Indeflate - Inflate, or deflate two tyres simultaneously! - Page 8
Page 8 of 8 FirstFirst 1 2 3 4 5 6 7 8
Results 141 to 149 of 149
  1. #141
    The Windy City
    Thanked: 1801
    Default Re: Indeflate - Inflate, or deflate two tyres simultaneously!
    Ek sal vir jou uitvind.
    INDEFLATE, Now available in the online shop!
    Click below for more info.
    http://www.4x4community.co.za/shop/i...&product_id=68
  2. #142
    Feb 2013
    Thanked: 24
    For the guys who has been using this for a while now. Just to confirm, does the gauge read fine around 100 to 300 kPa, or do you find yourself still using another gauge to double check each time?
    You probably heard people saying Africa is not for sissies. Well, neither is it for wussy equipment.
    Man who dies with most gear wins!
  3. #143
    Thanked: 36
    Gauge is very accurate - checked against ARB gauge and TPMS. No need to check with another gauge - I did initially - but now satisfied it is accurate.
  4. #144
    The Windy City
    Thanked: 1801
    I don't, typically deflate to around 1 bar, don't really care if it is 1, or 1.2.
  5. #145
    Lonehill, JHB
    Thanked: 519
    On sand you need 0.8 typically, even 0.6. It’s unbelievable what difference 0.2 bar makes on soft sand. On normal trails it’s not such an issue.
    But the Indeflate I have is very accurate, no issues there
    2014 Pajero 3.2DiD SWB
  6. #146
    Greenstone Hill
    Thanked: 48
    When this was originally 'launched' - I remember thinking "Wow, that's quite a bit of money to let air out of a tyre". I kept thinking that way until this past holiday when my travelling companion pulled one out when he and I were about to cross over onto soft sand.
    I climbed out my car, guage in one hand, ARB deflator in the other - having taken both out the cubby hole.
    He climbed out, went for a pee, opened his drawer system, took it out, came over, and showed it to me while I started my first wheel.
    Fast forward a few minutes, he's back in his car, everything done and packed away - and I was only on wheel 2/6 (including caravan).
    I returned back home, and the VERY first thing I did after unpacking the caravan was buy TWO here on the forum. They arrived 1,5 days later = impressive.
    These Indeflate units are AMAZING, and very well built, you can feel the quality.
    I think what I liked most about the unit, is (obviously the speed) - but the quick connect onto the two wheels. There's no unscrewing valves etc. Just click onto one wheel, click on the other, and start deflating - AND then it self levels the two tyres too. BRILLIANT!
    Mark Trollope
    Prado 120 V6, Fortuner V6, Hilux 2.7, Cruiser 80 EFi, Cruiser 75, Lexus RX350, Jurgens Xplorer
  7. #147
    Lonehill, JHB
    Thanked: 519
    Default Indeflate - Inflate, or deflate two tyres simultaneously!
    Next step is to make two “extensions” that allows you to connect the existing indeflate to another two wheels then you can deflate (and inflate) all 4 wheels at once. It is simple really.... but the amount of tubing will make it bulky
  8. #148
    Lonehill, JHB
    Thanked: 519
    Quote Originally Posted by chris77777 View Post
    Ek het die glas van die meter op die Indeflate gebreek. Kan die glas vervang word ?
    I contacted them on Facebook and Ricus Venter confirmed that they can replace the glass on the meter. Give him a call.
  9. #149
    The Windy City
    Thanked: 1801
    Quote Originally Posted by KurtG View Post
    No need, already been in contact with him yesterday morning, will advise once the best method has been established.
