Weber trick - Page 4
Results 61 to 73 of 73
Thread: Weber trick
  1. #61
    Thanked: 176
    Default Re: Weber trick
    @KobusDJ
    What type of wood are you using there?
    I've tried a number of our indigenous hardwoods but most produce too much smoke and others make the meat bitter. The best local wood I've used so far is Swarthaak.
    BL324
    98 Hilux SFA 2.2 Ltd with EFI (Slakkie)
  2. The Following User Says Thank You to Geelvis For This Useful Post:
  3. #62
    Gaborone, Botswana
    Thanked: 428
    @Geelvis
    I have no idea what type of wood it is.
    It is hard and dry. Dry is very important... you get a very bad taste if not.
    Kobus
    HDJ81 VX
  4. #63
    Thanked: 54
    Quote Originally Posted by Geelvis View Post
    @KobusDJ
    Try and get hold of peach,cherry,pear
    Use two or three chunks not logs or you can overdo it
    The smoke gives you the taste and "bark" your coals do the cooking
    Low and slow
  5. #64
    Thanked: 176
    Quote Originally Posted by Grant Young View Post
    Low and slow
    Hi Grant,
    I have hickory, apple, cherry, pecan and mesquite chunks that I got from Big Green Egg.
    Many of our local hardwoods are like mesquite, which is very strong and should be used with reservation.
    I'd love to get some peach and pear chunks!
    BL324
  6. #65
    Randburg
    Thanked: 80
    So, kan ek die perske takke gebruik wat ek gaan afsnoei hierdie winter? Ek het 'n paar Kakemas, Orion en Oom Sarel bome wat ek moet snoei.
    Touareg V10
  7. #66
    Aug 2010
    Centurion, Pretoria
    Thanked: 69
    His:
    2010 Daihatsu Terios 4wd manual, GIZ Top R 3 inch suspension lift and shocks, GIZ Fiber glass Snorkel, Bash Plates.
    1999 Discovery II XS V8 Autobox, with some mods...
    Hers:
    2015 Ford Figo 1.4i Ambiente.
    Ours:
    2016 Campmaster Compact 100 trailer.
  8. #67
    Apr 2017
    Thanked: 119
    @KobusDJ
    Try using wood that does not have bark ,bark smokes excessively and for some reason has those bitter flavours
  9. #68
    Thanked: 54
    Hi Grant,
    I am fortunate to live in Stellenbosch
    Is just ask the fruit farmers
    Mesquite is to strong I find the smoke bark is somewhat bitter so I don't use it
  10. #69
    Thanked: 54
    Quote Originally Posted by Dudleytheplumber View Post
    Yes should have made it clearer no bark on the chunks
    Also was referring to the smoke"bark" on the meat
  11. #70
    Apr 2017
    Thanked: 119
    You right clear the bark off the chunks...bark on the meat new for us at least it has no bite
  12. The Following User Says Thank You to Dudleytheplumber For This Useful Post:
  13. #71
    Thanked: 176
    Quote Originally Posted by SpiderGear View Post
    @Spider Gear
    That's exactly the right wood to use. Just make sure it's properly dry.
    BL324
  14. #72
    Thanked: 176
    Quote Originally Posted by mariusrautenbach View Post
    Nothing wrong with their wood Marius.
    I use their orange, almond and olive wood. The olive is fantastic for lamb on the Weber and citrus always goes well with chicken, pork and even beef. It's a very mild smoke flavor.
    I've ordered one of these from the UK and I'll be using the wood dust available from SA BBQ Smokers.
    https://www.proqsmokers.com/cold-smokers
    BTW: SA BBQ Smokers also offer smoking seminars for those of you that would like to learn more about this dark art.
    BL324
  15. #73
    Thanked: 176
    Thanks Dudley!
    I always remove the bark from indigenous wood like Sekelbos, Kameeldoring etc. They still generate more smoke than I would like and for this reason I seldom use our local woods. The local hardwoods aren't too bad in electrical or gas smokers as the ood is the only source of smoke. When using charcoal or briquettes, they add more smoke
    Fruit trees like apple and peach have a very thin bark which makes no difference at all to the flavor.
    https://biggreenegg.com/product/smoking-chunks/
    These are by far the best smoking chunks available in SA. They're expensive but a little goes a looonngg way.
    BL324
  16. The Following 2 Users Say Thank You to Geelvis For This Useful Post:
