camping fridge cooling fan problem
Results 1 to 15 of 15
    Malmesbury
    Thanked: 54
    Default camping fridge cooling fan problem
    we have a snowmaster 60l double door fridge and the cooling fan gave us some trouble , it does'nt work to blow the air from the freezer side to fridge side
    i took the fan out and saw that if you bump anything to the side of the fan it jams ,then the fans gets pressed against the body so to speak ,and the cooling on the other compartment gets hotter .
    so, is there not something better than this tipe of fan that i can modify,
    i have allways tried to pack the stuff away of that fan ,but the trailor hop so baie op die grond pad ,but it is so a flimsy fan anyway ,any idees ,please
    Colt clubcab 2.8tdi 4x4 2005
    Ford Fiesta 1.4i (SWAMBO]
    opel corsa 1.7 dti 2006
    Aug 2008
    Rangeview Krugersdorp
    Thanked: 492
    Default Re: camping fridge cooling fan problem
    Proper PC fan ?
    Chev Aveo and Atos and Polo.
    Secunda
    Thanked: 64
    Tel: 011 392 5315 / 3147
    contact Snomaster
    Malmesbury
    Thanked: 54
    ja, gaan snowmaster bel ,dankie vir die tel. no.
    i have made a test today just to see what is happening to when i set the temp to it's highest ,here is some foto's i took about every 30 min apart
    the compartment on the right ,that is where the fan is to get the colder air is working just fine without the fan ,but i adjusted it to a higher setting and will check what the temp is in the morning .
ID:	488543   Click image for larger version.
ID:	488544   Click image for larger version.
ID:	488545   Click image for larger version.
    Malmesbury
    Thanked: 54
    i contacted snowmaster and the guy told me that i had the old tipe of fridge that worked with the fan and the new one's had a different setup
    so if i start up the fridge the day before both compartements will be ok,but i am going to modify that stupid fan for a larger one ,how i still don't know .
    Thanked: 142
    I have exactly the same snomaster. That little fan was replaced by me and to find the exact same one is impossible. So i put in a thicker one,which protrudes a bit on the fridge side.
    That little fan is a chinese gimmick. The aluminium sheeting of the cooler side goes cold from the freezer side.
    The switch or controller is only to switch off the pescy little fan , which also screams like a banshee when it is lekker cold.
    So what i am saying is that you should ignore it.
  7. The Following User Says Thank You to janseekat For This Useful Post:
    Thanked: 973
    My fan on my NL 40 gave up. Looked like aneasy job so I went to our local matrix and took the sample. No problem gave me a fan looked exactly the same size and power.
    Fitted it, ...... and now my fridge looks like a disco. This fan had a built in light
    BMW R1200R
  9. The Following User Says Thank You to Stranger For This Useful Post:
    Dec 2006
    Thanked: 29
    Quote Originally Posted by Alberto View Post
    Kontak Danie - Fastner Warehouse, Brackenfell, hy mag moontlik n oplossing gee 021 982 7120. Hy het op 'n stadium baie tipes kamp yskaste herstel. Weet nie of hy dit nog doen nie
    https://www.google.co.za/search?q=fa...1!2i415!4f13.1
    (die adres in Taurus straat is die huidige adres)
    Landcruiser 79 Series D/Cab 4.2L Diesel
    Bush Lapa Miskruier (no: 34)
    Malmesbury
    Thanked: 54
    Quote Originally Posted by janseekat View Post
    dis net soos jy se ,as dit begin skreeu dan raak ek gatvol ,maar daai yskas het geen einde nie hoor ,maar kan 'n mens die gat effe groter sny ,want jy kry 'n groter fan by brights ,maar kan dit die koue hanteer ,
    wil nie gat so los nie en koue wat ingeblaas word help lekker
    Malmesbury
    Thanked: 54
    dankie ,was jare terug by danie vir 'n klein probleem ,ken sy storie en sort gou gou 'n probleem uit en gee sommer raad ook .
  13. #11
    Malmesbury
    Thanked: 54
    laaste foto sonder die fan in .
  14. #12
    Thanked: 142
    Toets die fridge kant met sommer n huis termometer ,jy kan so 3-5 grade aftrek.
    Voel met jou hand die binne wand van die fridge , dan sal jy voel hoe koud hy word.
  15. #13
    Thanked: 142
    Alberto hier is nog iets vir jou snowy
    Isoleer wand binne die "cover"veral die vloer. Gemaak van oefen mat ,pattex.
    LED vir krag en die compressor. .
    Om te sien of die yskas se krag gekoppel is Krag led vanaf die + op die controller van compressor. Ek het dit gedoen nadat my lighter plug op 12v nie so lekker gekontak het nie. Toe weet ek van niks . Die geel led is die krag.
    Rooi Compressor led vanaf die cooling fan op die condenser. so as cooling fan aangaan saam met compressor brand die led.Gaan af saam met comp.
ID:	489134   Click image for larger version.
  16. The Following User Says Thank You to janseekat For This Useful Post:
  17. #14
    Malmesbury
    Thanked: 54
    JAN, ek lag lekker vir die naam van die yskas ,snowy, ,dit gaan van nou af hier genoem word
    die led lig is briljant hoor ,ek het altyd maar oor gegooi met die opstart slag ,as die probleem verlede jaar gebeur het dan het ek by jou 'n draai kom maak ,ons was des 25 in jou dorp oppad mata mata toe en by daan viljoen oorgeslaap.
    die oefenmat is dit vir die koue inhou of vir die stampe .
  18. #15
    Thanked: 142
    Die oefenmat is vir koue issolasie , dit werk goed..
    25 Des moes jy my op Myl 72 kom soek het.
    Groetnis
    Coenie
