Trailer nose weighing
Results 1 to 20 of 20
    Jul 2009
    Bellville
    Thanked: 20
    Default Trailer nose weighing
    I want to get something that I can use to weigh the nose load before I hitch. One option is the "Noseload" device. anyone using this or something else recommended?
    Melkbosstrand Cape Town
    Thanked: 44
    Default Re: Trailer nose weighing
Size:  203.0 KBI use one of these , had it for years , just hook it under the coupler.
    Jul 2009
    Bellville
    Thanked: 20
    Looks good, but how do you use it? Did you build something you hang this on and then attached the trailer or do you hang this o the towbar some how?
    Aug 2008
    Rangeview Krugersdorp
    Thanked: 492
    Use bathroom scale. After 2 trips you'll know how to pack to get correct weight.
    Chev Aveo and Atos and Polo.
    Nov 2008
    Ellisras
    Thanked: 49
    I use a bathroom scale
    - Hook the trailer
    - lift the jockey wheel
    - insert the scale with a small plank on it for protection
    - slowly lift the trailer with the jockey wheel jack until all load off the car ball
    bobsyouruncle
    2000 Patrol GU 4.2D(onkey) @ 800 000 km
    Thanked: 633
    - Hook the trailer
    bobsyouruncle
    You are correct.
    Just putting the scale under the jocky wheel will not give you the true ball weight
    The lever distance from the jockey to the coupler is quite significant and will make a measurable difference
    Dum vivimus, vivamus!
    LC76V8
    Wilderness
    Thanked: 568
    That will not give you the true ball weight
    You obviously did not read his post properly, or do not comprehend his post!
    2003 Grand Cherokee 2.7 Limited. 2" lift. Cat-less. EGR defeat.(For sale)
    2011 Isuzu 300d-teq 4x4 d/c
    Building a new offroad caravan.
    Thanked: 633
    Lol...
    I read until "lift your jockey....."..
    My bad
    LC76V8
    Melkbosstrand
    Thanked: 45
    There's an article is the latest Go Camping magazine, using a weighbridge.
    first van only...
    then van wheels, while connected to the car (car not on the bridge)... difference is true ball weight.
    2015 VW Amarok 4motion Auto
    2011 Conqueror Companion
    Thanked: 44
    Quote Originally Posted by Andrew Rodrigues View Post
    I use two strong hooks top and bottom of scale , hook the bottom one under the coupler where the ball goes and put a bar through the top hook . I can lift it by myself if light enough or two of us lift the bar if it is heavy.
    Jun 2007
    EDENVALE
    Thanked: 797
    first van only...
    But that is different to the vertical ball weight imposed by the trailer, isn't it?
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Thanked: 18
    first van only...
    Most weighbridges round up or down to the nearest 20 kg. Quite a difference when the maximum allowed by law is 100 kg
    Thanked: 1155
    You are correct.
    Will not give the correct ball load but that is easy to calculate. Distance from jocky wheel to axle/ball to axle * scale reading.
    Jouko
    2003 Grand Cherokee 4.7l
    2012 Smart
    Never drive a normal car
    Melkbosstrand
    Thanked: 45
    Quote Originally Posted by Coltmaster View Post
    Really? Wow, ok, thanks
    Nov 2008
    Ellisras
    Thanked: 49
    You are correct, but the distance from J/Wheel to axle is no less than 80% of the distance from Ball to axle
    Therefore you will be within 20% correct AND you will be over measuring...
    So, if the scale is under the J/Wheel - just multiply the scale reading by 0.8 and you will be close enough to the actual.
    Thanked: 797
    Why not make a post with a flat base and stand it on your scale? Weigh it beforehand and subtract from the total.
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Nov 2012
    Thanked: 187
    This the best idea yet.
    Choose life
  19. #19
    May 2008
    Thanked: 274
    A broomstick will do, with a small plank at the end to spread the load...
    Flip
    Awesome: Suzuki Jimny;
  20. #20
    Jul 2015
    Thanked: 188
    I checked my Bushlapa’s nose weight today with an old broomstick. All you want is that 1mm where the jockey wheel “lifts off”. I was surprised, my Bushlapa nose weight is 107kg. I need to see how i can reduce this weight since my Prado’s back tyres are sometimes running 60 degrees.
    [B]Prado TX 4.0|Rocksliders|Bash Plate|Lift| Bushlapa Miskruier 892 Past: FJ Cruiser Rav4 2.0 (SWAMBO)
