Suzuki Jimny 2015 speaker sizes
Results 1 to 6 of 6
    Dec 2012
    Randburg
    Default Suzuki Jimny 2015 speaker sizes
    Good day all,
    I am in the process of upgrading my stock sound system from my newly acquired Suziki Jimny 2015. I tried to google online but got a mixed result between the older models and the SJ etc. So I just decided to open her up and have a look.
    Here is my findings:
    Stock Front Speaker:
Name:	2018-06-10 09.44.50.jpg
Name:	2018-06-10 09.46.08.jpg
Name:	2018-06-10 09.46.31.jpg
Name:	2018-06-10 09.45.40.jpg
    Now when I convert 4" to cm one gets 10.16cm. My concern is that the front cutouts are certainly smaller. If anything they more like 9cm?
    This worries me as I cannot simply order a new set of 4" speakers and know that they are gonna fit?
    With regards to the rear, I read that they should be 5" 1/4" (slightly larger than the front).
Name:	2018-06-10 10.17.25.jpg
    Now these look more like your 4" hole cutouts?
    Maybe some one has some experience with this?
    What other options do I have?
    Can one cut the hole larger using a dremmel?
    I donot like the idea of this as the stock cutout has rounded edges. If I cut it, its then opening up metal to rust and could affect the structural integrity (especially at the back as the seat-belt bolts onto the metal right next to the speaker.
    See seat-belt connection here:
Name:	2018-06-10 10.17.00.jpg
    However at the back there is plenty of space to cut out a 5" hole for some decent speakers.
    In the front there is minor space. However I have noticed in the front there is quite a bit of space (2-3 cm) between the speaker and the plastic cover. This means one could maybe come OUT abit. Maybe build a spacer ring which will take a larger speaker, as long as the magnet (back of the speaker) fits into the stock hole? (however this is going to heavily depend on the new speakers dimensions and build.)
    Suzuki Jimny 2015
    Ford Focus Mk1 2003
    cape town
    Thanked: 349
    Default Re: Suzuki Jimny 2015 speaker sizes
    speakers are measures from screw hole to screw hole not cone size.
    Dec 2012
    Randburg
    Quote Originally Posted by Ocin View Post
    Aah that makes a significant difference.
    Im assuming there is then an international standard as to what dimensions will fit, Ie speaker hole is 8 mm from cutout.
    Suzuki Jimny 2015
    Ford Focus Mk1 2003
    cape town
    Thanked: 349
    Quote Originally Posted by Zapnologica View Post
    unfortunately there is no standard and speaker sizes do differ a bit from brand to brand but usually the hole is big enough for the cone to fit.
    May 2013
    Klerksdorp
    If they don't fit, just either buy spacers, or make them from mdf
    My Youtube Channel
    04 Mitsubishi Pajero 3.8 V6 SWB On the Audio side..
    63mm freeflow and Rocksliders from PEPA customs JVC KD-R971BT headunit,Focal Access Tweeters, Morel Maximo Midrange, Jl 12W3v3-4 subwoofer
    Dastek UniChip
    MAXE Nudge bar with Warn Spotlights
    Front and rear bash plates
    Stofpad lift spacers
    265/65R17 General Grabber AT
    Dec 2012
    Randburg
    I went to an audio shop and ask them if I can try just fit some speakers for sizing.
    If you just want plug & play:
    > front is 4"
    > rear is 5"
    However 5 1/4" does fit in the rear hole. Just the mounting holes do not line up.
    I went for the slightly larger ones in the back. However I had to drill additional holes. Which work fine, However there is a good chance these will strip should I ever remove the speaker a few times.
    Here are some images for interest sake:
    Front 4:
Name:	2018-06-10 17.17.58.jpg
    Rear 5 1/4"
Name:	2018-06-15 18.00.18.jpg
    Suzuki Jimny 2015
    Ford Focus Mk1 2003
  7. The Following User Says Thank You to Zapnologica For This Useful Post:
