rebuilt completely and was initially in the kombi first as a mid-engined monster )
    - 4.3 chev V6 to toyota 2.0 TD
    - toyota 2.0 TD to another sub assembly 2.0 TD ( I handed tools with this one - 6pm to 4am and she started on the first crank at 7am - had to wait for gaskets to set )
    - Toyota 2.0 TD to Mitsu 3.2 DiD
    Jo'burg
    Looking good guys!
    Could you isolate the knock?
    Was it a gudgeon pin? or big ends?
    SWAMBO
    2009 Suzuki Grand Vitara 3.2i V6 Auto
    Me
    2003 Ford Focus 2.0
    Eurard: For T=2; ½T=1 but, 1/2T=¼
    4ePikanini Guest
    Quote Originally Posted by RedLineR View Post
    Looking good guys!
    Can't really say for sure as no bearings were spun. The inside looked really bad and the crud on the piston could have been a cause due to pre-ignition but my dad and the workshop suspects it was a big end based on the fact that the one part of the crank ( see right side of pic below ) was badly scored. But knock or not I'm glad it is getting rebuilt as it was badly neglected and overheated pretty badly at some stage in its life. No antifreeze --> badly rusted cap --> failed to release pressure --> bulging radiator top tank --> burst coolant hoses --> overheated
    Next to do
    pay for engine (heads, rebore, pistons and clutch) - still awaiting quote today or tomorrow
    then to do as finances come in ( dealer prices excl vat )
    new engine mountings - R657.14 each
    new TO bearing - R41.65
    clutch cylinder kit - R97-28
    new coolant hoses - approx R1000-00
    ** install engine
    fill with oil and coolant
    diff's oil change
    tranny/transfer oil change
    CV boots
    brake bleed
    clutch bleed
    ** First drive straight to Hi-Q/Tiger wheel
    Tyres
    Shocks
    alignment
    oil pressure/temp gauges
    Loss of coolant alarm
    Voltmeter
    ROAD TRIP!
    4ePikanini Guest
    the quote is in
    4ePikanini Guest
    I have ordered some parts from the dealer as the machinist says I can have the motor month-end.
    All new coolant hoses except the connections that go to the back heater matrix ( never gets below 10 celsius here )
    Two new tensioner pulleys ( expensive and the quote says they are power steering pump pulleys - I sent a pic to the dealer to make sure they are correct)
    Two new engine mountings
    TO bearing
    That's all nice and well ... but ... wouldn't it be nicer as a 3.5 or 3.8 by the time you start it
    2005 Saab 9-3 2.0t Arc
    ex: 2000 Colt Rodeo 2.8 TD 4x4 219 000Kms
    Custom Aluminium Hard Cover, Custom Tool box.
    Madman EMS2 Gauge, monitors EGT, coolant level and voltage.
    4ePikanini Guest
    Quote Originally Posted by rules View Post
    It would be nice but seeing as this is my first build ( and my financial constraints ) I want to try and keep it as close to stock as possible - less complications.
    Nov 2008
    Thanked: 13
    Default Hats off
    Hats off to you for undertaking this project.You will appresiate the Jaro allot when finished.It is grate to see the younger generation [ no pun ] taking pride in what they are doing and it with there own hands.I am onley about 10 years older but take my hat off to you.Shows big ball bearings !!!
    Toyota Fortuner 4.0L 4X4
    AKA - TUNA
    4ePikanini Guest
    Quote Originally Posted by Vissie View Post
    Thanks Vissie.
    There is a sense of pride and satisfaction, when your own hands have laboured on a project, that money can't buy.
    4ePikanini Guest
    Small progress.
    Engine will be back in two weeks.
    In the meantime I've chased all the wires from the speakers as only the rear right was working.
    All 4 speakers are working now and the wiring ball sorted behind the radio.
    4ePikanini Guest
    progress
    before
    after
    4ePajero Guest
    Did you open it to check the
    • brushes
    • bearings/bushes
  19. #19
    Nigel
    Thanked: 1018
    Pa, keep your nose out of it..........
    LC 78 Troopie 1HD-FTE
  20. #20
    4ePikanini Guest
    I'd rather he ( who has put a DiD in a Gen1 ) keeps his nose in it
  1. PRADO vs PAJERO
    By benhur in forum Vehicle & Technical Chat - General
    Last Post: 2015/05/18, 10:25 AM
  2. My Pajero aint scared!!!!!
    By Tau in forum Mitsubishi
    Last Post: 2008/09/01, 03:54 PM
  3. Gen3 Pajero Survives 6-car pile-up
    By 4ePajero in forum Mitsubishi
    Last Post: 2007/09/06, 09:16 AM
  4. New Pajero
    By Gerrit Loubser in forum Mitsubishi
    Last Post: 2006/11/04, 03:40 PM
