Fixing my old/new Pajero - pic intensive - Page 7
Page 7 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 121 to 140 of 194
  1. #121
    4ePikanini Guest
    I have a pulley squeel ( very intermittent ) and the only one it could be is this one as it still squeels with A/C belt and PS pump belt removed.
    Do I need to buy it as a whole or can I have a bearing pressed in?
  2. #122
    4ePikanini Guest
    removed that pulley assembly and when I spun it, it felt really solid and smooth so I thought "it can't be this"
    I cleaned everything and re-assembled with a bit of penetrating oil on the pulley bearing and by the alternator.
    Everything is quiet as a kitten purring now
    So let's see how it goes.
    Anybody know where the rear door switch is ( that triggers the door-open light )
  3. #123
    4ePikanini Guest
    Took a pic of the finished product
    and put my stamp on
  4. #124
    Apr 2008
    Like the Heat Shield...
    89 110 V8
    A closed mouth gathers no foot
  5. #125
    4ePikanini Guest
    For the record
    To set the timing you must connect the brown terminal to earth and set the advance to 5 BTDC
    The black connector can be connected to 12v to let the fuel pump run
  6. #126
    Alicedale
    Is that heat shield or a sound damper? cost? any good?
    '16 Toyota Land Cruiser D/C v8
    '15 Toyota Hilux 3.0D4D
  7. #127
    4ePikanini Guest
    Quote Originally Posted by Bryan Webber View Post
    On the firewall or bonnett?
    Either way I got the car as it is there, so I can't really say.
  8. #128
    Thanked: 550
    Timing spec on my samcor unit on a plate under the bonnet says 7 deg?
    Beautiful piece of work Marius I hope it gives you many trouble free years
    Henk
    Fitment and trailer service. Agent for Metalian & Tentco
    Follow us on Facebook
  9. #129
    4ePikanini Guest
    My bonnet and FSM says 5 deg.
    Could be different compression ratios or maybe LRP vs Unleaded?
    Or coastal vs inland?
    Would be really interesting to know why yours got branded 7 deg.
    Maybe the 3.5 & 3.8 are 7 deg and they put the wrong sticker on
  10. #130
    Sep 2008
    Default Nice one
    Nice one let us know how it goes once it has been "commisioned"
    Regards,
  11. #131
    4ePikanini Guest
    It is already in daily use. Goes like a drunk......willingly and thirsty!
  12. #132
    Thanked: 550
    Yours is for the coast where mine is up country ... altitude adjustment maybe mine has an imported sticker and yours local
    I will querie it with the guru at mitsu and get his explanation
    Henk
  13. #133
    This is really fantastic, you really have inspired me to do alot more work on mine!
    Thank you for all the absolutely fantastic info you have been supplying!
  14. #134
    4ePikanini Guest
    Quote Originally Posted by Nubnubs View Post
    Thanks!
  15. #135
    4ePikanini Guest
    Busy doing left inner CV boot
    Any bright ideas to get this circlip off? I can't get my circlip pliers into that small gap.
  16. #136
    Dude you are insane... i dream of buying an old sports car (Jaguar or Alfa) and doing it up! How did you learn how to do all of this, was it all from your Dad#
    I often think i should just buy a manual and go for it....
    VW Amarok 4Motion 2.0BiTDI D/C Auto
    Mitsubishi Triton 3.2 DID D/C 4x4 SOLD
    Alfa Romeo 3.0 V6 24v Spider SOLD
  17. #137
    4ePikanini Guest
    Quote Originally Posted by KiazerG View Post
    The foundations were laid by my father. Other than that I have spent a lot of time in the last 3-4 years going through forums and learning.
    The rest is about getting your hands dirty.
    Sometimes the manual describes stuff in detail that is actually very simple if you ignore the manual and just dive in and do it.
  18. #138
    Quote Originally Posted by 4ePikanini View Post
    You can try 2 screwdrivers and a bit of care
  19. #139
    4ePikanini Guest
    No chance. The gap is only about 1.5mm. I can barely get just one in there.
    I can get the one side up and over but then struggle to run the rest over.
  20. #140
    and if once you get one side up run a screwdriver around he edge, that should pop it off. you may not have enough hands though ;p
    Showed the old man the photo's and he said that the shaft is similar to that on a passat, he basically said that you need to really pul on that shaft to get it out, he said that you normally tie a rope onto the shaft with a weight or stop on the other end and you yank it out. on the otherside of that star is a ring clip which compresses inwards. the star should stay there when the shaft comes out.
  1. PRADO vs PAJERO
    Last Post: 2015/05/18, 10:25 AM
  2. My Pajero aint scared!!!!!
    By Tau in forum Mitsubishi
    Last Post: 2008/09/01, 03:54 PM
  3. Gen3 Pajero Survives 6-car pile-up
    Last Post: 2007/09/06, 09:16 AM
  4. New Pajero
