How to convert GPS coordinates format.
Results 1 to 15 of 15
    Shelly Beach
    Default How to convert GPS coordinates format.
    I am in process of plotting route through Damaraland. All coordinates are given as S21 00'51 E14 27'28. Now I have other coordinates given as S26.911 E13.627. How do I convert this to read like the previous format ? I am using Base Camp.
    any help will be appreciated.
    Default Re: How to convert GPS coordinates format.
    Hi. Google for NGI coordinate converter. Its a excel program that you can enter data into in most formats and gives out other formats. If you dont come right give me a pm
  3. The Following User Says Thank You to Dirkie2710 For This Useful Post:
    Lubumbashi
    Thanked: 8
    Zorba,
    You can send the data to me. I can change the format as required.
    kinnieve@gmail.com
    Cape Town, Plumstead
    Thanked: 62
    Can't you just put the info into Basecamp in the first format, then in the settings change to the second "other" format and then just enter them ?
    Safe Diving
    Andy
    2013 Isuzu KB6 300 DC 4X4
    http://www.flickr.com/photos/andrews_underwater_images/
    Thanked: 14
    I think this is what you looking for ?
    In Map Source - Edit, Preferences, Position.
    Base Map should be pretty similar.
    This will 'switch' the display of co-ordinates on your map from current system to the chosen one.
    Janine
    2009 Jimny
    Transfer case and Radial cup protection
    VPU - rear wheel arches
    Packing System & Roofrack
    Geolander AT's,
    Airbags & EFS shocks
    2010 Ford Bantam XLT 1.6 - Sold
    1981 Ford Cortina - but it went forever! Until stolen
    Apr 2012
    Bela Bela
    Thanked: 74
    As Andy said. In Basecamp go to Edit. Select Options. At the bottom of the Measurements tab change Grid to the format you need. Change back after marking your waypoint etc.
    If you then close Basecamp and start it again all you waypoints will be in the format that you last used.
    Pete
    ADVENTURE BEFORE DEMENTIA
  8. The Following User Says Thank You to petewill For This Useful Post:
    Shelly Beach
    Quote Originally Posted by Grise View Post
    Thanks to all who replied. I found the solution in the Edit section of BaseCamp.
    Kind regards
    Zorba
    Wartburg
    Thanked: 310
    You can also enter them in Google earth, in whatever format. It will convert them automatically to the format you define under Tools/Options
    You do not need to enter the degree and minute symbols. Just leave spaces for these. eg in dms simply enter eg -dd mm ss.ss, for decimal degrees, dd mm.mmm and dd.ddddd for decimal degrees
    Sep 2014
    Thanked: 24
    S26.911
    0.911*60/100 = 54.66
    66 * 60 /100
    39.6
    South 26 degrees, 54 minutes and 39.6 seconds
    Do the same for E13.627
    May 2016
    Thanked: 1209
    In 2011 I submitted this to the forum.
    Attached Files Attached Files
    2006 VW Touareg V10 TDi
    (currently done more than 373 000 km)
  13. The Following User Says Thank You to 4eTouareg For This Useful Post:
  14. #11
    Thanked: 27
    Thanks, that is a useful file!
  15. #12
    Jun 2012
    Thanked: 84
    Quote Originally Posted by ChrisPH View Post
    S26.911
    66 * 60 /100
    39.6
    Chrisph, dankie wou nou net vra hoekom convert hulle dit nie gou self nie, doen dit so nou en dan sommer met foon se calculator en stukkie papier... Nou laai hulle aps af ens... Hoe gaan jy dit in die bos doen?
    Some people think Enduro Bikes is a matter of life and death. I don't like that attitude!I can assure them its much more serious than that
  16. #13
    Benoni, Gauteng
    Thanked: 21
    Mental arithmetic around the camp fire, before the tot of Scotch naturally ....
    Eric
    ZS6 EPL / ORRA - T60
    ME_______ - '09 SUZUKI JIMNY - Pipe Bumper / Under body Protection / Winch / Snorkel / Roof Rack / VHF+UHF Comms
    SWAMBO__ - MAHINDRA BOLERO - Feels like an SJ / loads like a truck / tows like a tank!
    RETIRED___ - '99 Gen 1 Grand Vitara / 1.6 Vitara JLX ...x2 / SJ413 SWB ...x3 / SJ413LWB ...x1 / SJ410 ...x2.
  17. #14
    Lubumbashi
    Thanked: 8
    Dankie Gerhard!
  18. #15
    S26.911
    66 * 60 /100
    39.6
    That's the way its done, no apps required!
    2011 Discovery LR4 HSE
    2008 LR 110 Defender Puma SVX, 60th Anniversary Ltd Edition.
    2006 LR 110 Defender Td5
    2014 Jurgens Safari Xplorer
    Renault Clio VaVaVoom
