Engine bay or load bin, that is the question?
Results 1 to 7 of 7
    Sep 2010
    False Bay
    Thanked: 48
    Default Engine bay or load bin, that is the question?
    I intend fitting a dual battery system shortly and have the option of positioning the battery either in the engine bay or load bin (double cab).
    An aluminium canopy will be fitted soon and I will do the fitting out myself with various power off-take points, both 12v and 220v. There will also be a connection for solar charging.
    What are the pros and cons of the battery either in the engine bay or load bin?
    Sam
    ZS1SAM
    V5/ZS1SAM
    HAMNET
    2018 Toyota 2.4 GD6 SRX D/C 4x4 auto
    Land Rover Defender 110 Puma - sold
    Metalian Mini
    Feb 2013
    Thanked: 41
    Default Re: Engine bay or load bin, that is the question?
    My thoughts,
    * Inside engine bay doesn't take up space in the load bin which is quite a big thing especially in a double cab.
    * Inside engine bay exposes the battery to a lot of heat which can't be good for it in the long run.
    * Depending on the type of charger you choose, DC/DC chargers generally don't like heat, which can be a problem if you want to mount in the engine bay.
    Would be interesting to see other opinions, I'm personally quite 50/50 on this one.
    You probably heard people saying Africa is not for sissies. Well, neither is it for wussy equipment.
    Man who dies with most gear wins!
  3. The Following 2 Users Say Thank You to bigboy529 For This Useful Post:
    Aug 2007
    Stellenryk, Bellville
    Thanked: 206
    Load bin but as a portable unit that can easily be moved around, should the need arise.
    2007 Colt Rodeo 3000I V6 D/C 4x4 (Currently in surgery)
    Dual battery system
    57 mm freeflow system
    General Grabber AT3's
    Challenger Bundu Basher Off-road trailer
  5. The Following User Says Thank You to Blackie For This Useful Post:
  6. #4
    Clanwilliam
    I had the same problem last year.
    In the end I went with the load bin as most of the articles I read said that DC/DC chargers (well most of them) do not like the heat of an engine bay to much.
    I went with a permanent installation close to cab (shortest distance), mostly because I am to lazy to clamp it down or remove it all the time.
    Plus you do not want something that heavy in the load bin that is not secured, esp when doing a bit of 4x4.
    But will be interesting to see what the experts say
  7. The Following User Says Thank You to HiluxRoux For This Useful Post:
  8. #5
    Thanked: 531
    I used to have the second battery in the D/Cab load bin, and found it to be a nuisance. Also, I could use the space much better.
    Providing you have the space I will go for the engine bay option. However, first make sure you use a battery that can handle the heat. If you want to go for the engine bay, stay away from Lead Crystal - they cannot handle it. My battery sits in the engine bay, with the DC-DC charger under the dash behind the cubby, a very short distance away. I bought my battery second hand after it came to its replacement date in a cellphone tower, and it has now done 3 years under the bonnet, still doing its thing as if it was just installed. I also run a 45 L freezer in the car, and whilst driving I charge another battery in the caravan which powers a 90 L 12 volt compressor fridge. This caravan battery is a Lead Crystal.
    When you are dead, you don't know that you are dead. It is difficult only for the others.
    It is the same when you are stupid.
  9. The Following 2 Users Say Thank You to Poen For This Useful Post:
  10. #6
    Feb 2012
    Bloubergrant
    Thanked: 62
    If your solar panel will be mounted permanently on the roof of the canopy, then engine bay could work. I found that for prolonged camping, mobile battery unit and non-fixed solar panel works best, gives you freedom to use the vehicle and also get optimal charge from sunlight - solar charging is in my view far more effective than car charging.
    2007 Hilux 2.5 D4D
  11. #7
    Sep 2010
    False Bay
    Thanked: 48
    Thanks for all the comments and suggestions.
    Load bin in a battery box is my choice for maximum flexibility.
    Sam
    ZS1SAM
    V5/ZS1SAM
    HAMNET
    Metalian Mini
