Amarok Suspension Upgrade Options - Page 2
Results 21 to 36 of 36
    Feb 2007
    melkbosstrand
    Thanked: 31
    Default Re: Amarok Suspension Upgrade Options
    Quote Originally Posted by PierreSN View Post
    I definitely asked for longer coils and if I remember correctly the old vs new was still shown to me. So I am convinced I went for the long er coils with the shocks. The initial plan for me was only to get the longer coils up front and blocks at the rear with the standard shocks in place. Upon removal of the shocks we noticed the one shock was buggered completely and then only did I order the bilsteins shocks. It might be the setting on the shock then as you say, but I am not sure how the shocks will have to be set?
    read previous posts & picture, the shocks should be at lowest setting. The cradle should be as far down as possible...
    VW Amarok 132kw 4motion highline 2012
    Software upgrade (170kw +- & 560nm)
    3" custom down pipe and catalytic converter removed.
    Bilstein suspension upgrade
    Thanked: 26
    Quote Originally Posted by jonoB View Post
    Thanks, I will have a look at the shocks and see where this craddle is set to.
    If not at the lowest setting - does the whole assembly need to be taken apart or can it be adjusted whilst still installed to the vehicle?
    2014 VW Amarok 132kw 4Motion Auto
    Stofpad Rock Sliders, Full Bilstein Suspension with 35mm Lift
    Amorosa
    Thanked: 113
    Quote Originally Posted by HaroldJK View Post
    Nou eers op 115,000km's... Nog 'n spring chicken!
    Still going strong!
    Mooi man, dan het daai Seikel suspensie minder as 100k km op...
    Othou Seikel is deur VW getoets.
    Die ander nie en dan kry jy vrae as jy goedkoper goed insit...
    VW Amarok
    Bush Lapa Miskruier 586
    Dec 2011
    Thanked: 152
    It would be very interesting to do a comparison between some of the Aussie suspensions and the Germans. I have the Seikel Desert fitted with Eibach coils and shocks and it is superb. I even had a west coast farmer tannie in the bakkie a while back, she commented that it felt like a Mercedes on the dirt road we were on. High praise indeed, I think?
    The germans just really seem to understand shocks and suspensions. When the time comes to upgrade I will most probably fit the Bilsteins because I haven't seen the Eibachs for sale anywhere. BUT, if someone were to show me how good an Ironman setup is in comparison, I will be very willing to change.
    Perhaps on the V6 that I'm trying REALLY hard to convince myself I don't need..
  5. #25
    Feb 2007
    melkbosstrand
    Thanked: 31
    the entire assembly will need to be removed and taken apart... If done by someone that knows what they are doing it shouldn't take long
  6. #26
    Jan 2016
    Groot Gat
    Thanked: 18
    This is how my coils compared that came from Mikem(Darryl).
    Not longer but just more turns in coil that came from them.
    I have also fitted an Arb delux relacement bar and it only dropped 12mm in front.
    Hope this helps.
    '10 Vw Amarok 2.0 BiTdi D/C 4trek
    Mikem Suspension Lift
  7. The Following 2 Users Say Thank You to StephanJvR For This Useful Post:
  8. #27
    Feb 2007
    melkbosstrand
    Thanked: 31
    Mine is exactly like that but longer, Darryl had supplier issues at the time but managed to get me longer coils... Give him a call and see what he has for you... Im sure he will remember me as he couriered coils back and forth multiple times to assist me .
  9. #28
    Jun 2015
    Any thoughts on this:
    SUSD 50mm Front/25mm Rear Full Lift & Level Kit for Amarok
    https://www.susd.co.nz/product-page/...kit-for-amarok
    2011 VW Amarok BiTDi DC 4Motion
    Seikel Field & Forest Suspension
  10. #29
    Thanked: 7
    Not a bad solution for R6500 landed in SA...
  11. #30
    Swakopmund
    Thanked: 50
    If you just put in spacers, you only lift the centre of gravity. There is no improvement in wheel travel or flex nor load carrying ability. In fact you slighty worsen the road holding. When using a proper aftermarket suspension, usually the higher centre of gravity is compensated for by the suspension setup. Your wheel travel improves due to longer shocks. The shocks would be better quality than stock. Springs can be designed to cope with a higher than normal load, e.g. when fitting steel bumper and other accessories.
    When a man sits with a pretty girl for an hour, it seems like a minute. But let him sit on a hot stove for a minute and it's longer than any hour. That's relativity.
    ALBERT EINSTEIN
  12. The Following 3 Users Say Thank You to HugoNotte For This Useful Post:
  13. #31
    Dec 2013
    Thanked: 155
    Agree 100%!!
    If you're simply looking for more ground clearance it might be an option, but if you then fit a heavy bumper you would actually reduce your front susp travel!
  14. The Following User Says Thank You to WillemT For This Useful Post:
  15. #32
    Oct 2012
    otjiwarongo
    Thanked: 49
    ek stem, k het die dessert seikel kit gehad op my vorige amaroks en nou spacers en die pad houvermoe is def swakker, ek sit volgende maand weer seikel dessert kit in. maak net n helse verskil
    2017 VW Amarok BiTDi 4Motion D/Cab
    2012 VW Touareg V6 TDi Bluemotion
    2012 VW Amarok BiTDi 4Motion Singel Cab (Sold)
    2014 VW Amarok BiTdi 4 Motion Auto (SOLD)
    2016 Toyota Hilux 3.0 D4D 4x4 X/Cab (SOLD - 3 BLown Turbos )
    2011 VW Amarok BiTDi 4 Motion DC (SOLD)
    2013 VW Polo 1.6 Comfortline 5Dr (Sold)
    2004 Jurgens Explorer
  16. The Following User Says Thank You to hein100 For This Useful Post:
  17. #33
    Jul 2015
    Gauteng
    Thanked: 8
    Quote Originally Posted by hein100 View Post
    En wat van die rit gehalte. Maak die "Desert" hom stywer of sagter ry?
  18. #34
    Oct 2012
    otjiwarongo
    Thanked: 49
    Quote Originally Posted by KRoss View Post
    Dit is baie meer compose op grond paaie. En obvious jou travel is beter. As jy oor n speedbumb gaan dan is die bewegung van die neus op en af def minder. Sal nie se hy ry baie harder nie. As hy doen is dit nie veel want ek het niks agter gekom.
  19. The Following User Says Thank You to hein100 For This Useful Post:
  20. #35
    Oct 2012
    otjiwarongo
    Thanked: 49
    Ok so my dessert seikel is gefit en sommer n dust kit ook gefit vir die bak. Met die canvas seiltjie op en hou dit nogal die stof mooi uit.
    Wat is julle mates die wat seikel het voor en agter na die lift?
  21. #36
    Jul 2008
    Pretoorsdorp (Centurion)
    Thanked: 69
    Rear Set-up with airbags, these are pretty awesome as you can inflate them up to 7 bar with heavy load. Fully loaded 3.5bar worked great to level the Amarok,
    Load include, canopy with fridge & battery plus 50l Water & 50l Diesel on the roof rack with amo-box & side awning Plus fully loaded trailer also with extra fuel, 100l Fridge and 2 x Dual battries.
ID:	472578   Click image for larger version.
ID:	472579   Click image for larger version.
    SUSPENSION FOR THE FUTURE
    www.amadaxtreme.co.za S2551'50.2 E2809'58.2
    Diamond Park nr2, 86 Jakaranda Str, Hennopspark, Centurion
    Cobus Bohmer - 071 641 7947 cobus@amadaxtreme.co.za
  22. The Following User Says Thank You to Navigator For This Useful Post:
