Higher Profile tyres for Discovery 3 TDV 6
Results 1 to 10 of 10
    Mar 2018
    Goba
    Thanked: 30
    Default Higher Profile tyres for Discovery 3 TDV 6
    Getting the D 3 back on the road ..new Tyres is needed….
    The D3 will be mostly used on very thick sand with sharp sticks and branches hiding underneath and possible sidewall damage is a risk… towing a Challenger trailer
    Little bit of mud and mostly gravel but all terrains will do the job….
    I am a high sidewall fan..(My Disco 1 runs on 235/85/R16) I had one sidewall cut in 5 years on those Nankang’s..and got my 60 000 Km from them and installed 4 new Nankang’s January. My spare was used only once for 100 Km when I had the side wall damage
    (And the old used ones is now working on farm trailers)
    Seems the recommended tyre is 255/60/R18 and the highly appraised Pirelli Scorpion is R 2700-00
    My question:
    Will 255/70/R18 fit without rubbing..I do not want to do any wheel arch mods on the D3
    Yokahama Geolander @ R 2100-00 x 5
    GT Radials Adventura @ R 1700-00 x 5
    The Pirellei Scorpio in this size is R3600-00 each and It seems to be P rated
    On forums I have found :
    265/70R18: won't fit without extreme modification
    Is it the profile Hight or Width ??
    285/65R18 (won't fit without a _lot_ of work): Nitto TrailGrappler, BFG AT, Hankook AT
    275/65R18 (won't fit without a bit of work): Maxxis Bighorn, Hankook MT, Dunlop Rover MTTMAX, Goodyear MTR Kevlar, Cooper STT
    285/60R18: Cooper Zeon LTZ, Nitto AT, Procomp AT, Falken AT, Dunlop Grandtrek AT3 ?? They say Nothing ..it is just noted..
    I do plan to install a spare wheel carrier at the back…..
    1997 Discovery 1 300 TD i ...Old Faithful
    2006 Discovery 3 2.7 TDV 6...not sure yet ?
    The Windy City
    Thanked: 2292
    Default Re: Higher Profile tyres for Discovery 3 TDV 6
    I've had 275/70R17's fitted, it was tight but it fitted. Note though that was with the lift rods installed.
Name:	2013-07-20 12.12.47.jpg
ID:	490996   Click image for larger version.
Name:	2013-07-20 12.21.59.jpg
ID:	490997   Click image for larger version.
Name:	2013-07-25 12.45.13 a.jpg
  3. The Following User Says Thank You to Dirk For This Useful Post:
    Mar 2018
    Goba
    Thanked: 30
    Dirk
    Thank you,
    It crossed my mind to go back to 17's
    As stated in a post ....there is a wider choice and cheaper...
    If I am not mistaken the 2006 TDV 6 D3 came out with 17's
    I like that ...the lift rods is censored I believe...?
    Tzaneen
    Thanked: 124
    The sizes you look at will not fit in the spare well.....you will have to fit the spare carrier
    Tha profile is a % of width.265mm width /65(%) of the width is the hight=172mm.
    Consider 17".The S models all came with 17" std.
    2012 RR TDV8 4.4
    2006 TDV6 SE A/T(Sold)
    2008 FL2 TD4 SE A/T
    1968 Renault 8 Gordini
  6. The Following User Says Thank You to DiscoFrans For This Useful Post:
    The Windy City
    Thanked: 2292
    Quote Originally Posted by DiscoFrans View Post
    I did a swop of 18 to 17 just after I got the Disco.
    The spare does fit, but you have to deflate it, and a rachet strap helps plus a bit of fighting
  8. The Following User Says Thank You to Dirk For This Useful Post:
  9. #6
    The Windy City
    Thanked: 2292
    Quote Originally Posted by LRTDV6 View Post
    Meaning?
    I had lift rods fitted for 3 years, only took them out when I had the electronic unit fitted (and now they lying on my desk!)
  10. The Following User Says Thank You to Dirk For This Useful Post:
  11. #7
    Mar 2018
    Goba
    Thanked: 30
    Meaning?
    Thank you Dirk
    Answered me perfectly...Did not know there is permanent lift rods...and electronic unit..
    I would also prefer the electronic unit...
  12. #8
    The Windy City
    Thanked: 2292
    Thank you Dirk
    Yes, but it is R7000 for suspension controller VS R500 for the rods....
    I've had both, if I had to do it again I will probably stick with the rods, the controller is nice, but it is just a nice to have, I cannot say that I needed/used it once really other than showing people what it can do.
  13. The Following User Says Thank You to Dirk For This Useful Post:
  14. #9
    New Germany, Durban
    Thanked: 299
    Unless you opt for the IIDTool which does diagnostics and other configurations also. Rods work just as well.
    265/65/18 rubs on full lock and tends to hook the front bumper on the standard ride height. It is a little better when lifted 30mm in the front by default.
    265/60/18 doesn't rub at all.
    When I have done bumper, etc. then i'll go 285/70/18 or something along those lines to get more rubber to work with.
    2010 LR Discovery 4 V8 HSE - Lifted with IIDtool, Powered by Petrol and Running on BFG KO2 265/65/18's or Achilles XMT's in 265/60/18 [Imvubu]
  15. The Following User Says Thank You to douglash For This Useful Post:
  16. #10
    Mar 2018
    Goba
    Thanked: 30
    Dirk, Thanks
    “Yes, but it is R7000 for suspension controller VS R500 for the rods....
    Ouch…With the cost getting the D3 alive again…R500 sounds like my cup of tea
    Will definitely go for the rod option if I can get ??/70/18 profiles at affordable price
    Douglash.. Thank you
    “Unless you opt for the IIDTool which does diagnostics and other configurations also. Rods work just as well.
    “When I have done bumper, etc. then i'll go 285/70/18 or something along those lines to get more rubber to work with.”
    That is my target….to get as much rubber as possible
