Solar panels configuration dilemma.
Results 1 to 19 of 19
    Mar 2017
    Thanked: 11
    Default Solar panels configuration dilemma.
    ave 250 w 24v x4 and 150w 12v x6. I have a 48 v battery bank of 800ah and mppt 60A 150v limit and a 48v kv inverter. zI need help with the pairing of the panels ad the voltage of the 12v panels in seried doed noy match the voltage of the 24 string
    and i wanted to connect the 2 strings in parallel
    Hillcrest, Malaysia
    Thanked: 3251
    Default Re: Solar panels configuration dilemma.
    Quote Originally Posted by Mbu View Post
    No real way to do it. Buy another MPPT charger and connect the 24V panels to one charger and the 12V panels to the other charger.
    24V panels - two strings of two panels in series, connected in parallel.
    12V panels - two strings of three panels in series, connected in parallel.
    ZS5KAD Yeasu Ft-897D
    2 V8's a V6 and an inline 4
    Mar 2017
    Thanked: 11
    Thanks. What about the battery bank?Do I need to split it or can both mppt's charge the same battery bank at the same time
    Nov 2008
    Ellisras
    Thanked: 49
    What about adding 2 more 12V panels to make all 48V
    Thus
    - 24V panels - 2 strings of 2 panels
    - 12V panels - 2 strings of 4 panels
    - then only one controller
    2 panels cheaper than another controller
    2000 Patrol GU 4.2D(onkey) @ 800 000 km
    Hillcrest, Malaysia
    Thanked: 3251
    Both chargers can charge one battery, with most chargers anyway. You need to check the specs.
    Hillcrest, Malaysia
    Thanked: 3251
    Thus
    Not a good idea, especially with an mppt charger. You get multiple mppt points, only one of which is the true Mppt. This can confuse the hell out of a mpg chargers tracking system.
  7. The Following 2 Users Say Thank You to Fluffy For This Useful Post:
    Hillcrest, Malaysia
    Thanked: 3251
    BTW - You don’t need to configure them to get 48V. That’s what the solar charger is there for. The mppt spec will tell you what panel voltages will work. In your case the max PV voltage must just be <150V
    PLEASE NOTE - THIS IS THE PV PANELS Voc MAX, not 24V or 12V
    Mar 2017
    Thanked: 11
    Thanks for the advice Ill just get a second mppt controller. Currently only the 12v pv are connected to the mppt and I lined all six of them in series and they give me an Voc of around 117 v. and +- 8.3 A . Reason being I wanted a high voltage system to reduce voltage loss on the 6 gauge wiring to the.charge controller. With your setup of two strings of 3 x12v panels in parallel will supply twice the current at about 16.6A which I assume will charge the battery bank in a shorter time.
    Nov 2008
    Ellisras
    Thanked: 49
    Does that mean you can connect the 4 24V panels and 4 of the 12V panels all in series ?
    4x24 + 4x12 = 144 V
    Hillcrest, Malaysia
    Thanked: 3251
    Actually no. I suggested the configuration to be safe. If all in series is safe then that is good, go for it, unless there is a chance of shading.
    It actually doesn’t matter what the currents are from the PV array. In a mppt Charger it performs a power conversion not a current or voltage conversion, so either way the net current into the battery will be the same no matter what the PV current is.
  12. #11
    Nov 2008
    Ellisras
    Thanked: 49
    4x24 + 4x12 = 144 V
  13. #12
    Hillcrest, Malaysia
    Thanked: 3251
    4x24 + 4x12 = 144 V
    Absolutely no way, ever. Please read the last sentence in post #7 carefully.
    I also urge people to be aware when playing with larger systems and panels in series.
    We are getting into lethal voltages territory. PASOP.
  14. The Following User Says Thank You to Fluffy For This Useful Post:
  15. #13
    Nov 2008
    Ellisras
    Thanked: 49
    I hear what you say about dangerous Voltage, but in post 7 you said it must just be smaller than 150V
    Now I am asking if you can string to create 144V - that is < 150V
    Slightly confusing me...
  16. #14
    Hillcrest, Malaysia
    Thanked: 3251
    Read post #7.
    A panel has two main voltages. Basically the “working” voltage and the “disconnected” voltage.
    So typical voltages for your “12V” Panel are 17V and about 23-26V, basically twice you’re string voltage. Your 144V string is going to have an open circuit voltage of around 260-300V DC.
  17. The Following 2 Users Say Thank You to Fluffy For This Useful Post:
  18. #15
    Paradise Beach
    Thanked: 16
    And it is now considered a low voltage electrical installation with legal considerations
  19. The Following 2 Users Say Thank You to fredwb For This Useful Post:
  20. #16
    Mar 2017
    Thanked: 11
    as you can see 4 x36.8 is 147v which is too close to the limit 150v
    initially i thought that if I can match the 12 v string to the 24v string in parrallell with no more than 5% difference in the voltange of the strings then it may work
    but I would rather be safe and not confuse the mppt.Click image for larger version.
ID:	486641Click image for larger version.
  21. The Following User Says Thank You to Mbu For This Useful Post:
  22. #17
    Nov 2008
    Ellisras
    Thanked: 49
    Thumbs up Re: Solar panels configuration dilemma.
    Many things can be learned by reading this forum...
  23. The Following User Says Thank You to Dungbeetle For This Useful Post:
    Mbu
  24. #18
    Kuilsrivier
    Thanked: 59
    Rather get a 2nd MPPT controller.
    Have the 24V panels on one MPPT and the 12V panels on the 2nd MPPT.
    You can now have each set also facing different directions, so now you can have morning and afternoon covered.
  25. The Following 2 Users Say Thank You to Wetkit For This Useful Post:
  26. #19
    Thanked: 30
    Buy a second MPPT charge controller and rig the strings as @Fluffy said. Locate the two sets of panels as @Wetkit said. One set facing True North and the other True West to True North West.
    If I may quote: "MPPT checks output of PV module, compares it to battery voltage then fixes what is the best power that PV module can produce to charge the battery and converts it to the best voltage to get maximum current into battery."
  27. The Following User Says Thank You to mygoggie For This Useful Post:
    Mbu
