Fixing my old/new Pajero - pic intensive - Page 4
Page 4 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 61 to 80 of 194
  1. #61
    4ePikanini Guest
    Maybe split parts & labour?
    Have done so and will post at the end when I have the final tally
    Updates
    New TO Bearing
    CV joints feel fine but I need to do CV boots
  2. #62
    4ePajero Guest
    Did Barry machine the rear flange on the crank (where the oil seal runs)?
    High mileage engines often leak oil here.
  3. #63
    4ePikanini Guest
    I didn't ask specifically but I think he did as the block looked like it was machined ( or at least polished/cleaned ) at both ends.
  4. #64
    4ePikanini Guest
    Got the motor home at 18:15
    Got it ready to go with mountings on the hoist at 19:45 after dinner
    and this is at 21:10 with transmission and engine mountings bolted down
  5. #65
    Thanked: 8
    Looking good, seems like you may just make the SURVEY trip.
    V8 Cruiser & Comfort trailer
    The first 40 years of childhood are the toughest!
  6. #66
    4ePikanini Guest
    Quote Originally Posted by Randy View Post
    what survey trip
    There is still lots of work to be done and I need shocks and tyres.
  7. #67
    Thanked: 8
    [QUOTE=4ePikanini;344794]what survey trip
    QUOTE]
    with 4ePajero - ? next week or two's time
  8. #68
    4ePikanini Guest
    I won't do it with the current tyres and I wouldn't feel good taking such a long trip so soon after a rebuild.
    Next time though
  9. #69
    4ePajero Guest
    Well done so far!
    Take your time, do it right!
    We'll do a good Transkei trip in December!
  10. #70
    Thanked: 59
    Jaaa Paaaa.... Looks good
  11. #71
    4ePikanini Guest
    oh for pete's sake
    workshop swapped the camshaft covers.
  12. #72
    Kleinmond
    Thanked: 60
    Quote Originally Posted by 4ePikanini View Post
    oh for pete's sake
    Never trust anybody to do anything right on your behalf until you have checked it yourself !!!
  13. #73
    Pietermaritzburg
    Thanked: 16
    Thought your Oil filler cap was on the wrong side
    Sorry! But its looking good so far, keep us posted!
    2002 Colt, 2.8 tdi Rodeo, 4x4, ARB Bull Bar, Excalliber Running Boards, Monroe Gas Magnum Shocks, Cooper AT3's, Excel 53l long range tank, National Luna Dual Battery System, Campmaster 80l Fridge/Freezer Combo, FrontRunner Fridge slide and Bin Slide, Alpha Gte Canopy with FrontRunner Roof Rack and Homemade Awning...Pulling a Caravan sometimes
  14. #74
    4ePikanini Guest
    I'm starting to think about the monitoring of the vitals on my engine.
    Where is a good place to get
    oil pressure feed?
    oil temp feed?
    water temp feed? ( depending on the answer of question below )
    Is the standard temp gauge measuring the water pre or post thermostat? I would think pre- thermostat because you can see the temp rise but this can also be due to heat transferred through the metal. I want to be sure as I want the temp reading before the thermostat as a stuck thermostat will show the heat rising on the standard gauge quicker than a post thermostat location.
  15. #75
    Vanderbijlpark
    As you should be able to see, just below your thermostat housing there are 2 sensors. These should be; 1) gauge temp sensor; 2) ECU temp sensor.
    So yes, it should be pre thermostat.
    Hope this helps?
    95, 3L V6, LWB Pajero, Replacement front Alloy bumper, 31x10.5 Copper STT's, Dual batteries.
  16. #76
    4ePikanini Guest
    wife came looking why I was swearing
    as it stands now. Just the front to do. Starter and exhaust all buttoned up
  17. #77
    Kensington till further notice.
    Hey Pikanini,
    Looks as if you're doing well so far. Keep up the good work. By the way, if I understood correctly, the wiring ball s called a "CROWS NEST".
    Wish yo well
    Tony
  18. #78
    4ePikanini Guest
    The wiring doesn't scare me. While the engine was at the workshop I went through it and re-wrapped it so it's strong and good. I also took many pictures of where everything goes ( there are no duplicate plugs so I just have to match actually )
  19. #79
    4ePikanini Guest
    Calling on the experts
    It's been a while since I disassembled and can't remember in what order I took it off. Can you advise on the order to assemble the front?
    I'm sure I can figure it out but I hate having put something on and then having to remove it again because something else has to go first. - already had to take the inlet manifold off because I forgot the breather screw thing on the tappet cover that has a hose going to the throttle body
    still need to do ( what I can remember )
    a/c compressor
    ps pump
    cambelt covers
    alternator
    coil brace thingy on the inlet manifold
    viscous fan
    radiator and cowling
  20. #80
    4ePikanini Guest
    I aligned the dizzy like this before dropping it in. is it correct?
  1. PRADO vs PAJERO
    Last Post: 2015/05/18, 10:25 AM
  2. My Pajero aint scared!!!!!
    By Tau in forum Mitsubishi
    Last Post: 2008/09/01, 03:54 PM
  3. Gen3 Pajero Survives 6-car pile-up
    Last Post: 2007/09/06, 09:16 AM
  4. New Pajero
