Fixing my old/new Pajero - pic intensive - Page 9
Page 9 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 161 to 180 of 194
  1. #161
    How big a job is the pitman arm? I need to go through the process as well?
  2. #162
    4ePikanini Guest
    spray q20 for a few days to loosen up the pitman arm
    remove wheel
    center steering
    remove balljoint nut halfway on small end of pitman arm
    use puller to release balljoint
    unscrew big nut halfway on big end of pitman arm
    smack witha big 4pound hammer to get it loose - this is not easy as you feel you might break something
    once it is loose mark the postion of the arm on the splines
    loosen both nuts
    replace arm
    put everything back together
    small tighten by feel
    big nut is about 143NM torque
    go for alignment
  3. #163
    4ePajero Guest
    Theoretically you don't need an alignment after the fitment of the new Pitman arm.
    The whole task took 1 hour. Removing and fitting the wheel took half the time!
    If the Pitman arm won't budge, it can be heated before hitting.
    Worse case is to cut a slot in it with a small grinder.
  4. #164
    That should be do able. Thanks.
    P.S When are are the 4Es writing their book "How to maintain,refurbish and modify Pajeros?" I'll have one
  5. #165
    Good Day! Just a quick Question! Blew my Turbo , and from there I havent driven my Pajero for over two Years now. It was standing, never started her at all. I am replacing the Turbo now. What Precautions should be taken before I start her up?? Please advise
  6. #166
    4ePikanini Guest
    Some way down on this page there is a nice discussion regarding the things to look out for.
    http://www.4x4wire.com/forums/showfl...0&fpart=2&vc=1
  7. #167
    4ePikanini Guest
    My first trail. Nothing broke and I was very impressed with what the vehicle can do.
  8. #168
    4ePikanini Guest
    Some more pictures from the professional photographer on the trail - Craig Muller
  9. #169
    4ePikanini Guest
    While now getting to address my A/C system I noticed I have no electric fan in front of the condensor and I know that is a boo boo. So I made a quick trip to Midas and a little bit later. Voila!
    It only runs if the compressor clutch is engaged ( 12v going to clutch switches a relay )
    I got to get the A/C working! The 'reliable' temp gauge showed 36 at some stage - and that was while driving on the highway.
  10. #170
    4ePikanini Guest
    Small update. The MAF sensor packed up. The car started lurching and dying and hunting at idle again.
    I unplugged the MAF sensor and the engine purrs like a kitten again. ( This creates the check engine light to stay one )
    The stealer wanted R4500 so I asked some mitsu friends overseas in USA if they would keep an eye out for me for a MAF sensor as they are cheap there from the junk yards.
    Lucky for me MontyMcV found one and with shipping and registered post it all came to $60 ( R475 via paypal ).
    I'm just waiting for it to come in.
    My list grows short now.
    - A/C blockage removal and gassing.
    - Shocks
    - anti-roll bar rubbers ( suspension clunking is annoying )
  11. #171
    Apr 2008
    Hi 4ePikanini/4ePajero
    Can you possibly help me with torque settings. Busy overhauling my engine 6G72 3.0 V6) at present and should be roughly the same as your Pajero engine.
    Got settings as follows:
    Head 40Nm - 70NM - 100Nm (staged)
    Flywheel 77Nm
    Big ends 26 - 52Nm (staged)
    Mains 80Nm
    I have rebored the block and cut crank and are fitting new pistons, rings and bearings. Torqued the Mains ok. Torqued Big ends first stage = Ok. Torqued second stage and can't move the crank by hand at all. Is this right?
    Appreciate the help.
    Cobus
    94 Pajero 3.0 V6
    95 Colt Rodeo 3.0 V6
    VW Beetle - 1968 tish
  12. #172
    4ePajero Guest
    Download a manual from one of the links here:
    http://www.4x4community.co.za/forum/...ad.php?t=10946
  13. #173
    4ePikanini Guest
    Torque specs attached according to the manual.
    I take no responsibility for the accuracy of the info supplied.
  14. #174
    Apr 2008
    Thanks. Torque settings seems right. Still feel awkward about crank not able to turn by hand. Think I will re-torque too make sure.
    Cobus
    94 Pajero 3.0 V6
  15. #175
    4ePikanini Guest
    have you checked clearances with plastigage?
    A lubed and correct torque assembled engine should be able to turn by hand ( using a ratchet - not just gripping the crank or pulley )
    Are the heads on yet?
  16. #176
    Apr 2008
    I have decided to take the assembled block and crank back to the engineers. Heads are not fitted yet.
    Cobus
    94 Pajero 3.0 V6
  17. #177
    4ePikanini Guest
    Quote Originally Posted by Oslons View Post
    The key to success is to make your problem someone else's problem.
    keep us updated and you owe us some pictures
  18. #178
    4ePikanini Guest
    Update
    Got these at a bargain ( less than R50 ) overseas so they are on their way here.
  19. #179
    Apr 2008
    Quote Originally Posted by 4ePikanini View Post
    Very true but in the end I had to do the stripping myself and refit pistons again. Saw that my block is not gonna get attention since I have already paid and stripped at engineers place for them to measure caps. Miscommunication between me and engineer, two bearing caps swopped around caused issue. My caps were numbered and that how I put it back. they did not go according to numbers and fitted left sided piston on right side - numbered conrod. So basically just time wasted but at least easily fixed.
    Will post some pics later. Struggled a lot to get block on to gearbox as well as getting block on left sided engine mounting. Lowering block one side was in line but other way off.
    Cobus
    94 Pajero 3.0 V6
  20. #180
    4ePikanini Guest
  1. PRADO vs PAJERO
    Last Post: 2015/05/18, 10:25 AM
  2. My Pajero aint scared!!!!!
    By Tau in forum Mitsubishi
    Last Post: 2008/09/01, 03:54 PM
  3. Gen3 Pajero Survives 6-car pile-up
    Last Post: 2007/09/06, 09:16 AM
  4. New Pajero
