40 liter Engel fridge
Results 1 to 14 of 14
    Mar 2011
    Brits
    Default 40 liter Engel fridge
    I am all new to an camping fridge and need some advice.
    I recently bought a second hand 12V/220V Engel fridge for our camping trip starting this Saturday.
    We will be going to Southern Namibia (fish river & Richtersveld) and then down the west-coast to Cape town.
    I have bought the fridge, plugged it into 220 Volts in the house, to see if it is working and I was really impressed.
    The temperature were at a constant -18.5 C and at night it dropped to -22 C.
    So Friday I put it into the fortuner to see what it will do on the 12 Volts.
    The lowest it reached (at night early morning) was -2 C.
    Yesterday at 12pm it was standing on +4.5 C and it was not open since Saturday morning.
    The fridge is still at its coldest setting. Same as what it was in the house n 220 V.
    I do have the isolated bag in which the fridge is standing.
    I use a brad Harrison connector plug and the fortuner does have a second battery.
    My question is, is it normal for the fridge to only reach -2 C on 12 Volts and +4.5 C at midday ?
    Centurion, South Africa
    Thanked: 232
    Default Re: 40 liter Engel fridge
    From what I can remember when I still had my Engel 40 rigged up via the same setup in my FT (and Echo 12v when at campsite), it maintained what is was set to, e.g. -5 etc.
    Are you sure it is getting a continual power supply during the time?
    Pieter
    Fortuner 4x4
    Echo 4
    Thanked: 1034
    Did you test it with contents or an empty fridge ?
    BMW R1200R
    Thanked: 99
    My 40lt Engel will reach and maintain -18 or colder on the coldest setting whether on mains or battery power.
    From what you describe something not right.
    Either the battery is not good or the fridge is faulty. Make sure the battery is fully charged and have what it takes to keep the fridge going, if it is and it struggles to go below -18 overnight there is something wrong.
    My money would be on the battery not delivering as it should.
    2009 Hilux 3.0D4D D/C 4X4, Dual battery, ARB Bar, Winch, Home made rock-sliders, EFS Suspension, IPF Spots, Stofpad rear bumper.
  5. The Following User Says Thank You to Pietsweis For This Useful Post:
    Jun 2008
    kleinmond
    Thanked: 54
    check second battery, is it fully charged, you should use a trickle charger at least once a month because normal driving will not fully charge second battery
    Landrover Puma 110, OME - sold
    Imagine Trailvan
    Disco1 V8 - sold
    Disco 4 V8 HSE
    Thanked: 99
    Sorry, to add a comment.
    If on the coldest setting and running at temperatures of +4.5 degrees does the compressor run? Because it should run continuously trying to get the temperature down, if it doesn't then once again I would think a battery issue.
    Do you have a battery tester?
    Mar 2011
    Brits
    I did test it with contents in (wors - packets).
    I don't have a battery tester
    Will battery-centre be able to do the necessary test ?
    Thanked: 149
    Check the 12v supply cable.Spesificaly th fridge connection side. Thars why owner#1 sold it. Maybe the Fortuner connection is not supplying enough amps. All else fails your inverter power supply in th fridge is crook.
    Jun 2008
    kleinmond
    Thanked: 54
    get yourself a dual battery indicator, it helps a lot (and a elcheapo multimeter)
    Imagine Trailvan
    Disco1 V8 - sold
    Disco 4 V8 HSE
  11. The Following User Says Thank You to briansvdmerwe For This Useful Post:
    Mar 2011
    Brits
    So I took the car to battery-centre.
    Discovered that the second battery was only 7.4 Volts and have a dead cell.
    Replaced it with a proper 80 amps deep cycle battery.
    Discovered then that the second battery doesn't get charged from the alternator.
    Went to auto-electrician and discovered there was a broken off wire.
    Fixed that, and now back home.
    Just put the Engel back and I am sure it will be fine now.
    Will check in a few hours time.
    I am sure the broken off wire was the culprit from the start.
    Thanks for everybody's input
  13. #11
    Thanked: 149
    Good enjoy many happy cold hours .
    Just remember that Engel does not have a low voltage cut out.
    Groetnis
    Coenie
  14. #12
    Apr 2008
    Thanked: 51
    Ras en Des ek sien julle is van Brits en daarom los ek maar die brits en hoop julle verstaan Afrikaans.
    Ek is baie dom met elektries en het twee 40l engels. Al deur die 3 batterye. Toe ek jou storie lees toe weet ek, maar nou is jy "sorted"
    Die volgende moet jy egter onthou: Met n 80 ampere uur battery (Ek het een Engel gedoen op 90Au diep siklus en gestruikel) ongeag wat die eksperts vir jou se, gaan jy op maksimum verstelling die battery laat afloop al ry jy ook elke dag vir 8 ure in baie warm toestande. Die diep siklus batterye laai baie stadig en as hy te diep ontlaai "tel die kar se alternator hom nie op nie"
    Iemand het genoem dat die Engel nie n low voltage protecter het nie. Dus voor jy sien is die battery pap.
    Wat jy kan doen: Stel die Engel sodat hy op 0 grade bly. Moenie te veel warm produkte insit nie. Hou die battery dop!
    Ons het nou n 90Au loodkristal battery, Een Engel is vrieskas en word op 0 gestel. Die ander een is yskas en hy is op 5. Die battery hou dan so 2 dae, maar as dit bitter baie warm is (Oktober in Chobe) moet ons maar meer ry. Ry Ctek charger saam en op kampplekke met krag word die battery weer gelaai (blykbaar laai die loodkristal nie vol op die alternator nie)
    Het julle kinders wat saam kamp? Indien ja kry n solar
  15. The Following User Says Thank You to Williepiet For This Useful Post:
  16. #13
    Thanked: 149
    Wil net ook by se die termo meter buite wys meer (warmer) as wat binne is.
    Ek sit myne in die aande af , more oggend is hy nog koud genoeg en die binnegoed nog gevries.
    Ek stel my myne net so duskant die 3.
  17. #14
    Jan 2016
    king william's town
    Thanked: 240
    Just something else to remember where my system faltered.
    Bad roads can cause play in the Brad Harrison plug which can cause it not to give constant power through to your fridge/freezer.
    Carry a spare with you for emergencies...
  18. The Following User Says Thank You to haboob For This Useful Post:
