2005 Wrangler TJ Build - Page 5
Results 81 to 98 of 98
  1. #81
    Jul 2014
    Thanked: 32
    Default Re: 2005 Wrangler TJ Build
    How much did thatbfront bumper cost you? Jeep looks good
  2. #82
    Jul 2008
    Joburg
    Thanked: 24
    Quote Originally Posted by imo View Post
    Fitted the LED headlights today and the Lightbar.
    also went perhaps a little too crazy with laminex. What do you guys think?
    Attachment 477518
    Before laminex
    Attachment 477519
    After Laminex
    YES OR NO to the laminex? Its looking a little too gangster for my liking
    When I was first looking at TJs I was looking for a black one so I could do exactly that. Nice one.
    Stu.
    Current:
    06 Wrangler Sahara. 3.5inch Rubicon Express and Bilstein lift, Metalcloak control arms, 1.25" RC Body Lift, 1" JKS MotorMount Lift, Zone Disconnects, BFG KM2 33's
    NO LOCKER NEEDED!!!
    KTM 1190 Adventure
  3. #83
    Thanked: 24
    Leave laminex on for a while, if you don't like it after a month, pull it off.
    1985 Toyota Fj45 Landcruiser 4.2 P/U (Sold),
    1991 Jeep Wrangler YJ 4.0 Sport (Sold),
    2006 Toyota Hilux 3.0 D4D D/C Raider (Sold),
    1984 Suzuki Sj410 1.0,(Sold)
    1991 Jeep Wrangler YJ 4.0 Renegade
    2007 Jeep Wrangler JKU 3.8 Sahara
  4. #84
    Jan 2009
    Thanked: 9
    Quote Originally Posted by rog163 View Post
    Hi, you can contact Terrence from Advanced Offroad in Cape Town for a price on 0828950744
    2005 Jeep Wrangler Sahara
    2016 BMW 1200GS Adventure
    [URL="http://Www.two2zanzibar.blogspot.com"]Www.two2zanzibar.blogspot.com
    *** ADMIN REMOVED ***
  5. #85
    Jan 2009
    Thanked: 9
    Hi All
    Im having a very slight issue with the vehicle bogging/hesitating/breaking up on take off and through the lower gears at low RPM.
    Any ideas on the causes?
    i look forward to your responses
  6. #86
    Feb 2015
    Noordhoek, Cape Town
    Thanked: 2435
    I wonder if the 33" tyres might not be a wee bit too heavy? Perhaps gearing/ratios would help. Did this happen before the 33's were fitted?
  7. #87
    Jan 2009
    Thanked: 9
    Quote Originally Posted by Chris Stoffel View Post
    Hi Chris, its always been an issue even before the lift and tyres. The car runs well and gets up to speed comfortably with hard acceleration. The problem is an initial "flat spot" on acceleration in First and second gear.
    Its not serious, just a little annoying.
    BTW, i got 300km on my first full tank!! Thats frikking heavy, however i have been driving the Jeep pretty hard. Lets see what happens on the next tank.
  8. #88
    Feb 2015
    Thanked: 2435
    Hallo imo. Maybe it needs a tune up?
  9. #89
    Jan 2009
    Thanked: 9
    Just had a service, but i think it may be a good idea to get someone else to look at it.
    Good idea, Thanks
  10. #90
    Pretoria East
    Thanked: 221
    Good idea, Thanks
    Just a guess but you may have a vacuum leak likely from a hose that has perished which causes the stumble/hesitation.
    You should inspect and probably replace all the little vacuum hoses which are at least 10 years old now. Boring and fiddly but a good idea nonetheless.
    Also inspect the mating surfaces at the air flow sensor/throttle body. Spray quick start over these areas while it is idling and it will show a leak if present by causing the rpm to increase.
  11. The Following 2 Users Say Thank You to locklaw For This Useful Post:
  12. #91
    Jul 2008
    Joburg
    Thanked: 24
    Yeah. My throttle body got pretty dirty and started sticking open slightly on idle and causing other weirdness. Took it off and gave it a good clean and it was hundreds.
    Remember everything on there is now 12years old at minimum.
    Stu.
    Current:
    NO LOCKER NEEDED!!!
    KTM 1190 Adventure
  13. #92
    Jan 2009
    Thanked: 9
    Quote Originally Posted by locklaw View Post
    thats a good idea, gonna be a busy weekend
  14. #93
    Pretoria East
    Thanked: 221
    Yep. Even if it does not cure your stumble, it is good maintenance to do which is often neglected. While you are in there, consider buying some electrical contact spray and cleaning connectors out as you go.
  15. #94
    George
    Thanked: 362
    Isn't switch cleaner perhaps better for that application, it removes moisture, cleans, small amount of lube and increases conductivity?
  16. #95
    Pretoria East
    Thanked: 221
    Yep, that is what I meant. I like the Liqui-Moly one but any good brand will do
  17. #96
    George
    Thanked: 362
    Spanjaard also makes one, I've been using it for years, available at Midas etc and not overly expensive.
  18. #97
    Perth
    Thanked: 44
    With regards to getting a bit more sound, I just changed the rear muffler to one with a straight through pipe. Its also called a glass pack or hotdog as far as I know. Definitely made it sound a lot better, and no worry about the cat
    Hendrik
    2.5HP Triton
  19. #98
    Jul 2014
    Thanked: 32
    Default 2005 Wrangler TJ Build
    On the verge of ordering one, how much space is there between the Bull bar and front of the car? Is there a large gap?
    Would You mind posting a picture from the side of the bumper?
