Weber trick - Page 4
Results 61 to 70 of 70
Thread: Weber trick
  1. #61
    Thanked: 174
    Default Re: Weber trick
    @KobusDJ
    What type of wood are you using there?
    I've tried a number of our indigenous hardwoods but most produce too much smoke and others make the meat bitter. The best local wood I've used so far is Swarthaak.
    BL324
    98 Hilux SFA 2.2 Ltd with EFI (Slakkie)
  2. The Following User Says Thank You to Geelvis For This Useful Post:
  3. #62
    Gaborone, Botswana
    Thanked: 428
    @Geelvis
    I have no idea what type of wood it is.
    It is hard and dry. Dry is very important... you get a very bad taste if not.
    Kobus
    HDJ81 VX
  4. #63
    Thanked: 54
    Quote Originally Posted by Geelvis View Post
    @KobusDJ
    Try and get hold of peach,cherry,pear
    Use two or three chunks not logs or you can overdo it
    The smoke gives you the taste and "bark" your coals do the cooking
    Low and slow
  5. #64
    Thanked: 174
    Quote Originally Posted by Grant Young View Post
    Low and slow
    Hi Grant,
    I have hickory, apple, cherry, pecan and mesquite chunks that I got from Big Green Egg.
    Many of our local hardwoods are like mesquite, which is very strong and should be used with reservation.
    I'd love to get some peach and pear chunks!
    BL324
  6. #65
    Randburg
    Thanked: 80
    So, kan ek die perske takke gebruik wat ek gaan afsnoei hierdie winter? Ek het 'n paar Kakemas, Orion en Oom Sarel bome wat ek moet snoei.
    Touareg V10
  7. #66
    Aug 2010
    Centurion, Pretoria
    Thanked: 69
    His:
    2010 Daihatsu Terios 4wd manual, GIZ Top R 3 inch suspension lift and shocks, GIZ Fiber glass Snorkel, Bash Plates.
    1999 Discovery II XS V8 Autobox, with some mods...
    Hers:
    2015 Ford Figo 1.4i Ambiente.
    Ours:
    2016 Campmaster Compact 100 trailer.
  8. #67
    Apr 2017
    Thanked: 118
    @KobusDJ
    Try using wood that does not have bark ,bark smokes excessively and for some reason has those bitter flavours
  9. #68
    Thanked: 54
    Hi Grant,
    I am fortunate to live in Stellenbosch
    Is just ask the fruit farmers
    Mesquite is to strong I find the smoke bark is somewhat bitter so I don't use it
  10. #69
    Thanked: 54
    Quote Originally Posted by Dudleytheplumber View Post
    Yes should have made it clearer no bark on the chunks
    Also was referring to the smoke"bark" on the meat
  11. #70
    Apr 2017
    Thanked: 118
    You right clear the bark off the chunks...bark on the meat new for us at least it has no bite
  12. The Following User Says Thank You to Dudleytheplumber For This Useful Post:
