Venter trailer with offroad chassis modification - Page 2
Results 21 to 40 of 49
    Aug 2007
    Thanked: 91
    Default Re: Venter trailer with offroad chassis modification
    Looking Good Mike!
    Aug 2007
    Thanked: 91
    Lol, no Tron. Its so that the cops pulling one over cant see the changes made. Infact, hardly anyone will notice
    Aug 2007
    Thanked: 91
    Bill brakes is always a good idea, thing is my axel is still new, only two yesrs old and I am not changing it as well.
    Aug 2007
    Thanked: 91
    Mike where you fitted your spare wheel is where i am fitting a basket from mesh to transport wood and grids
  5. #25
    Aug 2007
    Thanked: 91
    Frustrating I cant find any "off-cuts' pieces of mesh (or expanded metal) at the steel dealers in my area. I need three small pieces, Not going to buy a full sheet.
  6. The Following User Says Thank You to Bostokkelos For This Useful Post:
  7. #26
    Aug 2007
    Thanked: 91
    Positioning of the nosecone, to create the gap where the mesh basket with angle irion frame is going to be for the wood and dirty braai grids
ID:	477020   Click image for larger version.
ID:	477021   Click image for larger version.
ID:	477022   Click image for larger version.
  8. #27
    Jul 2017
    Hoedspruit
    Thanked: 131
    I have a 1976 Venter that I want to do the same to. Will be putting a bought axle on so that I can use the receipt for the re-registration to up the puny 560kg tow limit.
    I like your ideas with the chassis and will be doing pretty much the same as mine is rusted badly
  9. The Following User Says Thank You to Chris G For This Useful Post:
  10. #28
    Aug 2007
    Thanked: 91
    Chris rust is the liller for a venter. I have no rust. I will paint the whole trailer underneath with chassis paint. Should last me years
  11. The Following User Says Thank You to Bostokkelos For This Useful Post:
  12. #29
    Jul 2010
    Pinetown
    Thanked: 495
    What mod did you make to the a-frame itself to strengthen it ?
    Platkar = Chevy Spark 1.2
  13. #30
    Aug 2007
    Thanked: 91
    I replaced the whole Aframe with 100x50 lip channel. The new aframe is welded onto the new chassis.
  14. The Following User Says Thank You to Bostokkelos For This Useful Post:
  15. #31
    Thanked: 797
    Quote Originally Posted by Chris G View Post
    Is this possible?
    I have a rusted out trailer that I am gong to rebuild and if possible I wouldn't mind doing a weight upgrade.
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  16. #32
    Nov 2014
    JOHANNESBURG
    What size tyres did you fit to get greater ground clearance. My other comment is that when you go off-road is to used two 50mm ratchet straps and put them over the lid and going around under the chassis and that way it prevents the to of the trailer from shaking to much on the chassis
  17. #33
    Aug 2007
    Thanked: 91
    The ground clearance was gained due to the fact that There is now a 50 mm spacer (the chassis) between the trailer box and the axle. The axle is now fixed to the chassis(which is the bottom of the trailer now), and the load box is mounted on top of the chassis, which use to be the bottom of the trailer. Thus the 50MM lift. The tyres are still the same tyres and rims that was on the trailer
  18. #34
    Aug 2007
    Thanked: 91
    Also, the Axle moved "backwards", although its still at the same place on the trailer, the fact that I increased the length of the A frame with 350 mm, the axle moved 350 mm futher away from the tow ball of the car. This will help with more stable towing
  19. #35
    Aug 2007
    Thanked: 91
    2000 views! Well atleast I created some interest lol. If someone is doing this aswell, let us know
  20. The Following User Says Thank You to Bostokkelos For This Useful Post:
  21. #36
    Jul 2017
    Hoedspruit
    Thanked: 131
    Is this possible?
    Yes. If you upgrade the axle you need to take it for roadworthy and weighing. I believe you apply at the traffic department for a change to the vehicle first. Then take all your paperwork to the licencing dept. Get it finalised. Get the new specs and approach campworld or some such place for a new licence plate.
  22. #37
    Thanked: 797
    Great, thanks for the info!
    Sounds like it's doable. I have an axle with brakes so that's sorted.
    Looks like I am off to the dreaded Civic Centre License Section.. Abandon hope, all ye who enter here...
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  23. #38
    Melkbosstrand
    Thanked: 45
    Go early... No queues and the staff are still friendly... Haven't been p!ssed off yet.
    2015 VW Amarok 4motion Auto
    2011 Conqueror Companion
  24. #39
    Jul 2017
    Hoedspruit
    Thanked: 131
    Make sure that you have your receipt for the axle. They will need that
  25. #40
    Thanked: 797
    I have never had anything but good service from them.
    Milnerton is another story altogether.
    John
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
