Inverter wanted - Mean Well TN-1500
Results 1 to 10 of 10
    Thanked: 30
    Default Inverter wanted - Mean Well TN-1500
    Hi, I am looking for a Mean Well TN-1500 12VDC inverter. If you know of one, please let me know.
    Thanks!
    Herman
    Somerset West when not in Jhb
    Thanked: 63
    Default Re: Inverter wanted - Mean Well TN-1500
    Thanks!
    Herman
    Hi Mygoggie, why this specific model?
    ORRA Callsign: X130
    Thanked: 30
    Quote Originally Posted by Subok View Post
    I have two already and require one for the third load string in the house.
    12VDC input because I am running it off a set of 10 seawater cells I built.
    MPPT charger as I am planning to run three solar strings to charge the cells.
    UPS mode so I can get rid of all the UPS's in the house while using the grid as main feed.
    Thanked: 333
    CA might be able to help you
    https://www.rectifier.co.za/meanwell-tn-1500/
    You might also give Mantech a try.
    Eggie.
    - apology to Edward Langley.
  5. The Following User Says Thank You to Eggie For This Useful Post:
    Thanked: 30
    Thanks @Eggie, I have requested quotations from these companies already.
    cape town
    Thanked: 79
    current automation iirc are the agents for mean well. I see they don't have a branch in PE - tho they may have a rep there of sorts or can ship directly to you.
    I'm about 5min away from the cpt branch and can collect and postnet to you if needed.
    Thanked: 30
    Quote Originally Posted by RussellF View Post
    What a kind offer. Thanks @RussellF
    I will take you up on this if I do not get a secondhand one!
    Nov 2008
    Thanked: 44
    Thanks!
    Herman
    I have one that I started my PV project on, been contemplating installing in the caravan, but that is where it stays, with the contemplation. Was last serviced by Rectifier and have not taken out of the box since.
    Let me know, perhaps I can help you.
    Simplicity is the ultimate sophistication.
    - Leonardo Da Vinci
    Also on
  10. The Following User Says Thank You to Rooikop For This Useful Post:
    Thanked: 30
    Quote Originally Posted by Rooikop View Post
    Dankie het jou 'n PM gestuur.
    Thanked: 30
    @Rooikop managed to save my bacon. Package on the way to my non-nersa-compliant system.
    Mods you can lock the thread please.
