Scooter misfire at speed, Help Please!
Results 1 to 20 of 26
    Thanked: 62
    Default Scooter misfire at speed, Help Please!
    Hi All
    My daughters scooter has developed a missfire at speed.
    Starts and reaches about 50kph no problem but as soon as you go any faster is boggs and missfires.
    I have checked the following.
    1. Vacuum hoses
    2. Pet cock
    3. Coil and plug lead
    4. Plug
    5. Inlet manifold (leaks)
    6. Carb cleaned
    7. Mixture set
    No luck, still won't go. Any advise on what to check next?
    Welkom
    Thanked: 70
    Default Re: Scooter misfire at speed, Help Please!
    Blocked/Dirty fuel filter perhaps causing fuel starvation at speed.
    99 Mitsubishi Pajero SWB 3.5 V6 Blister 4X4
    11 VW Amarok 2.0 BiTDi 4Motion D/C
    10 BMW 135i ///M (platkar)
    Bush Pig Off-road Trailer
    Ex: 11 Mitsubishi Triton 3.2 D/C 4X4
    Ex: 08 Mazda BT50 Crdi D/C 4X4
    Ex: 06 Ford Ranger 2.5 D/C 4X4
    Ex: VW Syncro 4X4
  3. The Following User Says Thank You to MarcoP For This Useful Post:
    Thanked: 62
    Quote Originally Posted by MarcoP View Post
    Thanks Marco, forgot to mention that I checked that, even bypassed the filter... no luck
    Thanked: 4262
    Check the exhaust for carbon......
  6. The Following User Says Thank You to jelo For This Useful Post:
    Mar 2018
    Randfontein
    Thanked: 13
    Could be that the stator isnt able to provide enough spark at those revs?
    Welkom
    Thanked: 70
    Did you check the filter/gauze in the Pet cock as well?
    Ex: VW Syncro 4X4
    Hillcrest, Malaysia
    Thanked: 2979
    Regrettably I have no choice but to offer the following honest advise.
    Change the sparkplug and buy better quality 2SO, not forecourt Jasco FC rubbish.
    Or resign yourself to misfires, fouled plugs and changing plugs regularly.
    That's honest opinion. I may not know a lot about 2SO in Turbo Diesels, But i know a $hit&oad about 2SO in two
    stroke engines.
    If on the other hand the scooter is a 4 stroke, forget the above comments in your case.
    ZS5KAD Yeasu Ft-897D
    2 V8's a V6 and an inline 4
    Thanked: 62
    stroke engines.
    Thanks Fluffy, it is a Four Stroke
    Thanked: 62
    Hi Marco, yes cleaned that when I cleaned the fuel tank
    Thanked: 62
    Quote Originally Posted by MartinBravo View Post
    I will have to check that, Could it be the CDI? Or do either they work or not work at all?
  13. #11
    Jul 2008
    Wellington
    Thanked: 210
    Coming from a KTM that could do all sorts of weird and wonderful things..
    Have you checked the state of the battery?
    Somewhere in between Land Rovers
    Honda Africa Twin
  14. #12
    Thanked: 62
    Thanks Jelo. will do that!
  15. #13
    Aug 2008
    Rangeview Krugersdorp
    Thanked: 456
    Lots of Yoootoobs on making your scooter go faster by deristricting it ?
    Might be worth a look.........
    Chev Aveo and Atos and Polo.
  16. #14
    Thanked: 62
    Quote Originally Posted by hcs View Post
    Mmmm... seems fine, but I will swop out with my bikes battery and check, you never know...
  17. #15
    Mar 2018
    Randfontein
    Thanked: 13
    Post Re: Scooter misfire at speed, Help Please!
    Nope. i have had it where it wasnt providing enough and would almost go into a rev limiter type situation, the bike should be able to rev free through the range.maybe its chucking spark away somewhere too?
  18. #16
    Thanked: 62
    Thanks Marco I will have a look, I have searched youtube for my specific problem but have tried all the fixes I could find without luck
  19. #17
    Thanked: 62
    Thanks Martin, will have a look
  20. #18
    Jul 2008
    Wellington
    Thanked: 210
    Another thing to recheck or perhaps just refit is the spark plug.
    I fitted new plugs to my bike and one new plug was a dud. Bike ran rough and would also misfire a bit. Changed the plug and all sorted again
    Honda Africa Twin
  21. #19
    Thanked: 62
    Thanks hcs, It is worth a try!
  22. #20
    Waterfall
    Thanked: 256
    Sounds like your ignition coil is breaking down.
    Have you cleaned the airfilter recently?
    Any minority that advocates for gun control is either wilfully ignorant, or has never opened a history book.
