Tyre Pressure Monitor
Results 1 to 14 of 14
    Nov 2012
    Default Tyre Pressure Monitor
    About 9 years ago I bought a Tyre Dog monitoring kit with external sensors from ebay and it was shipped from Taiwan. I have now got 2 faulty sensors and the display holder is broken. I am unable to locate replacement sensors and the ebay suppliers no longer ship to RSA. Can anyone assist with information as to where to obtain new sensors or recommend another make which doesn't cost a fortune. Incidentally , the old iunit has saved me from destroying 2 tyres on my Land Cruiser 75 series.
    Jun 2017
    Kuilsriver
    Thanked: 27
    Default Re: Tyre Pressure Monitor
    Try Aliexpress
    They ship from various suppliers in China and you will have to be prepared to wait for your thingies approx. 4 to 8 weeks.
    Sandton
    Thanked: 42
    Try Abraham - abraham@tireguard.co.za - 0829260585 (Abe on forum). He sells Tyreguard - great service. I have used mine for about 7 years. Saved me from ruining tyres about 6 times!
    2013 Discovery 4 SDV6S
    2008 Discovery 3 TDV6S (SWAMBO)
    Imagine Comfortvan
    Sep 2010
    Brymore, Port Elizabeth
    Thanked: 18
    These screw-on units- do they affect the balance of the wheel? What about the centrifugal force on the valve stem, will the valve be happy being pushed against the rim?
    Pieter
    2008 Fortuner 3.0 D-4D 4x4
    Struisbaai
    Thanked: 191
    Quote Originally Posted by JonvZ View Post
    Went the same route with Tyre Dog.The replacement units are very expensive.When I wanted to replace them 4 years ago they were R700 each.Rather get a new unit like Valor with internal sensors.Ive had mine for 4 years and never had a problem.
    Then give the Tyre Dog a float test.Mine did not make the test.
    2015 Land Cruiser 79 D/C V8 Diesel Turbo
    1983 Suzuki SJ 410 SOA.
    Bush Lapa Boskriek No 607 - Die Kriek
    Melkbosstrand
    Thanked: 50
    Quote Originally Posted by BarOne View Post
    I have those units, and haven't noticed anything...
    BUT, what you could do is fit the units before the garage balances... that way it'll be properly sorted.
    2015 VW Amarok 4motion Auto
    2011 Conqueror Companion
    Sandton
    Thanked: 42
    Did not cause any balance issues nor issues with centrifugal force on the valve stem on the car. However on the Comfortvan the centrifugal force did cause an issue due to the valve stems being quite long. Solution - fit shorter valve stems.
    Imagine Comfortvan
    Feb 2018
    I can vouch for Tireguard from Abraham. Good service, good quality, works well.
    Saved 1 tire for me recently in Namibia.
    In the kit included is precut valve stem covers made from high density foam to prevent the valve stem from "flapping" against the rim etc.
    Otherwise fit shorter stems.
    Wartburg
    Thanked: 416
    I use balancing beads in my tyres - have not had any balancing problems since using these instead of conventional lead weights.
    Thanked: 19
    Tireguard
    Ford Ranger 3.2 Auto 4x4 Wildtrak
    Invader duo
    Aug 2011
    Thanked: 19
    You can always use a service like Aramex Global shopper. They give you an address in 50 countries or so and then you just let the seller send it to that address and then they courier it to you.
    May 2012
    Quote Originally Posted by Oswald View Post
    Tireguard
    Does it show all the tyre pressures on one screen?
    2012 TOYOTA FORTUNER D4D 4x4 AUTO
    May 2011
    Thanked: 303
    Quote Originally Posted by Blinkie View Post
    You need to scroll through. But it will warn you and then you can check immediately!
    May 2012
    Quote Originally Posted by Luka View Post
