Fixing my old/new Pajero - pic intensive - Page 10
Page 10 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10
Results 181 to 194 of 194
  1. #181
    4ePikanini Guest
    Anti-Roll bar
    Got some post today
    The before
    The during
    and the after
    Steps
    - loosen and remove first top nut on anti-roll bar ( arb )
    - loosen and remove second nut on arb
    - remove the washers and top rubber noting the order
    - loosen bottom nut that bolts to the lower a-arm
    - jack up arb with a bottle jack until the arb clears the shaft
    - swivel the shaft out and replace the bottom rubber - I actually removed the whole thing
    - swivel back the shaft and slowly release the arb back onto the threaded area
    - put other stuff back in order - noting to compress the rubbers for about 5 turns only ( if you keep turning the first nut you will over compress the rubbers and make them fail early ) and then doing the up the second nut tightly.
    - clean up
    Tools required
    14mm spanner
    14mm socket and ratchet
    4 poly replacements
    Time
    My first time took 25 minutes in total for both sides including packing tools away
  2. #182
    4ePikanini Guest
    Wow!
    Just got back from a short drive.
    I have to say I never thought those small rubbers make such a big difference. No more 'clunking' and the steering is much sharper and more responsive.
    It's a 20 minute cheap job and makes a world of a difference to the steering. I can almost think it handles better than the jetta!
    I have added simple instructions above on how to do them.
    Now to find the loose bolt on SWAMBO's seat
    EDIT - found the seat problem - The teeth wasn't hooking the adjustment catches on the rails causing the seat to have play. A slight bend on the teeth solved the problem.
    Now the pajero is rattle free! Gives the car a real good quality feel.
  3. #183
    Quote Originally Posted by 4ePikanini View Post
    Update
    Got these at a bargain ( less than R50 ) overseas so they are on their way here.
    Thanks for uploading so many pictures, very helpful to other people fixing the same type of cars.
    Where did you order these bushings from, and how much was the shipping? I need to get some for my Suzuki SJ.
  4. #184
    4ePikanini Guest
    I ordered from milner off-road
    They charged me 3.50 for carriage and the marked the value on the package as 50 so I had to pay R55 tax
    Anyway it's still not too bad but had I known the extra costs I would just buy poly from the hardware store and turn and cut my own.
    On the other hand it is nice to just bolt in ready made parts.
    Lots of stuff can be sourced on fleabay but make sure the seller supports registered shipping otherwise about a third of your orders will end up in Nigeria. ( Make sure of the total cost before buying - some things can be had for very cheap but others not - shop around )
  5. #185
    Thanks, have been looking around on e-bay and various other import sites. Certain genuine parts from the dealers are unjustifiably expensive.
  6. #186
    Thanked: 838
  7. #187
    Thanked: 838
    I went through this thread again looking for some pics and info.
    Man, i should never have sold that pajero!
  8. #188
    Jan 2011
    Hehehehe...not as fancy as the Treg, but much less debt
  9. #189
    Thanked: 838
    Quote Originally Posted by pblaauw View Post
    Precisely. And much cheaper to fix.
  10. #190
    Jan 2011
    Hindsight...20/20
  11. #191
    Thanked: 33
    Wrong! You should never have sold THOSE Pajero's! Both were excellent vehicles. I almost made the same mistake recently but luckily got my head straight. If I can just sort my ABS kickback problem!! Maybe I must bring it to you and leave it there for a month to tinker :-) , just to get you back in the Pajero spirit!
    No - come to think of it, that will be a bad idea as you might not give it back to me! :-)
    CATS
    Sent from my GT-P7100 using Tapatalk 2
    2009 Pajero 3.2 DiDc GLS (Casper) Blank canvas with some blobs
    2003 Safari Xplorer
    Previous : 1996 Colt Rodeo 3000 V6 (The Original! - SOLD) : 1998 Colt Rodeo 2.8Tdi (My first Diesel - SOLD) : 2008 Pajero 3.2 DiDc GLS (Sylvester - SOLD) : 2001 LR Defender 90 (Grizzly - Sadly SOLD) : 2010 LR Discovery 4 HSE (Snow White - SOLD) : 2001 Pajero 3.2 DiD GLS (Snoopy - SOLD but never forgotten)
  12. #192
    Witbank
    Thanked: 7
    Default Changed my mind
    Marius, I think you have just changed my mind regarding selling my LWB. Still between two fires though.
    I was getting annoyed with the repairs on it but yes, I love it and maybe she will be fine again one day when I get her back from the mechanic.
    I was going to get get rid of it once she is back home. Lets see how she behaves after the engine rebuild
    "If you can park your car and NOT turn around to look at it as you walk away, you haven't bought the right car"
    Fancy Nancy - 2009 Pajero 3.8 Liter 24 Valve V6 SOHC MIVEC ECI- Multi Engine 6G75 with 184Kw & 329 Nm.
    Topless Tersia - 96 J-Top SWB 3.0 V6 Pajero. Restoration 99% completed.
  13. #193
    Oct 2012
    Default Phwoarr
    Phenomenal thread this.. major kudos to the 4e's..
    Thanks very much Marius for all this.. I'm light years away from having even the slightest bit of such knowhow - but I truly look forward to being able to mission oneday!
    Thanks again for all your hard work documenting all this - may it stay in the digital world as long as the Pajero's will in the real one!
  14. #194
    Thanked: 838
    That pajero is long gone. I have a touareg thread now worth over 100 pages.
    Thanks for the kind words.
  1. PRADO vs PAJERO
    Last Post: 2015/05/18, 10:25 AM
  2. My Pajero aint scared!!!!!
    By Tau in forum Mitsubishi
    Last Post: 2008/09/01, 03:54 PM
  3. Gen3 Pajero Survives 6-car pile-up
    Last Post: 2007/09/06, 09:16 AM
  4. New Pajero
