How to convert GPS coordinates format.
Results 1 to 15 of 15
Hybrid View
    Aug 2011
    Shelly Beach
    Default How to convert GPS coordinates format.
    I am in process of plotting route through Damaraland. All coordinates are given as S21 00'51 E14 27'28. Now I have other coordinates given as S26.911 E13.627. How do I convert this to read like the previous format ? I am using Base Camp.
    any help will be appreciated.
    Default Re: How to convert GPS coordinates format.
    Hi. Google for NGI coordinate converter. Its a excel program that you can enter data into in most formats and gives out other formats. If you dont come right give me a pm
  3. The Following User Says Thank You to Dirkie2710 For This Useful Post:
    Lubumbashi
    Thanked: 9
    Zorba,
    You can send the data to me. I can change the format as required.
    kinnieve@gmail.com
    Cape Town, Plumstead
    Thanked: 68
    Can't you just put the info into Basecamp in the first format, then in the settings change to the second "other" format and then just enter them ?
    Safe Diving
    Andy
    2013 Isuzu KB6 300 DC 4X4
    http://www.flickr.com/photos/andrews_underwater_images/
    Thanked: 17
    I think this is what you looking for ?
    In Map Source - Edit, Preferences, Position.
    Base Map should be pretty similar.
    This will 'switch' the display of co-ordinates on your map from current system to the chosen one.
    Janine
    2009 Jimny
    Transfer case and Radial cup protection
    VPU - rear wheel arches
    Packing System & Roofrack
    Geolander AT's,
    Airbags & EFS shocks
    2010 Ford Bantam XLT 1.6 - Sold
    1981 Ford Cortina - but it went forever! Until stolen
    Aug 2011
    Shelly Beach
    Quote Originally Posted by Grise View Post
    Thanks to all who replied. I found the solution in the Edit section of BaseCamp.
    Kind regards
    Zorba
    Wartburg
    Thanked: 416
    You can also enter them in Google earth, in whatever format. It will convert them automatically to the format you define under Tools/Options
    You do not need to enter the degree and minute symbols. Just leave spaces for these. eg in dms simply enter eg -dd mm ss.ss, for decimal degrees, dd mm.mmm and dd.ddddd for decimal degrees
    Apr 2012
    Bela Bela
    Thanked: 84
    As Andy said. In Basecamp go to Edit. Select Options. At the bottom of the Measurements tab change Grid to the format you need. Change back after marking your waypoint etc.
    If you then close Basecamp and start it again all you waypoints will be in the format that you last used.
    Pete
    ADVENTURE BEFORE DEMENTIA
  10. The Following User Says Thank You to petewill For This Useful Post:
